Installed new sway bars - Mustang Evolution
Old 08-30-2014, 06:13 PM   #1
hitmeagain's Avatar
I just installed the sr performance front adjustable and rear non adjustable bar.... The front bar went on as easy as pie no big deal and I set it in the softest setting to try to get the car to turn in a little better and make it more responsive. The rear bar was absolutley frustrating. The hard ware that holds the bar to the car at the shocks has to be changed and I had the hardest time getting the nuts started on the bolts and had to unbolt the shock from the axle to get it started on the driver side. It would have been easier to remove the wheels but my work space is so small I couldn't. Well any ways these are well worth the money. The car is transformed from a plow to an actual car that responds to my inputs and turns in very good. Defiantly a pretty easy fairly inexpensive mod that makes a huge difference.
hitmeagain is offline   Reply With Quote
Old 09-01-2014, 08:12 AM   #2
kingstrider's Avatar
Sounds gnarly. I changed the entire suspension on my car over the weekend including new sway bars, shocks, struts, lowering springs, etc. There's no way I could have done it without the wheels off and jacked up a foot or so off the ground.
kingstrider is offline   Reply With Quote
front and rear sway bars installed garbill2003 2005-2010 Mustang GT 28 03-30-2013 04:16 PM
running skinnies and no sway bars tire The Bar 2 03-05-2004 11:39 AM
sway bars part2 JoeR. Pre-2005 V6 Mustang 10 01-05-2004 11:37 AM
Sway bars JoeR. Pre-2005 V6 Mustang 26 01-05-2004 10:49 AM
02:08 PM
