I Really messed up - Mustang Evolution
Old 09-29-2014, 05:38 PM   #1
I Really messed up
My stupidty, I usually know that when filling up, once the the handle snaps to shut the fuel flow, I shouldn't try to add a little more because that will always overflow on the ground...........but since I'm stubborn, saying 'Maybe this time will be different' $%%^&&$#@#((*%*^&&(#(%$. Of course it overflows....Now this morning I find this on the ground. I think the gas dissolved some kind of glue.
What is the best way to glue this baby back reliably. (not super glue) I don't want to find it missing 2 months down the road.
Thanks in advanced.
Name:	Mustang reflector.jpg
NoTop5.0 is offline   Reply With Quote
Old 09-29-2014, 06:02 PM   #2
blackie's Avatar
I would use clear silicone automotive quality,autozone has it.
blackie is offline   Reply With Quote
Old 09-29-2014, 07:40 PM   #3
Plasti dip it back on. then you can call it a mod.
Sent from my SM-G900T using Mustang Evolution mobile app
Mikeyt03 is offline   Reply With Quote
Old 09-29-2014, 08:38 PM   #4
3 weatherstrip and emblem glue
---------- Post added at 10:38 PM ---------- Previous post was at 10:37 PM ----------
3m
chefron50 is offline   Reply With Quote
Old 09-29-2014, 09:03 PM   #5
LuisBlackGT's Avatar
Just try taking it in for warranty?
2014 Black Mustang GT. 20" Amr wheels, Sr Performance lowering springs 1.5", stillen front chin, mmd window louvers, roush AB exhaust. FOLLOW ME ON INSTAGRAM: @barrios_Luis
LuisBlackGT is offline   Reply With Quote
Old 09-29-2014, 09:34 PM   #6
Superglue it in there. Thats what i did. When are you ever going to take it out again?
Old 09-29-2014, 09:39 PM   #7
Is there any indication of how it was originally held in place from the factory?
If not I would go to an autoparts store in the adhesive isle and look for an automotive adhesive that is made to bond to plastic and paint.
StarzTA17 is offline   Reply With Quote
Old 09-29-2014, 11:49 PM   #8
Jd431x1f's Avatar
Region: Nevada
What about plastic model glue? Looks like the same type of plastic.
Jd431x1f is offline   Reply With Quote
Old 09-30-2014, 12:44 AM   #9
Compstall's Avatar
Elmer's wood glue
- Brent
'11 GT Kona Blue Brembo
"Measure with micrometers, mark with a scribe, chop with an axe"
"I'm not new to driving. I've been doing it for a couple of years now." - Aphex
Compstall is offline   Reply With Quote
Old 09-30-2014, 01:41 AM   #10
The only issue I see with that is how it would hold up to extreme hot or cold temperatures over time.
Old 09-30-2014, 01:48 AM   #11
Jd431x1f's Avatar
Region: Nevada
I Really F up
The plastic model glue would melt them together. I think it would hold up.
Old 09-30-2014, 04:00 AM   #12
Originally Posted by Compstall View Post
Elmer's wood glue
lol
you still don't win the million dollar prize
thanks all, the silicone sounds better as it is flexible and pita to remove.
never had good results from superglue.
Old 09-30-2014, 04:59 AM   #13
bucko's Avatar
Another issue with "topping off" your fuel is the charcoal canister. It's intended to collect the fumes from the gas tank and route them to the intake for burning off. When you top off, you over fill, and the fuel sloshes up the tube and into this canister overflow tube, and over time distroys the charcoal canister. It will set a code, and that canister is almost a hundred bucks to replace.
I used to do this years ago, until my F-150 had this failure due to over filling.
Old 09-30-2014, 05:40 AM   #14
SixBanger's Avatar
Hindsight's 20/20 I guess, but don't top off your fuel. Just think, when you squeeze that little extra bit in there how much are you getting in there? Pretty much nothing when compared to the 13 or so gallons you just dumped in!
2014 V6 Base Coupe, Sterling Gray Metallic///3.31 Gears///FP6 Appearance Package///Tech. Package///Reverse Sensing and Security Package///Mods: Boss 302 grille, MMD Ducktail Spoiler, Weathertech Floor Mats, Bassani Axle-Back Exhaust
SixBanger is offline   Reply With Quote
Old 09-30-2014, 08:03 AM   #15
Strange Mud's Avatar
+1 silicone
Old 09-30-2014, 08:08 AM   #16
2 Stangz's Avatar
Region: Nevada
Buy a new one. Fix it the right way. They're cheap.
Old 09-30-2014, 08:09 AM   #17
yep, silicone
bodon is offline   Reply With Quote
Old 09-30-2014, 09:52 AM   #18
gasoline safe RTV if you're gonna keep doing it.....
Old 09-30-2014, 07:40 PM   #19
im sure he learned his lesson. then again...
deadpandan is offline   Reply With Quote
This guy is having a bad day... A really, really bad day JROC The Bar 15 08-16-2007 10:52 PM
Im in a really messed up situation... help? Zim The Bar 51 09-22-2006 12:59 AM
this is really messed up... Zim The Bar 9 01-31-2004 12:29 AM
well im really really bored right now Zim The Bar 19 01-06-2004 08:30 PM
im really really bored. Zim The Bar 0 11-17-2003 03:59 AM
01:51 AM
