How To Plasti Dip Stripes? - Mustang Evolution
Old 09-09-2014, 11:41 AM   #1
WhiteCoyote's Avatar
I want stripes but just to be sure I like them I thought plasti dipping would be a great way to find out. I have used plasti dip before and love the product but doing stripes on a car is a bigger deal than what I done. Any suggestions?
WhiteCoyote is offline   Reply With Quote
Old 09-10-2014, 12:06 AM   #2
Jack1995's Avatar
The problem with plasti dip is that you'll need at least a tiny gap in order to get a fine edge. but I have seen fonzi on youtube plasti dipping the gap-free window trim. The tip is to remove the tape while the last coat is still wet. I have not tried it personally, but this is probably the only way you can get a perfect stripe. Good luck!
Jack1995 is offline   Reply With Quote
Old 09-10-2014, 01:25 AM   #3
Abominable Mustang
WhoDat's Avatar
Region: Alaska
This! I did the same with Plasti Dip as a temporary way to see if I'd like some red accents on mine, and peeling the tape immediately after spraying the last coat leaves a nice clean edge.
2012 Kona Blue 3.7L V6:
Old 09-10-2014, 01:41 AM   #4
Compstall's Avatar
Yep, gotta pull tape when it's still wet. Only other option is to use a razor blade up against the edge of the tape but not a good idea in this application..
- Brent
'11 GT Kona Blue Brembo
"Measure with micrometers, mark with a scribe, chop with an axe"
"I'm not new to driving. I've been doing it for a couple of years now." - Aphex
Compstall is offline   Reply With Quote
Plasti dip stripes SoCalKev 2005-2010 V6 Mustang 24 01-01-2013 03:52 PM
to plasti dip or not plasti dip ebgonzalez1 2011-2014 V6 Mustang 17 09-15-2012 03:52 PM
Plasti dip stripes?!? OneBad3.7 Mustang Paint, Appearance & Detailing 50 06-17-2012 04:58 PM
Finally im done!! Plasti dip fender stripes SwatKatz901 1996-2004 Mustang GT 28 04-01-2012 11:47 PM
Plasti-Dip Stripes meano1 1996-2004 Mustang GT 14 03-14-2012 06:52 AM
07:46 PM
