Premium Parts on my Bone Stock 2014 GT? - Mustang Evolution
Old 09-08-2014, 05:03 PM   #1
RJTheIV's Avatar
So I have a friend who says that parts of my engine are forged and that I have "premium" shocks on my car. How can I tell if this is true, or is it even possible? He said you shouldn't be able to bounce the car very much if at all by pushing on the hood, and yet he did it to mine.
RJTheIV is offline   Reply With Quote
Old 09-08-2014, 05:33 PM   #2
ArtU's Avatar
Well, parts of your engine are forged, but not the pistons; and their is different types of forgin' on Rods up from the stock ones. If you have a GT you don't have a Forged Build till you put in the hotter parts.
As for shocks, I don't think any "Bounce test" done by a Beer Bud will prove anything. You would need to stik a head under there and read a bar code part number. Certain packages had better suspension, but unless they are on your sticker I doubt you have them.
Drive-Way BSin' with buds is fun with friends but always take things with a grain of salt and lime
5.0L 32-valve DOHC V-8 that uses advanced features like Twin Independent Variable Camshaft Timing (Ti-VCT) to deliver 420 horsepower @ 6500 rpm and 390 ft.-lb.+ of torque @ 4250 rpm (with premium fuel). The lightweight aluminum cylinder block features cross-bolted main bearing caps and thick main bearing bulkheads for bottom-end strength. Optimized oil drainback and windage control improve high-rpm performance
High-performance 5.0-liter, four-valve Ti-VCT engine
Displacement 302 cu. in.
3.63 bore x 3.65-in stroke
Aluminum block
Forged steel crankshaft
Forged steel connecting rods
Hypereutectic aluminum pistons
Aluminum cylinder heads, DOHC, four valves per cylinder, Variable intake and exhaust camshaft timing
8qt capacity oil pan
11.0:1 Compression ratio
Tuned composite intake manifold provides efficient air delivery and weight savings
80 mm single bore "drive by wire" throttlebody
Mustang GT 409 stainless-steel tubular exhaust manifolds
Old 09-08-2014, 06:06 PM   #3
RJTheIV's Avatar
Aluminum block
Thanks for the clarification! I appreciate the help.
Old 09-08-2014, 06:41 PM   #4
ArtU's Avatar
Its a strong engine, and most say is good to 500hpr or a tad more on the stock parts,and a stage 1 super charger. But fully forged with better rods gets you into "Deep Space" HPR territory with stage 2 and 3 superchargers
Old 09-08-2014, 06:47 PM   #5
Compstall's Avatar
You should put a Chip in it, man ahh tell yew whut
Sent from my iPad using Tapatalk HD
- Brent
'11 GT Kona Blue Brembo
"Measure with micrometers, mark with a scribe, chop with an axe"
"I'm not new to driving. I've been doing it for a couple of years now." - Aphex
Compstall is offline   Reply With Quote
Old 09-08-2014, 07:12 PM   #6
ArtU's Avatar
Oh, BTW the rods are the "Powder Metal" forged type not the H or I beam Steel you put in for Stage 2+ built work.
Compstall, you cant "Put a chip in it" and you know that, so you must be Funin'
Chips for those that don't know are what you had to do before ODBII came out in 1996, before then just 'bout all beer dudes would say..."Engines' got a chip In It"
Art
02 V6 Mustang bone stock P0316 and P0302 codes-refuses to be fixed cessnadriver Pre-2005 V6 Mustang 45 10-04-2013 04:18 PM
bone stock 5.0 new personal best BUSHGUTS At the Track 32 04-29-2013 09:55 AM
Boss 302 goes 11.70's Bone stock w/slicks stampde General Mustang Discussion 7 03-29-2011 05:47 PM
2011 3.7 1/8th mile BONE STOCK AUTO omahamustang Pre-2005 V6 Mustang 7 10-09-2010 07:12 PM
Proud to Announce: 13.43@102mph BONE STOCK! doodad General Mustang Discussion 17 03-02-2007 08:39 AM
12:25 PM
