anyone with boss 302 IM - Mustang Evolution
Old 09-08-2014, 09:25 AM   #1
Joaquin_ii's Avatar
so i installed my intake manifold yesterday and the install was fairly easy that being said i happen to come across a problem. when im idle say at a light, i happen to see my RPM go below 500 and then i hear my engine fight it and it shoots back up to about 700. my rpm have alwasy moved around but ive never seen it go that low or react in that way. does anyone else have this problem? or is it normal with this IM?
Joaquin_ii is offline   Reply With Quote
Old 09-08-2014, 12:43 PM   #2
Leo513's Avatar
Nope.... Vacuum leak maybe. Do you have a tune for the Boss IM?
Leo513 is offline   Reply With Quote
Old 09-08-2014, 01:35 PM   #3
Joaquin_ii's Avatar
yes i do. bama.
it doesnt happen onstantly though it happens maybe once a minute or so
Old 09-08-2014, 01:38 PM   #4
Rapinator126's Avatar
There is a air leak somewhere. Either one of the gaskets fell out of place slightly, or is not tightened properly.
Or you pcv hoses are not hooked up properly. Could be a # of things.
Or simply could be your canned tune.
Rapinator126 is online now   Reply With Quote
Old 09-08-2014, 01:41 PM   #5
Joaquin_ii's Avatar
ill recheck the torque later see if thats it.
Old 09-08-2014, 01:50 PM   #6
You positive all the gaskets were in ther? And straight not tore etc?
Old 09-08-2014, 09:02 PM   #7
Joaquin_ii's Avatar
yes they all looked perfect when i saw them and i torqued to spec.
Old 09-08-2014, 09:09 PM   #8
ArtU's Avatar
Cannot intake manifold leaks be troubled shoot by using an un-lit propane torch? I did check a motor once that way, lightly putting the propane for a sec or too across the intake gasket area looking for a change in idle means a leak.
Same with hoses, a leak will pull in the propane and idle will change.
Art
Old 09-08-2014, 09:15 PM   #9
Joaquin_ii's Avatar
i wouldn't dare to shoot a torch into a an intake manifold. I'm going to remove it tomorrow and double check everything if something is wrong i will reapply the factory manifold.
Old 09-08-2014, 09:47 PM   #10
ArtU's Avatar
No, you don't shoot a lit or unlit torch into the intake manifold You take an unlit torch with propane output on low and run the gas slowly by items that can suck air; hose connections, areas where the manifold seals to the heads etc. If air is being sucked in, it also brings in some propane and changes idle. DO some searches on the techniques used to find vacuum leaks by shops.
On the other hand, nothing wrong with taking the manifold off and double checking everything either.
Old 09-09-2014, 01:35 AM   #11
Ammermeow's Avatar
You can use carb cleaner to trace vacuum leaks also. Engine will rev when you hit the source of the leak. Are you sure the MAF sensor is plugged in? Had an engine act similar with the MAF unplugged.
Sent from my SCH-I535 using Mustang Evolution mobile app
2012 GT Brembo M6, BBK CAI, Dynomax axleback, Bama tuned, UPR UCA & mount, Hotchkis LCA/panhard bar/adjustable swaybars, Whiteline relocation brackets, Barton shifter & bracket, Eibach ProKit Springs.
Ammermeow is offline   Reply With Quote
Old 09-09-2014, 03:42 PM   #12
Joaquin_ii's Avatar
it was due to a bolt not tighten down all the way. everything else was good as far as gaskets and MAF. however i over torqued a bolt so now i have to drill it out somewhere thank you for helping out everyone.
2013 Mustang Boss 302 :: 2013 Ford Boss 302 bvillarreal60 Member Garages 0 05-01-2013 10:09 PM
Boss 302 vs. Boss Shinoda SaleenV8 2011-2014 Mustang GT 5 05-06-2012 12:45 PM
Boss 302 or Boss 429? AllanUSAFEvans 2011-2014 Mustang GT 6 03-05-2012 09:06 AM
BOSS 302 Mustang :: 2012 Ford B0SS 302 GoldenPonyBoy Member Garages 0 09-18-2011 12:12 PM
07:14 AM
