DRL - Mustang Evolution
Old 08-31-2014, 02:25 AM   #1
Mutafov's Avatar
Region: Nevada
DRL
My DRL(Daytime Running Lights) are acting up and I'm talking about to LED strips they put on the 2013+ models! If my headlights are off my DRL's are off too but if my headlights are on so are my DRLs.. If I manually turn on my DRLs they work and same with when I open/close/unlock the door.. Sounds like a blown fuse right? But I checked all of them and they're all fine.. Someone have any suggestions?
Mutafov is offline   Reply With Quote
Old 08-31-2014, 08:16 AM   #2
mav351w's Avatar
I'm not 100% sure but I know if I have my headlight switch on automatic they are on all the time. And when is open my door the fogs come on too. Try that and see if it works.
14' GT PREMIUM
DEEP IMPACT BLUE
mav351w is offline   Reply With Quote
Old 08-31-2014, 08:38 AM   #3
scott_0's Avatar
I dont have a 13-14, but I believe the DRL strips should be on when the key is in the on position, no matter if the headlights are in the auto setting or not, why not take it to the dealer, sounds like an electrical issue........
Old 08-31-2014, 12:39 PM   #4
Lucky_13's Avatar
I have a 13 and the DRL don't come on if you have the parking break engaged.
Sent from my SAMSUNG-SGH-I717 using Mustang Evolution mobile app
2013 Sterling Gray GT Premium, Brembo Brakes, Track Pack, 3.73 gears.
Lucky_13 is offline   Reply With Quote
Old 08-31-2014, 12:55 PM   #5
Brockman66's Avatar
Correct, the lights are on always when the switch is set to automatic. They also illuminate along with your turn signal bulbs when you lock or unlock the car. When the car is on and you have the parking brake on the lights turn off.
Brockman66 is offline   Reply With Quote
how do i turn off my drl's??? (daytime running lights) kona2010v6 2011-2014 V6 Mustang 42 01-08-2017 02:51 PM
2013 Headlight or DRL question Mlarv5 Shelby Mustang 10 01-29-2016 02:59 PM
DRL DISABLE?? Fordboi2012 2011-2014 V6 Mustang 49 01-31-2014 09:52 PM
2013 Headlight or DRL question Mlarv5 Mustang Paint, Appearance & Detailing 0 06-09-2013 05:24 PM
04:32 AM
