Brake/Clutch bleed - Mustang Evolution
Old 09-03-2014, 10:45 AM   #1
Brake/Clutch bleed
I bought some Dot 4 brake/clutch fluid. I was wondering if u can swap fluid and then just pump brake and clutch pedal a bunch of times. Is it necessary to take tires off and bleed each brake.
stang21 is offline   Reply With Quote
Old 09-03-2014, 01:13 PM   #2
Ammermeow's Avatar
I did. I changed to a steel braided clutch hose, had to pump the clutch like 100 times to bleed. If you are just siphoning out the brake fluid from the master this will not be necessary since the brake lines and clutch line will maintain the fluid already in them. But this would not be a complete fluid swap unless you bleed all the lines to get the old fluid out.
Sent from my SCH-I535 using Mustang Evolution mobile app
2012 GT Brembo M6, BBK CAI, Dynomax axleback, Bama tuned, UPR UCA & mount, Hotchkis LCA/panhard bar/adjustable swaybars, Whiteline relocation brackets, Barton shifter & bracket, Eibach ProKit Springs.
Ammermeow is offline   Reply With Quote
Old 09-03-2014, 01:18 PM   #3
ya i mainly just want to swap fluid for the clutch for high rpm. If i suck out all the old fluid and pumping clutch pedal will this help.
Old 09-03-2014, 01:51 PM   #4
Voltwings's Avatar
You need to do the full flush. This is your brakes and your clutch, two very vital and important systems, dont half *** it.
Old 09-03-2014, 07:32 PM   #5
ya went ahead and did a full flush of the break calipers and pumped the clutch and break pedal and hundred times. then refilled with amsoil dot 4. Also installed a steel clutch line. Clutch feels so much better, the stiffness went away. high rpm shifts have massively improved.
Old 09-04-2014, 08:21 AM   #6
Voltwings's Avatar
Very nice. Its painful to put all amsoil fluids in the GF and I's mustangs but somehow i just sleep better at night knowing its got the good stuff in it. You may also want to look into removing the clutch assist spring if you have not already, makes a tremendous improvement in the high rpm lock out.
bleed brakes and still soft pedal? rwheels 2011-2014 Mustang GT 1 08-09-2014 04:04 PM
Easiest way to bleed front brakes?? mustangmania91 1979-1995 Mustang GT 9 11-24-2013 05:57 PM
clutch clutch... clutch Butch SVT Mustang 4 06-29-2012 04:53 PM
bleed coolant line 97V6stangct Pre-2005 V6 Mustang 0 01-28-2012 11:34 AM
how to bleed brakes I_luv_HP&trq Pre-2005 V6 Mustang 5 11-26-2005 10:32 AM
03:38 PM
