Pinion seal leak?? - Mustang Evolution
Old 08-27-2014, 06:05 PM   #1
shellac's Avatar
Pinion seal leak??
Any know issues with '13's? I just had mine replaced at 10,500 along with axel vent. What even causes a pinion seal leak?
shellac is offline   Reply With Quote
Old 08-27-2014, 08:19 PM   #2
Coyote5o's Avatar
Region: West Virgina
My rear was whining like crazy from day one. Blew the pinion seal. Ford replaced the ring n pinion, pinion bearing and seal. ring and pinion were installed wrong. I imagine the friction caused heat, which means higher pressures, which means blown seals.
2013 Mustang GT w/ Track Pack - Steeda Ultralite Springs, Koni Str.t Struts/Shocks, BMR LCA & Relocation Brackets, BMR Adjustable UCA and Bracket, BMR Adjustable Panhard, DSS Aluminum Driveshaft, Bassani x-pipe and catback, MGW shifter, JLT CAI, Steeda Tune
Coyote5o is offline   Reply With Quote
Old 08-27-2014, 08:21 PM   #3
shellac's Avatar
Ford replaced both no questions asked. But I didn't get a chance to talk to the mechanic about the cause. It just said worn out.
Old 08-27-2014, 08:27 PM   #4
Coyote5o's Avatar
I know there was also an axle vent issue. Never had that so I can't say which years or what the root cause was for it
Old 08-28-2014, 03:28 PM   #5
Theres a tsb for that and i had it repaired twice.
winkawak is offline   Reply With Quote
Pinion seal leak? silverstang831 2005-2010 Mustang GT 4 06-17-2013 01:14 PM
pinion seal 2002Gt 1996-2004 Mustang GT 3 04-05-2012 06:21 PM
Pinion seal advice 04machazblue 1996-2004 Mustang GT 9 09-07-2011 09:18 AM
Pinion seal now fixed SpectorV Pre-2005 V6 Mustang 2 01-11-2005 07:19 PM
Got a pinion seal leak... SpectorV Pre-2005 V6 Mustang 18 01-04-2005 08:19 PM
09:53 AM
