Tie rod question - Mustang Evolution
Old 09-25-2014, 10:25 AM   #1
Tie rod question
If my steering wheel is slightly off center, can the tie rods be adjusted to center it?
Sent from my SM-G900T using Mustang Evolution mobile app
Mikeyt03 is offline   Reply With Quote
Old 09-25-2014, 08:18 PM   #2
Redonblackpony's Avatar
What has changed to make your steering wheel off center? Did you hit a curb? Did you change the LCAs?
Redonblackpony is offline   Reply With Quote
Old 09-26-2014, 03:18 AM   #3
Ammermeow's Avatar
Adjusting tie rods will change the alignment, but it is possible it is out of alignment already which is the root cause of your problem. In older cars I would pull the steering wheel off and rotate a tooth, but wouldn't try this with an air bag car.
Monitor tire wear for a bit to see if your alignment is off.
Ammermeow is online now   Reply With Quote
Inner Tie Rod Nut Sizes Sgt_Syke 1979-1995 Mustang GT 4 02-27-2013 03:38 PM
Purchasing Turn Buckle/tie rod OzzyLiriano 2011-2014 Mustang GT 0 09-05-2012 10:42 PM
Inner tie rod ends Justintriner 1996-2004 Mustang GT 2 12-10-2011 01:07 AM
Tie Rod Kamakanani0 Pre-2005 V6 Mustang 15 01-28-2011 08:10 PM
Tie Rod: Smokedya95stang Pre-2005 V6 Mustang 3 05-10-2004 10:29 PM
01:37 AM
