2012 GT struggling on cold start. - Mustang Evolution
Old 09-18-2014, 01:14 AM   #1
Mustang Coyote's Avatar
Every once in awhile my mustang, with 45K miles, has trouble cranking. The symptoms include a longer crank duration than my normal and more common ones. After it does crank, the RPM needle shakes rapidly below 0 RPMs before going up to normal crank range. This has occurred on both level and angled ground. I have had more than a half a tank of gas during all but one occurrence. With 45K miles I'm wondering if there is a component i should replace or upgrade? I bought her with 41K. It also seems to be happening more often lately as well. ANY help is much appreciated. Thanks you.
Mustang Coyote is offline   Reply With Quote
Old 09-18-2014, 01:19 AM   #2
Check battery?
chefron50 is offline   Reply With Quote
Old 09-18-2014, 06:42 AM   #3
New plugs and sea foam to start with.
jd864 is offline   Reply With Quote
Old 09-18-2014, 08:04 AM   #4
Grabber Blue5.0's Avatar
Plugs shouldn't need to be changed @ 45,000 miles and seafoam is certainly not the answer.
And it wouldn't be the battery if it was cranking just fine.
Old 09-18-2014, 08:49 AM   #5
BIGHOSS5.0's Avatar
Have you run a diagnostic, no error codes or anything out of the normal? Double check you battery terminals and your Ground cable...Autozone will do a free battery/alternator check for you. Also check your coil packs make sure there are no loose or wet connections. I'm just throwing ideas of what it might be... Hope this helps...
BIGHOSS5.0 is offline   Reply With Quote
Old 09-18-2014, 09:06 AM   #6
KARgt13's Avatar
This isn't exactly the same, because I'm speaking about a '99 camry. However, it had the exact same issue you are describing and it was spark plug related, although in my case it ended up being the wiring and not the plugs.
KARgt13 is offline   Reply With Quote
Old 09-24-2014, 03:39 PM   #7
To anyone who was curious, turns out it was the battery. They performed tests that resulted in 0 cranking amps compared to the normal 590 on the stock battery. A new battery is in and everything is just fine. Thank you all for the input!
2012 gt
Remote start/push to start GT_Man 2011-2014 Mustang GT 9 01-31-2015 11:57 PM
Struggling to crank sixxerstang 2005-2010 V6 Mustang 2 12-13-2012 09:15 AM
Cold Start/ Idling issue CodyNelson 1996-2004 Mustang GT 11 09-24-2011 10:34 AM
2012 Camaro SS, 2012 Mustang Boss 302, or 2012 Mustang Gt Premium? iseabail General Mustang Discussion 4 07-18-2011 10:12 PM
Cold Start?? FrvrDreamin 1996-2004 Mustang GT 15 11-07-2006 09:17 AM
08:56 AM
