MGW or Barton for an MT-82 replacement? - Mustang Evolution
Old 09-05-2014, 12:44 PM   #1
Devil's Avatar
I have a 2014 GT/CS and as everyone else I too have the lockout issue where from 2nd to 3rd just wont happen under a heavy load.
I was looking at this:
MT-82 SHORT THROW SHIFTER
But after digging around the forums it looks like people either went with a Barton or MGW. From what i gathered it looks like the Barton also needs the bracket for better shifter positioning but people who got the MGW setup claim they seldom experience a lockout.
I'd like to know from both sides how often you experience a lockout under a heavy load?
Im looking to make a decision by the end of this weekend (hopefully)
thanks for the info folks!
Devil is offline   Reply With Quote
Old 09-05-2014, 12:54 PM   #2
Jgrummz's Avatar
Ide say you cant go wrong with either one. I went with the barton jus because its a little cheaper. I already have the 2post bracket which helped a lot and the shifter will be here today so ill let you know how i like it
Jgrummz is offline   Reply With Quote
Old 09-05-2014, 01:25 PM   #3
Randeezy23's Avatar
I have the mgw I haven't experienced any lock with mine, I have had mine for 3 months now. Great feel great look, it is more expensive than the Barton but you get a complete set up with mgw. I have the gripper shifter cause I like the feel of it. I also have the pony knob just like the gripper better. Click image for larger version
Name:	ImageUploadedByMustang Evolution1409945063.885610.jpg
Randeezy23 is offline   Reply With Quote
Old 09-05-2014, 02:15 PM   #4
Devil's Avatar
how long did it take for the setup? the gripper 6 speed knob is what i was looking at too.
I know the cost would be less for the Barton but i kind of want everything to be together. I plan on keeping this Mustang for a long while.
Originally Posted by Randeezy23 View Post
I have the mgw I haven't experienced any lock with mine, I have had mine for 3 months now. Great feel great look, it is more expensive than the Barton but you get a complete set up with mgw. I have the gripper shifter cause I like the feel of it. I also have the pony knob just like the gripper better. Attachment 165263
Old 09-05-2014, 02:19 PM   #5
Randeezy23's Avatar
It took him about 1hr with a lift.
Old 09-05-2014, 03:37 PM   #6
Shifts are short enough with the factory piece (IMO). So I just used the Barton two post bracket AND the Whiteline lower crossmember insert. The Whiteline insert prevents excessive movement under heavy load, and IMO did the most to improve the shifts. The Barton two post bracket cleaned up the gates, and gave the shifter a more direct and precise feeling.
Expect increased NVH, but its worth it.
BadCon is offline   Reply With Quote
Old 09-05-2014, 03:42 PM   #7
Gordito's Avatar
No lockout from 3rd with my MGW and I've had it for about 6 months.
Gordito is offline   Reply With Quote
Old 09-06-2014, 03:12 PM   #8
Lucky_13's Avatar
I have the MGW shifter and I haven't experience any lockout from 2nd to 3rd. I did have some problems shifting from 1st to 2nd but it was because of the way I was shifting. I have had it for 2 months and shifts like butter. It took me three hours to install without a lifter and only using jack stands.
Sent from my SAMSUNG-SGH-I717 using Mustang Evolution mobile app
2013 Sterling Gray GT Premium, Brembo Brakes, Track Pack, 3.73 gears.
Lucky_13 is offline   Reply With Quote
Old 09-06-2014, 03:14 PM   #9
Lucky_13's Avatar
Here's a picture of my shifter.
Old 09-06-2014, 06:36 PM   #10
Devil's Avatar
the setup looks nearly stock, it has that "right at home look"
I think ive made up my mind and am going with the MGW setup first along with the replacement bushing.
Thanks to everyone for being helpful!
Old 09-06-2014, 09:16 PM   #11
It's not the shifter,it's the clutch,replace it and all problems will go away
chefron50 is offline   Reply With Quote
Old 09-06-2014, 09:26 PM   #12
creepstang13's Avatar
From all the research Ive done ive decided to go with the mgw as well.
Sent from my XT907 using Mustang Evolution mobile app
creepstang13 is offline   Reply With Quote
Old 09-08-2014, 08:49 AM   #13
Devil's Avatar
pretty sure everyones saying shifter, and i feel like its the shifter too. 15k miles and not a single problem with the clutch. Ford just made a crappy shifter is all with a terrible mount is all.
Old 09-08-2014, 08:50 AM   #14
Devil's Avatar
same here, ive PMed a few people on here with the MGW and they all said the same thing about it and ive made my choice to go with the MGW as well.
Old 09-21-2014, 03:29 AM   #15
Jd431x1f's Avatar
Region: Nevada
I put an MGW in my 14 GT and haven't had anymore issues like I did with the sloppy stock setup. Only slight increase in NVH, best kit on the market, you won't regret it.
Jd431x1f is offline   Reply With Quote
Old 09-21-2014, 06:26 AM   #16
It's not me, it's you.
primer2tone's Avatar
Yep. I did the MGW as well. Very expensive but it is my favorite mod thus far.
Old 09-21-2014, 07:57 AM   #17
Deerslayer's Avatar
MGW Shifter + Blowfish Bracket = good as the MT82 gets
2013 GT : 6sp MT, Track Pkg, 3.73 Rear End, Brembo Brakes, Vortech V3 SC, Boss IM, BBK 90mm TB, JLT CAI, ID1000 injectors, BAP, Brisk Plugs, Tial BOV, Lethal OR X Pipe, 3" over axle to GT500 Quad Exhaust, Dynotech Alum DS, MGW Shifter, Eibach R2 Coil Overs, Bob's Billet LCA's, UPR adj. UCA, Eibach Adj PH Bar, TruCarbon Carbon Fiber inside/out. Tuned by Jon Lund II Three salvaged Bosses worth of Parts live on in this car. 705.11rwhp 5.33pulley/Torque Booster Wastegate
Deerslayer is offline   Reply With Quote
Old 09-21-2014, 08:17 AM   #18
AJcruz1's Avatar
MGW, best shifter available and I had the Steeda shifter before.
AJcruz1 is offline   Reply With Quote
Old 09-21-2014, 10:04 AM   #19
The mgw does a little more than the barton and 2 post bracket but it's emotion as to which one is best. Based on posts here neither really 'fixes' the problem. Apparently the blowfish bracket does address this issue. At that point stock, or aftermarket shifters are improved to where it should have been from the factory...
eticket is offline   Reply With Quote
Old 09-21-2014, 10:55 AM   #20
Jd431x1f's Avatar
Region: Nevada
Replacing the entire crap stock box is more than just "a little more". No emotion, just fact.
After looking up the blowfish, it should completely eliminate any lockout due to shifter/Trans movement. If you race, it's a no brainer as it doubles as a drive shaft loop.
Old 09-21-2014, 11:22 AM   #21
Devil's Avatar
So should I try out the blow fish bracket first?
Old 09-21-2014, 11:33 AM   #22
Paradone's Avatar
I have had the Barton setup with bracket for quite some time now on the 2014 haven't had any issues even power shifting no lockouts to date (granted I do not abuse daily) but not the first issue in the past owned both MGW and Barton just a personal choice both are great shifters well made.
Paradone is offline   Reply With Quote
Old 09-21-2014, 11:46 AM   #23
Devil's Avatar
I really don't feel like its my shifter, when I shift under a heavy load it feels like the tranny moves around ALOT. I wanted to try the blowfish bracket first to see how much it eliminates that and if I have to then I could spend the extra $$ on the shifter too. I wish I could change out everything at once.
Old 09-21-2014, 11:54 AM   #24
Jd431x1f's Avatar
Region: Nevada
If you don't care about shortening the throws on your shifter, get the blowfish bracket to tie the box to the tranny. Might also look at the Whiteline tranny bushing as well, it's around $40 on eBay. That should eliminate what your feeling.
Old 09-21-2014, 12:17 PM   #25
Devil's Avatar
just to confirm it should be these two:
Blowfish Racing SSB-01-000 Mustang Support GT 11-14/Boss 12-13
this bushing?
http://www.americanmuscle.com/whitel...-kit-1114.html
according to the reviews many people just replaced the bushing and have had no issues, should I try that first and see if it helps before I dive into the bracket?
Old 09-21-2014, 12:38 PM   #26
Jd431x1f's Avatar
Region: Nevada
Yes, those are the two I am talking about. The bushing won't solve the problem like the Blowfish, but it is cheap and if you get a new Barton rear bracket for $65 as well, you'd only have about $110 invested. Those two pieces should eliminate 75% of the movement, but the Barton bracket is useless with the Blowfish should you get one later.
Old 09-21-2014, 01:14 PM   #27
Devil's Avatar
sounds good, I will grab the bushing first and after that I will go with the blowfish support bracket as a finish off.
Old 09-21-2014, 10:13 PM   #28
Neither fixes the issue. Period. The blowfish does. At that point it's too close to call because the main issue is solved and now it's just personal taste as to which shifter is best. The two piece bracket from barton is no longer needed and I would think all the effort MGW did is migrated due to the blowfish as well.
Think of speakers, everyone has an opinion as to what's best. It's a simple as that. Bottom line, either you get this point or you don't. No worries either way...
Old 09-22-2014, 05:27 AM   #29
AJcruz1's Avatar
First off I just gave my opinion of what I feel is a great shifter as that is what the OP asked about. Secondly it depends on what you are doing with your stang and if you don't race it then the MGW WILL fix the issues you are having. It gives a better shifting experience and gets rid of the slope in the stocker. No one I know of was disappointed after installing the MGW. If you race it then it is an entirely different story and the blowfish bracket is the way to go to prevent the trans from moving but that doesn't mean you can't couple it with an aftermarket shifter for shorter throws. Lastly, JD431x1f was the one attacking your comment not me.
Barton Vs MGW BigBlue5.0 2011-2014 Mustang GT 15 03-10-2014 03:24 PM
mgw ~vs~ barton short throw shifter nculp9 2011-2014 Mustang GT 16 06-29-2013 09:09 AM
MGW vs Barton Short Throw Shifter Brock23 2011-2014 Mustang GT 26 10-26-2012 04:21 PM
Barton 2 Post Bracket vs Standard Barton Bracket SilverBullet12 2011-2014 Mustang GT 8 08-23-2012 09:43 AM
10:35 PM
