Active knock - Mustang Evolution
Old 09-30-2014, 06:03 AM   #1
Region: Asia
Unhappy Active knock
hi
I bought a used 2013 mustang Gt, I installed x pipe off road then I data log ,was there active knock 3.25. tuner in my area said maybe need to tune so he did and could not increase timing because the knock
I return the stock h pipe so now the car is stock, yesterday I data log and the knock increase to(4.50) fule is ok and exhaust is not touching, I’m thinking that maybe the old owner tuned it and forgot to return to stock (oem tune) when sold it and the car now has a custom tune as OEM .
please i need your support what do u think
Thanks.
MooDy5.0 is offline   Reply With Quote
Old 09-30-2014, 06:36 AM   #2
I think you need to edit your post to make it make more sense. As for the car...take it back to where you bought it and let them sort it out. The knock needs to be fixed. I hate to say it, but people trade in cars when they know they have engine issues. Dealers are so concerned with getting people in new cars that they fail to recognize issues with the car they're trading in. This is why I would never buy a used mustang unless it's a gt500 that has no signs of abuse or altering. Good luck.
Sent from my SM-G900T using Mustang Evolution mobile app
Mikeyt03 is offline   Reply With Quote
Old 09-30-2014, 07:41 AM   #3
Rapinator126's Avatar
The knock sensors on these cars are sensitive. Anything from a exhaust leak to something rubbing the frame can cause it.
Check everything out,
Old 09-30-2014, 08:02 AM   #4
scott_0's Avatar
when you say active knock, was it a - or a + before the number you read as knock?
Old 09-30-2014, 08:19 AM   #5
Region: Asia
I went to exhaust shop everything is normal
Old 09-30-2014, 08:21 AM   #6
Region: Asia
It is +4.50
Old 10-02-2014, 01:56 AM   #7
Region: Asia
Any suggestions??
Old 10-02-2014, 05:03 AM   #8
Try to check the bolts and clamps that connect to the Cats on the h/x pipe, folks like to flip em and then they tap the frame under load.
Also try to run 5gals or so of some 100+ octane and that will be able to eliminate bad fuel issues.
I had the same knock issues when tuning and turned out it was bad fuel and these cars are sensitive!
AllBlack14GT is offline   Reply With Quote
Old 10-02-2014, 12:53 PM   #9
I had some knock while tuning, all I did was went to the auto parts store and bought 2 bottles of Lucas octane boost and filled up my car with 93 and the problem went away.
smithmpp is offline   Reply With Quote
Old 10-09-2014, 08:41 AM   #10
utm18's Avatar
Cheap gas, just went through all this with Aed.
utm18 is offline   Reply With Quote
Old 10-20-2014, 01:09 AM   #11
Region: Asia
sorry for being late in reply, the knock is gone after i did a KAM reset.
now when i data log knock sensor is showing :
first run +0.40 max and -2 min
second run +0.50 max
what do u think? because i am going to contact Mike to tune my car
Thanks for the help i appreciate it
Knock Knock *Language* Brent Pictures and Videos 3 04-03-2008 04:18 PM
Motor acts like traction control is active ArmyStangGT 1996-2004 Mustang GT 6 09-29-2007 10:42 PM
Help ME.com stay active and full of technical info! SpectorV The Bar 0 10-17-2005 02:56 PM
12:03 PM
