Thump/Rattle Noises in Rear - Mustang Evolution
Old 08-26-2014, 09:28 AM   #1
wgolden30's Avatar
I lowered my car and added eibach pro kit, but recently i have been hearing thumping noises as i go over bumps fast, even rattling as well coming only from the back of the car.
any idea what this could be?
wgolden30 is offline   Reply With Quote
Old 08-26-2014, 09:44 AM   #2
Abominable Mustang
WhoDat's Avatar
Region: Alaska
Can't remember what all is included in the eibach pro kit, but a common source of rear end clunking/popping after lowering is the oem sway bar endlink bushings. I'd also go through and make sure everything is still torqued properly. Something could have settled after driving a bit and needs to be retorqued.
Sent from the Death Star.
2012 Kona Blue 3.7L V6:
Old 08-26-2014, 11:22 AM   #3
JoeM1494's Avatar
The thump could be you hitting your bump stops.. I lowered my car on Coilovers and cut my bump stops in half and constantly still hit them giving a thumping noise.. Probably that.
Joe
'13 GT Track Pack
JoeM1494 is offline   Reply With Quote
Old 08-26-2014, 01:01 PM   #4
Stangholio's Avatar
I'm going through the same thing. I did SR springs and BMR panhard bar. It sounds like I am bottoming out on slow bumps. I thought maybe a blown rear because they are still stock. Should I get aftermarket bump stops and change the shocks?
Stangholio is offline   Reply With Quote
Old 08-27-2014, 08:22 PM   #5
wgolden30's Avatar
Here is an update
I went to the dealership where it was installed at and had them take a look. Turned out to be a loose nut on the pan hard bar, as soon as they corrected it drives like a new car.
Old 08-27-2014, 08:50 PM   #6
Redonblackpony's Avatar
Do you have a adjustable upper control arm?
Redonblackpony is offline   Reply With Quote
Thump sound from the back end cmd 2011-2014 Mustang GT 16 03-17-2013 07:06 PM
Thump in the front end geepoons 2011-2014 V6 Mustang 4 07-25-2012 04:39 PM
Thump noise over bumps S197stanGT 2005-2010 Mustang GT 5 06-29-2012 12:02 PM
Strange thump melebop Pre-2005 V6 Mustang 15 07-02-2006 03:24 PM
Dash Rattle?? Tranny Rattle?? ricklmesa Pre-2005 V6 Mustang 0 03-08-2006 07:19 PM
04:40 AM
