Question about data logging - Mustang Evolution
Old 09-08-2014, 02:36 AM   #1
I did a lot of researching into the new Mustang GT's before I bought mine. Mostly it was for what were things to look out for or expect for normal quirks. The talk about cyl #8 has got me concerned. An equal amount of research shows people claiming stock tune, and, ALL early tunes causing engine damage. My car is a 2012GT and the previous owner put on, so far as I can tell an airraid CAI and Borla exhaust, I am assuming just axle backs for now until I see the car on a lift.
Since there is a general consensus that if you make pretty much any changes the car will need a re-tune I'm concerned with my car's setup. I don't have enough time in these cars to have a good feel if one is tuned. So far as I can tell, since the dash tells me at odd times to shift 1->4 for fuel economy combined with the mpg I get it appears there is no tune on the car. Or if there was the dealer/ previous owner returned it to factory?
What is the best way I can tell if there is a tune on the car? Do I take it to the dealer and have them match the flash counter against their records? Should I be worried with the CAI install and running the factory tune? I have been looking at Ford's procal to get rid of the skip shift nonsense but I don't see how I would have easy access to data logging with their handheld. Or do they use the SCTx4 that seems to be popular now? I've looked for videos showing a data logging session on the SCTx4 and I have not found anything. Is there a way I can, without buying an AFR gauge read my AFR's and or my EGT's realtime?
I feel like I've got too much information to parse in making a choice here. I've never taken a car to a dyno before but I am wondering if that would be the best thing to do in order to gather all the data on what the car is doing.
*Edit*
I did read this thread, but can anyone chime in if the app allows you to record any of the monitored perimeters?
OBD II Bluetooth monitors
*Edit2*
After more reading these obd ii apps do provide data logging
ShatterPoints is offline   Reply With Quote
Old 09-08-2014, 03:18 AM   #2
natestang07's Avatar
I'm just going to hit on the thing I can hell with. Look at american muscles website and try to identify the airaid intake. Figure out if it is tune required or not. If it is required you have a tune because the car would be running like crap without. Mine wouldn't even run without the tune.
Note that some of the airaids have a thing inside that while it is there it is no tune required and while it is not it is tune required.... I hope some of this helped as it became jumbled into this mess I wrote lol
05 Gt Premium Performance White, flowmaster outlaws, Jlt Series 3, Bama 91r tune
Old 09-08-2014, 10:41 AM   #3
2013_DIB_GTCS's Avatar
There's two versions of the airaid intake. One version is the race version that needs a tune or it'll run like crap. The other version has what airaid calls a modular venturi tube. It basically keeps the maf size the same so you don't need to get tune to use it. It's a black piece between the air filter and intake tube. I'd check to see if that's there and that can point you in some kind of direction
2013_DIB_GTCS is offline   Reply With Quote
Quick question about data logging Filth and Fury 2011-2014 Mustang GT 4 02-16-2014 08:57 PM
Does Data Logging Measure HP? OzzyLiriano 2011-2014 Mustang GT 17 07-13-2013 06:32 PM
How does the SCT data logging and monitoring work rebeltx 2011-2014 V6 Mustang 3 01-30-2013 09:29 AM
Some data logging feedback from my Steeda 93 octane tune mmike87 2011-2014 Mustang GT 6 08-20-2012 05:39 AM
BAMA Data logging ForsakenProto AmericanMuscle 1 07-18-2012 10:03 AM
11:48 PM
