Need with squealing in the rear end of car - Mustang Evolution
Old 09-02-2014, 04:47 PM   #1
I have a 2012 Mustang GT and just had it lowered with eibach pro kit with dampers. I have noticed a weird squealing noise from the rear end (i think) that only does it early in the morning (around 5am) and it does it even if I am on a normal road (not over speed bumps). I have opened the back seats and set my phone in the back seat to pick up the sound of it the best I can. I will put it in a youtube video to show the sound and since youtube would not just allow me to upload an audio clip, I had to create a non relevant video clip as well. I will post the link below. I did take it to the shop that installed the kit and of course they could not reproduce the noise and said it might just be moisture in the LCA or lower ball joint seals. I also thought it was the strut mounts but now I am almost certain it is coming from the rear. Please let me know what you think.
Car squeeking noise - YouTube
BeastGT is offline   Reply With Quote
Old 09-02-2014, 11:13 PM   #2
515roushtvs5.0's Avatar
Check your upper shock bushings behind the carpet in the trunk, I had a noise similar to that and used some silicone spray and got rid of it. Also check your sway bar and make sure everything is greased.
515roushtvs5.0 is offline   Reply With Quote
Old 09-03-2014, 07:56 PM   #3
What kind of silicone spray did you use?
Old 09-03-2014, 08:36 PM   #4
Just a regular silicone lubricant.
Metal squealing noise after driving for a while Patches89 1979-1995 Mustang GT 11 08-20-2012 06:09 PM
squealing noise 98mustang11 Pre-2005 V6 Mustang 14 04-17-2012 04:21 PM
How long is a mustang rear end compared to a ranger rear end. lenth meaning from tire to tire? macray33 General Mustang Discussion 1 03-14-2010 03:43 AM
My car is squealing, I dont think the belt needs to be replaced? bernardas General Mustang Discussion 3 03-02-2010 03:39 AM
Is a 1995 Mustang V6 rear end different from a 1995 Mustang V8 rear end? celyddon Pre-2005 V6 Mustang 2 08-25-2009 06:56 PM
08:26 PM
