Check engine light after sct x4 tune - Mustang Evolution
Old 08-22-2014, 06:57 PM   #1
gtlovin's Avatar
So I tuned my car and it was running fine and then I was going to my cousins house and the check engine light came on. I have steeda cai as well
gtlovin is offline   Reply With Quote
Old 08-22-2014, 07:48 PM   #2
UrMaster's Avatar
What's the code for
Sent from my SM-N900V using Mustang Evolution mobile app
2011 GT Premium A6 glass roof.
Dynatech LT's, OR-X, Kooks Axle-back, Circle D 5c, Boss IM, BBK 85mm TB, JLT CAI, BMR LCA's, adj UCA & Panhard,Strange 10 way struts, 331 gears tuned by AED.
UrMaster is offline   Reply With Quote
Old 08-22-2014, 08:00 PM   #3
CNFLCTD's Avatar
Who is the tune from?
CNFLCTD is offline   Reply With Quote
Old 08-22-2014, 08:32 PM   #4
gtlovin's Avatar
Steeda
Old 08-22-2014, 08:40 PM   #5
thats not a very helpful description. i'm assuming the X4 has a function that allows you to see what the CEL code is. check it and see what it says.
2012 GT Ignot Silver
Evolution5.0 is offline   Reply With Quote
Old 08-22-2014, 08:43 PM   #6
gtlovin's Avatar
Sorry brotha I'm still kinda new to this. Where would I find it
Old 08-22-2014, 08:55 PM   #7
i don't have a X4 but i just looked it up online and there is a users manual posted and tells you where it is. essentially go into the diagnostics menu and just do what the device tells you.
users manual:http://www.sctflash.com/PDF/X4Manual_002.pdf
Old 08-22-2014, 09:21 PM   #8
UrMaster's Avatar
Plug in the x4 and turn the key to the on position. Then select this setting.
Then select this.
It will then give a description of what the codes are causing the ses light to come on. Let us know what they are.
Old 08-23-2014, 01:40 PM   #9
gtlovin's Avatar
Then select this.
Thanks boss I appreciate the help, it means a lot! The codes are P0171 and P0174
Old 08-23-2014, 01:54 PM   #10
UrMaster's Avatar
What's it say the meaning is?
Old 08-23-2014, 02:00 PM   #11
gtlovin's Avatar
System to lean bank 1 and 2
Old 08-23-2014, 02:19 PM   #12
Grabber Blue5.0's Avatar
Did you remove your cats?
Old 08-23-2014, 02:22 PM   #13
gtlovin's Avatar
Nope all I've done is add a catback exhaust and the tune intake I got 3 days ago
Old 08-23-2014, 03:16 PM   #14
UrMaster's Avatar
Had that issue on my first tune. Get a hold of your tuner. They will make an adjustment to make that pesky light go away
Old 08-23-2014, 04:25 PM   #15
gtlovin's Avatar
Alright will do thank for the help👍
Old 08-23-2014, 04:26 PM   #16
RollDat's Avatar
Same thing happened when I got my tune/intake from steeda. Drove around for about an hour and a check engine light came on, lean bank 1 and 2. Called and found out they didn't put in that I had a CAI with the tune. They sent an updated tune and everything has been good since.
Sterling Grey Metallic 2012 GT
Mobile, AL
Instagram-_andrewmontgomery_
RollDat is offline   Reply With Quote
Old 08-23-2014, 05:09 PM   #17
gtlovin's Avatar
Mobile, AL
Really? Mine turned off then it turned back on
Old 08-23-2014, 06:35 PM   #18
ArtU's Avatar
DO you have an Intake that needs a tune? If so did you tell Steeda which model CAI when ordering the tune? These are the most common codes that show up with a CAI that needs a tune that is not set for it.
edit: Like the other answers, let them know, they will fix the tune and the codes will go away.
Art
Old 08-23-2014, 10:18 PM   #19
gtlovin's Avatar
Art
Yeah bro I bought the tune and intake together
Old 08-24-2014, 01:18 PM   #20
DallasStang77's Avatar
They still need to know because the sales dept is separate from the tunes dept.
check engine
check engine light after x pipe installed hepler02 Pre-2005 V6 Mustang 13 05-13-2013 07:40 AM
Check engine light after tune shunc01 2005-2010 V6 Mustang 7 04-21-2013 06:41 PM
Bama tune or lund tune or steeda tune Mustang32Bill 2011-2014 Mustang GT 89 11-12-2012 10:45 AM
Boss 302 tune and check engine light 4968coyote General Mustang Discussion 0 11-05-2012 10:53 AM
check engine light after x pipe and tune. Yellow50 2011-2014 Mustang GT 21 05-14-2012 09:59 PM
09:51 AM
