Rear end clunking - Mustang Evolution
Old 09-11-2014, 08:52 AM   #1
Stangholio's Avatar
Rear end clunking
Rear end making a clunking noise over slow bumps. SR springs and Koni yellows and BMR adjustable panhard on the car. Another guy had a similar noise and said it was the panhard. I just checked the panhard bar and it's fine also the rear strut bar. All seems tight. What else would cause the clunking? Thanks
Stangholio is offline   Reply With Quote
Old 09-11-2014, 09:14 AM   #2
Saleen90's Avatar
My 14 is stock and it creaks over bumps especially over turns combined with bumps I don't know that I would call it clunking... But maybe... But initially it scared me but I think it has something to do with the unibody chassis. Have a buddy with a 12 5.0 and does the exact same thing. All the ones I've been in make weird noises over bumps. Not sure if this alleviated your concern.
Saleen90 is offline   Reply With Quote
Old 09-11-2014, 09:29 AM   #3
Randeezy23's Avatar
Rear end clunking
I am having the same issue
I have BMR adjustable panhard bar, adjustable upper control arm and mount, lower control arms and relo brackets, koni adjustable all around and steeda ultra lites
Randeezy23 is offline   Reply With Quote
Old 09-11-2014, 10:29 AM   #4
2014oxstang's Avatar
Rear end clunking
I had the same ISSUE with my car. SR panhard bar here. That needed to be tightened up, and the NVH went away. Once you change out suspension components, it's only natural you're gunna hear some minor clunks and squeaks.
Get under there, and check everything out. Make sure EVERYTHING is tightened.
2014oxstang is offline   Reply With Quote
Old 09-11-2014, 12:45 PM   #5
Stangholio's Avatar
So I guess it's normal then. Weird. Thankfully the exhaust kind of hides the sounds. Thanks
Old 09-11-2014, 12:47 PM   #6
Joaquin_ii's Avatar
there are some threads on here mentioning the two piece driveshafts are the cause. those who have upgraded to a one piece mentioned the clunk was gone.
Joaquin_ii is offline   Reply With Quote
Old 09-11-2014, 12:49 PM   #7
Joaquin_ii's Avatar
Drive train CLUNK
second comment.
Old 09-11-2014, 02:20 PM   #8
It could be, but then again maybe not. And upgrading to a one piece DS is costly and involved. Would be a shame to shell out that kind of coin, and still have said NVH. I tend to think it's the P bar because I experienced the SAME EXACT thing. Adjust that bad boy, and tighten it up. Is the noise unbearable? I no longer have the clunks, but a few squeaks here and there. It's all manageable.
Old 09-13-2014, 10:56 PM   #9
Redonblackpony's Avatar
I had the same problem a while back. The clunking noise was driving me nuts. I heard the noise mostly when going slow over speedbump's. It sounded like something was loose in the trunk bumping around. Turns out it was my adjustable BMR upper control arm was loose.
Redonblackpony is offline   Reply With Quote
Clunking in front end. Audicrashdummy 2005-2010 V6 Mustang 1 01-29-2014 03:45 PM
Rear End Clunking silvrbullet2012 2011-2014 V6 Mustang 6 02-13-2013 07:24 PM
Rear end clunking Mayhem48 2011-2014 V6 Mustang 16 02-02-2013 02:40 AM
How long is a mustang rear end compared to a ranger rear end. lenth meaning from tire to tire? macray33 General Mustang Discussion 1 03-14-2010 03:43 AM
Is a 1995 Mustang V6 rear end different from a 1995 Mustang V8 rear end? celyddon Pre-2005 V6 Mustang 2 08-25-2009 06:56 PM
03:46 AM
