Catch Can Results - Mustang Evolution
Old 08-30-2014, 12:43 PM   #1
Paradone's Avatar
Catch Can Results
Catch Can results:
FRPP Track Key - 576 miles total running on the tune some very spirited and some cruise miles and making passes up town. This is half of what drained out so maybe total 2 tablespoons or so.
*NOTE* Oil on the dip stick is crystal clear as if it came out the bottle.
Paradone is offline   Reply With Quote
Old 08-30-2014, 12:54 PM   #2
Paradone's Avatar
Q Tip swab from Intake side where hose connects to Intake
Old 08-30-2014, 01:36 PM   #3
grabber12's Avatar
kind of nice to know how much it helps. Thanks, I might get me one.
2012 Grabber blue, Auto, Eibach pro street S coilovers, MM caster/camber plates, Borla ATAK cat back, off road X pipe, A.E.M CAI, SCT-x4 Mike Roush tune,SR LCA's, BMR Relocation brackets, J&M Pan hard bar, UPR Catch can, SVE 15x10's, Mickey T's 275-60-15.
grabber12 is offline   Reply With Quote
Old 08-30-2014, 01:42 PM   #4
Can someone explain this catch can and oil in intake stuff to a novice?
Something that can harm the car? Stock car vulnerable?
20145pointOH is offline   Reply With Quote
Old 08-30-2014, 03:47 PM   #5
Paradone's Avatar
I am by no means a mechanic or an expert as you can tell by my catch can install I am not "the best" mechanic but it looks "ok" I guess on to your question about this matter it seems that it is preferred to install a catch can when using the FRPP tune as to remove any possible oil vapors from entering your intake thus possibly reducing the air/fuel properties. It has been said if you hear a ping running the tune to install this to eliminate that ping as it drops your octane in the fuel/air ( I have never had that ping but just as a precaution I installed one). Again only what I have read I know allot of people use breathers the stock setup is a very short hose from your PCV to the intake the "catch can" removes those "oil vapors" however there are cans that are not very effective I was just putting it out there that this one in particular is working very well. Again I am not an expert on this subject matter, I know maybe Deerslayer and or Dallastang or Rapinator might be able to elaborate and or give a different opinion, I am only doing what FRPP suggested and only have the FRPP tune until warranty gets close then I will open this car up and add on much much more.
Old 09-02-2014, 12:09 PM   #6
Region: Oregon
No mention of which catch can is this?
skramblr is offline   Reply With Quote
Old 09-02-2014, 12:22 PM   #7
Paradone's Avatar
Its actually a VMS product from ebay I did not use the breather I capped mine off and bought quality hose but they have every color imaginable anodized also its a split chamber with insert nipples and separation hoses.
VMS Aluminum Oil Reservoir Catch Can Tank with Breather Filter Baffled Purple | eBay
Can You Catch Mr. Jones? Brent The Bar 6 08-01-2007 03:40 PM
01:58 AM
