If you have an Air Raid Intake Step in! - Mustang Evolution
Old 09-04-2014, 06:51 PM   #1
I'm looking to hear from people with Air Raid Intakes.
Mine has been on my '13 for aprx 1800 miles. Recently, I noticed that under acceleration I can hear the Intake hissing while I'm in and out of the gas. It doesn't just sound like the whooshing of a CAI but it sounds like there's a pin hole air leak hissing. Like an old car with a vacuum lining spitting air out. It's pretty loud and it's annoying me to no end. I tried taking the whole thing back off and remounting it. I tightened every connection. I found that the box had been missing a bottom screw for the coupler so the coupler was not attached at the bottom. I thought I hit the jack pot. Nope, Put it all back together 100% and it's still doing it.
This may have begun when I installed a Nitrous Outlet Plate a few weeks ago. I thought something related to that could be the issue but everything is 100%. It really sounds like it's the Filter and CAI making this obnoxious hissing noise.
Anyone else have this problem before I switch it all back to the stock one?
Justin81 is offline   Reply With Quote
Old 09-04-2014, 08:09 PM   #2
Could be the air going around the butterfly in throttle body
Pullingees is offline   Reply With Quote
Old 09-04-2014, 08:15 PM   #3
JoeyM91's Avatar
Check that the hose clamp is nice and tight as well over the filter. The rubber coupler is 100% secure over the throttle body,
Old 09-04-2014, 08:20 PM   #4
Could be... But sounds like it's coming from the filter.
Old 09-04-2014, 08:21 PM   #5
Triple checked .
Old 09-05-2014, 05:55 AM   #6
AJcruz1's Avatar
Make sure the airaid box is inside of the air intake vent for the car. where air comes in from the grill. Next thing to do is try a different filter.
AJcruz1 is offline   Reply With Quote
Old 09-05-2014, 06:38 AM   #7
Voltwings's Avatar
Do you have an SCT / Live link 2 datalogging software? You could easily just pull up the logger and measure the short term fuel trims to see if you have a vacuum leak. If you dont, you likely are just hearing the "whoosh" of the intake.
Old 09-05-2014, 06:58 AM   #8
Justin81 gave Justin81 a great hint
Old 09-05-2014, 07:20 AM   #9
I have an SCT Livewire which is the full screen where you can watch every parameter while driving. The Shorts are right at 1 under WOT. The rest of the tune looks good however I am seeing some KR which is the whole reason all of this came about. IT will see anywhere from 1.5 to 3* in most WOT situations.
Old 09-05-2014, 07:36 AM   #10
Voltwings's Avatar
I meant checking at idle, your WOT fueling may be compensated for the nitrous so its hard to say. Anything much over 1.05 or so (assuming your MAF is dialed in) will typically mean a leak. Most leaks are usually pretty obvious though, regardless of how small, and will peg your trims around 1.30 - 1.40 or so. If your trims check out and you dont have a leak you know you're good.
I always have my datalogger plugged in when i start the car after messing with stuff like that to check for leaks, just makes things easier in the long run.
Old 09-05-2014, 07:50 AM   #11
Yes, you're absolutely right about checking at idle.
I was watching it last night at WOT and the info was fresh in my head. At idle, it fluctuates from .98 - 1.02. The tune is a N/A Lund Tune which I never had an issue with before this. I always have my Livewire on the dash also so i'm always monitoring this too but that's good advice to watch Shorts at idle for issues. I don't believe there's a leak at this point I just think my Air Raid has a flaw that's causing this hissing sound. IT's there when revving it up with the hood open I can hear it. My main concern is the KR but i'm hoping it's due to High Humidity and possible change of my usual gas station. I'm on Empty now so I'll be filling up with the Usual Sunoco 93 and possibly mixing some 110 to rule out the gas issue.
Old 09-05-2014, 07:58 AM   #12
Voltwings's Avatar
Its possible. Could throw the stock air box back on there maybe to rule out the nitrous plate?
Old 09-05-2014, 08:02 AM   #13
That's definitely my next step. First i'm going to do the gas. If it still pulls timing i'm going to back up by going stock air box and than pull the nitrous plate. I'm not 100% confident in the Nitrous plate because I have already had 1 big problem with the Nitrous Outlet kit that was pretty f-ing stupid. After that, I'd like to pull the NOS plate and inspect it anyway.
Old 09-05-2014, 08:21 AM   #14
Voltwings's Avatar
Hmmm. well keep us posted.
« CAI | Gt500 muffler »
Progress on long tube headers install and step by step insall Luna1994 2005-2010 Mustang GT 76 01-08-2014 03:51 PM
For Sale: 2011 mustang 5.0 air raid intake Moto111 Mustang Parts for Sale and Wanted 4 05-20-2013 11:08 AM
01 vert deck step by step Tec_ Mustang Audio & Video 5 01-21-2013 11:48 PM
Need a step by step Blackedout Pre-2005 V6 Mustang 2 05-21-2011 11:35 PM
w00t! one small step for me, one giant step for my car fast64 Mustang Audio & Video 5 06-02-2004 01:54 PM
07:53 PM
