Front Right Popping Sound - Mustang Evolution
Old 09-19-2014, 11:25 AM   #1
KARgt13's Avatar
I just developed a pop in the front right of my car. It seems to happen when turning left from a stop on hills, for example if I make a left from a hill onto a flat as the wheel goes over the crest I get a pop (just one). Any ideas?
KARgt13 is offline   Reply With Quote
Old 09-19-2014, 11:44 AM   #2
andyx5oh's Avatar
I honestly thought I was the only one. lol happens to me every now and then. still don't know what it could be.
andyx5oh is offline   Reply With Quote
Old 09-19-2014, 03:34 PM   #3
Jd431x1f's Avatar
Region: Nevada
Did you lower your car? If yes the upper spring perch bearings are knocking.
Jd431x1f is offline   Reply With Quote
Old 09-19-2014, 04:23 PM   #4
KARgt13's Avatar
I did about a year and a half ago. That makes sense though.
Old 09-19-2014, 04:28 PM   #5
Jd431x1f's Avatar
Region: Nevada
They are One time use according to Ford, my 14 GT started doing it when I put in Steeda springs. I'm going to install the Steeda mounts to also fix the camber. Ive heard the GT500 mounts are a cheaper solution than the Steeda's and beefier than the stock ones.
Old 09-19-2014, 06:18 PM   #6
Abominable Mustang
WhoDat's Avatar
Region: Alaska
They are, but you have to keep in mind that they also require the use of 05-10 struts to work on the 11+ Mustangs.
2012 Kona Blue 3.7L V6:
Old 09-20-2014, 07:47 AM   #7
KARgt13's Avatar
I have the GT500 mounts.
Sent from my One using Mustang Evolution mobile app
Old 09-20-2014, 10:24 AM   #8
its the factory strut mount poping, i have it too.
13' Mustang GT, A6, Whiteline adj. phb & support brace, Roush a/b, Boss 302 brace, Pioneer door speakers, Alpine 10" 500 Watt RMS Amp and Sub, Michelin Pilot Super Sport
winkawak is offline   Reply With Quote
Old 09-20-2014, 05:09 PM   #9
KARgt13's Avatar
Okay. I don't have factory shocks,struts, or strut mounts. Eibach prokit. Could be that the strut already went bad.
Old 09-20-2014, 07:51 PM   #10
Then it shouldnt pop when u turn. Are the everything seated or installed correctly?
Old 09-22-2014, 06:49 AM   #11
KARgt13's Avatar
Everything has been in for about a year and a half now. Just started suddenly.
Old 09-22-2014, 11:11 AM   #12
KARgt13's Avatar
Another symptom I can add is constant popping when I make a slow sharp left turn.
Sound of hitting/rubbing from the front right mazen123 Pre-2005 V6 Mustang 2 05-14-2014 02:03 PM
Chirping sound be right front wheel well? V6 stang Pre-2005 V6 Mustang 8 11-04-2012 10:39 AM
2nd gear popping popping out Cleancobra22 General Mustang Discussion 4 05-29-2012 08:36 PM
Popping sound while braking... 12GTstangCS 2011-2014 Mustang GT 4 11-29-2011 12:55 PM
popping sound drivers front wheel edross 1996-2004 Mustang GT 15 06-21-2009 10:45 PM
07:59 AM
