Homemade Vacuum Leak Tester - Mustang Evolution
Old 08-29-2014, 09:09 AM   #1
Voltwings's Avatar
So i recently decided to go back to my stock GT manifold and intake from my Cobrajet set up, and was plagued with a phantom vacuum leak that was driving me crazy, and i finally broke down and made this nifty little device.
Basically you just burn a small cotton rag in the paint can.
Adjust air compressor to ~3-5 psi
The fitting is 5/8" so it can either be routed to the coupler for the intake i made, or any of the PCV fittings to test various parts of the system.
Apply pressure to the valve stem and smoke will blow out where your leak is.
Turns out i lost an injector O-ring during the swap -_- something that seems so trivial now, but oh well, at least its back up and running.
Also, this is why it's VERY important to have your datalogger hooked up after making major changes to the vehicle, and making sure it is running right after said changes. Hopefully this nifty little idea can help someone else in the future and save them some time and effort, i was damn near pulling my hair out trying to find this leak.
ID:	164663   Click image for larger version
Homemade Vacuum Leak Tester Voltwings 2011-2014 V6 Mustang 2 08-29-2014 10:10 AM
E85 Tester Question Big Q 2011-2014 Mustang GT 1 07-01-2014 02:18 AM
low budget fuel pressure tester Jar72 1979-1995 Mustang GT 0 02-02-2014 03:39 PM
Snap on dianostic tester tbonestang 1979-1995 Mustang GT 4 07-14-2012 10:14 AM
Erratic Idle problem solved-Intake manifold vacuum leak Mercedez L. 1979-1995 Mustang GT 7 07-30-2010 10:08 AM
01:57 AM
