Squeaking Noise - Mustang Evolution
Old 09-15-2014, 06:03 PM   #1
Mutafov's Avatar
Region: Nevada
Squeaking Noise
I lowered my car last Sunday and everything was torqued down to specs. The only thing that was done wrong was I accidentally put the dust boot cover upside down on the right front shock. After I few days I hear a rubber chirping/rubbing noise. It goes away and comes back randomly! I took off my wheel to see if I can see anything and everything looks fine.. Is it possible for an upside down dust boot to make noise? It's only when I turn the wheel and it doesn't even make any noise over speed bumpsClick image for larger version
Name:	ImageUploadedByMustang Evolution1410822228.517343.jpg
Mutafov is offline   Reply With Quote
Old 09-15-2014, 09:26 PM   #2
2014oxstang's Avatar
Squeaking Noise
The dust boot being upside down wouldn't cause a noise whatsoever. I just recently changed out my springs/struts/strut mounts/shocks, and I get squeaks. I figure it's because of the stiffer suspension. Doesn't have any negative effect on how the car drives and is so faint it doesn't bother me. Any negative effects on daily driving for you? My guess is it's normal. What kind of springs did you buy?
Ahhhh my bad says H&R right on them. What's the drop? Looks drastic.
2014oxstang is offline   Reply With Quote
Old 09-15-2014, 10:06 PM   #3
Mutafov's Avatar
Region: Nevada
It's the super sports which is about 2 inches.. But it doesn't sound right, I'm going to take apart the right shock again but the left side doesn't make a single sound so idk what could be the problem
Old 09-15-2014, 10:28 PM   #4
That's odd. Drastic drop.
Old 09-15-2014, 10:41 PM   #5
Mutafov's Avatar
Region: Nevada
I gets rid of the gap perfectly, you can fit 2-3 fingers in between the tire and top. I just drove home and the sound was gone; it'll be back.. I don't get it
Old 09-15-2014, 10:49 PM   #6
Same amount of fingers on mine with a 1.5". Are you on stock struts/shocks?
Here's mine, sits beautifully.
Old 09-15-2014, 10:52 PM   #7
Mutafov's Avatar
Region: Nevada
Yeah I'm on stock struts/shocks for now, I was planning on getting a new set in a couple of months.. I need better pictures of how mine sits now haha but I enjoy the way it rides Click image for larger version
Name:	ImageUploadedByMustang Evolution1410839523.270632.jpg
ID:	166181Click image for larger version
Name:	ImageUploadedByMustang Evolution1410839530.695435.jpg
Old 09-15-2014, 10:56 PM   #8
Looks good. Yeah you're definitely going to want to get struts/shocks before you blow out the OEM ones. That's a big drop, and the spring rates are much stiffer and the struts/shocks won't last long. Also, might want to look into caster camber plates, and a panhard rod to center the rear end. Did the rear end shift at all after the drop?
Old 09-15-2014, 11:01 PM   #9
Mutafov's Avatar
Region: Nevada
I ordered a panhard bar and it went on back order the second I ordered it 😒 but the rear didn't move at all which I didn't expect. I'm about to order the camber plates and get an alignment in the next week
Old 09-15-2014, 11:03 PM   #10
Yeah sometimes it won't move. It's a case by case type thing. Mine moved only slightly but I was able to adjust it immediately. That's good. Just keep and eye/ear on the stock strut mounts. Those are flimsy an will go first.
Old 09-15-2014, 11:09 PM   #11
Mutafov's Avatar
Region: Nevada
bad squeaking noise on 3.8 01' mustang jumpman1203 Pre-2005 V6 Mustang 9 07-27-2015 02:03 AM
Squeaking noise coming from belts sLbxO143 1996-2004 Mustang GT 11 02-25-2013 03:08 PM
weird squeaking noise 86 muscle 1996-2004 Mustang GT 8 10-08-2011 04:23 PM
Squeaking noise Nog51 Pre-2005 V6 Mustang 13 12-21-2010 10:18 AM
Squeaking Noise joekool9 Pre-2005 V6 Mustang 3 08-03-2004 10:38 AM
09:20 AM
