Advancetrac problem? - Mustang Evolution
Old 09-01-2014, 10:40 PM   #1
We have a 2012 GT premium with the Brembo package. My wife ran over something that cut the tire and it wasnt able to be repaired so we replaced 2 tires with Continental ExtremeDWs (stock size). They're on the back right now and I just drove it for the first time since the tires were installed. We live in the mountains and heading down the hill today, power would get cut and it felt like various brakes were being applied as well. I wasnt doing any spirited driving at all and the car has never exhibited this behavior before. This happened on just about every corner and mostly at turn in. Also happened on the 10/15 freeway interchange when I was traveling behind other vehicles at typical highway speeds. No illumination on the dash indicating traction control had intervened.
Any ideas on where to even start looking? The tires werent remotely close to losing traction. Tires were installed at Discount and Ford had the car the same week because the windshield washer motor went out. Oil was changed at the same time. Car has 23k miles on it and has been problem free until now.
madweazl is offline   Reply With Quote
Old 09-02-2014, 12:01 PM   #2
Could be a difference in tire diameter. Just to eliminate some possibilities turn off the Advancetrac and see if the problem goes away.
charliep is offline   Reply With Quote
Old 09-02-2014, 01:35 PM   #3
Wouldnt a light come on to indicate that it engaged though? I'll turn it off for giggles and see what happens.
Old 09-02-2014, 05:32 PM   #4
Getn off's Avatar
Light doesn't come on when it intervenes like other manufactures.
Troy
Getn off is offline   Reply With Quote
Old 09-03-2014, 09:01 AM   #5
I shut off the Advancetrac and it stopped happening so it is definitely the issue, now I just need to figure out the cause. I figure it has to be the tires.
Old 09-03-2014, 09:05 AM   #6
Strange Mud's Avatar
I wonder if it is tire OD differance.
w/o insulting check psi
Old 09-03-2014, 09:12 AM   #7
Yea, planned on doing that today. Was going to check out the manufacturers website to see if I could find the OD. It is more aggressive on left hand turns than right which leads me to believe that tire pressure may have something to do with it.
Old 09-03-2014, 11:26 AM   #8
I don't trust the manufactures sites. I know it's a pain but take a flexible tape measure and measure the circumference of each tire to confirm that they are the same.
Old 09-03-2014, 11:34 AM   #9
I used a straight edge across removed tires to compare them when I swapped out tires. I see Charlie mentioned OD B4 I did (so much for my reading skills)
remember burnouts are a good way to remove excess rubber.
It's good time to wax inner sides of rims.
Old 09-03-2014, 12:25 PM   #10
Getn off's Avatar
Try this site to get an idea. Of the dia. Keep in mind that there are very slight diffs between mfgs too.
Troy
255/40-R19 vs 285/35-R19 Tire Comparison - Tire Size Calculator
Old 09-03-2014, 12:31 PM   #11
Grabber Blue5.0's Avatar
It's not the difference in tire diameter. My fronts are 25.5" and my rears are 27.8" and I have no issues.
Old 09-03-2014, 02:22 PM   #12
Alright, guess I'll take it to the dealer and they can figure it out then.
Service Advancetrac Untamed5.0 2011-2014 Mustang GT 15 01-30-2016 07:28 AM
Advancetrac sport mode jomcgui 2011-2014 V6 Mustang 25 02-08-2013 08:37 AM
Difference with advancetrac and sport mode Maverick2004054 2011-2014 Mustang GT 11 02-07-2013 03:33 PM
How does AdvanceTrac work Fo Sho 2011-2014 V6 Mustang 7 07-10-2012 01:23 PM
2011 mustang gt advancetrac Jack Israelyan 2011-2014 Mustang GT 16 02-06-2012 07:34 PM
07:59 PM
