Cams - Mustang Evolution
Old 10-03-2014, 01:27 AM   #1
Zed
Zed's Avatar
Cams
Anybody know any good cams that will give me that "rump thump thump.... thump thum..ptptpt. rump rump thump" sound ๐Ÿ˜˜ I've heard it's hard getting that sound out of our 5.0's... not looking for the ghost cam tune, I want the legitimate thing (:
Sent from my SAMSUNG-SM-G900A using Mustang Evolution mobile app
Zed is offline   Reply With Quote
Old 10-04-2014, 09:29 AM   #2
Charlie_santos's Avatar
Zed u could've texted me lol I know how...
Sent from my LG-D850 using Mustang Evolution mobile app
Old 10-05-2014, 06:00 AM   #3
Probably a cam that is so aggressive it's effect s drive ability.
Sent from my SM-G900T using Mustang Evolution mobile app
Mikeyt03 is offline   Reply With Quote
Old 10-05-2014, 09:36 AM   #4
ArtU's Avatar
If you got a manual l, Ford TrackCal tunes lope with a rump rump, and so do MPT and Lund.
MPT will do auto ghost cam tunes but manuals are more drive-able.
ArtU
Ford TrackCal, Borla ATAKs, rumps and thimps at the Cruz ins...
Old 10-05-2014, 10:17 AM   #5
ArtU
Did you read his post at all?
Old 10-05-2014, 01:54 PM   #6
ArtU's Avatar
Yes, I did
Edit: perhaps its best to explain what I am trying to say. Our camshafts have variable timing controlled by the computer. Whether you use the computer tune to create overlap at Idle, or buy 4 camshafts that build it in the forging, the overlap is real. The rump is a rump on a good cam tune that doesn't dump gas. The Ford Track tune does not dump gas and is safe.
The cams forged to overlap at idle can make drive-ability difficult, as it was in the older days. If all he wants is the sound and not the higher end HPR of the forged performance camshafts its sorta a huge price to pay saying my 4 Cams overlap is forged vs pushed by a solenoid and oil pressure to produce the overlap.
The only thing not real about a tune pushing a variable cam overlap is you don't gain extra HPR at 7500, but what is real is you don't lose low end drive-ability as you point out right here: ["Probably a cam that is so aggressive it's effect s drive ability. "] and then you see the cars like that are trailered to shows not local.
Old 10-05-2014, 02:08 PM   #7
He doesn't want a tune that makes the lope idle sound. He clearly states that. You didn't read his post.
Old 10-05-2014, 02:20 PM   #8
Rapinator126's Avatar
I have posted countless times on here on, how to actually get a lope out of the 5.0's.
Old 10-05-2014, 02:27 PM   #9
I've got to admit. You're very knowledgeable. I respect you.
Old 10-05-2014, 03:01 PM   #10
ArtU's Avatar
Yes, such as in remove the phasers and use cam locks? That will produce it.
Old 10-05-2014, 03:16 PM   #11
Yes by deleting the VCT and the phasers then installing lockouts.
Then a good cam, the off the shelf stuff from comp is garbage
Old 10-05-2014, 03:28 PM   #12
Almost all camshaft manufacturers will make custom grind cams for the same price as the off the shelf ones.... That is the way to go.
Old 10-05-2014, 04:26 PM   #13
Joaquin_ii's Avatar
Any downside to deleting all that?
Joaquin_ii is offline   Reply With Quote
Old 10-05-2014, 04:32 PM   #14
Gas mileage will be bad, have to find a good tuner
Old 10-05-2014, 05:28 PM   #15
How bad, like Ford Raptor bad?
Old 10-05-2014, 05:33 PM   #16
Raptor is junk had one for my company truck for awhile, sold it and got a f250. Besides that. Anywhere from 6-10 with e85 just depends on gearing etc.
Old 10-05-2014, 05:35 PM   #17
Damn, that is bad.
Old 10-05-2014, 05:35 PM   #18
Joaquin_ii's Avatar
Dam that bad!?
Old 10-05-2014, 05:59 PM   #19
ArtU's Avatar
And harder to drive as a semi-daily driver, I drive mine anytime the weather is good and no salt or moisture on the ground. And that goes all the way back to this, without dumping what, 3K on cams, good person tuner? Might as well put a cobra or boss manifold and value stuff on those heads to get the benefit of the stationary overlap cams, extra lift etc. ... Unless of course you really need all that like RAP and others do and makes good use of it, I never would.
[Edit: perhaps its best to explain what I am trying to say. Our camshafts have variable timing controlled by the computer. Whether you use the computer tune to create overlap at Idle, or buy 4 camshafts that build it in the forging, the overlap is real. The rump is a rump on a good cam tune that doesn't dump gas. The Ford Track tune does not dump gas and is safe.
The only thing not real about a tune pushing a variable cam overlap is you don't gain extra HPR at 7500, but what is real is you don't lose low end drive-ability as you point out right here: ["Probably a cam that is so aggressive it's effect s drive ability. "] and then you see the cars like that are trailered to shows not local.]
Old 10-06-2014, 11:13 AM   #20
If you only want the sound just go with the cam tune. Why spend $3k on cams for the sound?
Old 10-06-2014, 12:04 PM   #21
mystang50's Avatar
BECASUE F*CK LOGIC
Old 10-06-2014, 12:19 PM   #22
Paradone's Avatar
All in how you want to spend your money if you want to invest 5k for a great sound go for it, custom grind is the only way to get that specific sound you are looking for as Rap clearly pointed out shelf cams are garbage and that is so true. So you have to decide where you want to spend your hard earned cash. I was after that old school lope and after investigating what it actually would take and the cost versus the benefit it was a shelved project so I bought a track key and kept the car stock and put dollars into the suspension.
Paradone is offline   Reply With Quote
Old 10-07-2014, 09:39 AM   #23
Voltwings's Avatar
I'd be willing to put money down you'll have a very hard time telling the difference between the two, as was stated earlier, they both lope for the same reason. You're still creating the overlap like a push-rod cam, you just literally have none of the downsides with the Ghost cam. To each his own though, i guess you'll be able to say it's actually got cams.
Old 10-07-2014, 09:45 AM   #24
Depends on how aggressive you go on a cam, a custom cam from L&M he will set it up however you want.
You can definitely tell a difference vs a ghost cam tune
Old 10-07-2014, 09:50 AM   #25
Voltwings's Avatar
Well if its loping so hard its struggling to stay running lol then yes, but a decent, still "street friendly" cam, id say its a wash.
Old 10-07-2014, 10:15 AM   #26
True but if they dellete the vct and do not take advantage of it with a custom aggressive cam then they are wasting alot of $$$
There is alot of factors thay have to come into play with you get that critical with your build
Old 10-07-2014, 11:42 AM   #27
Joaquin_ii's Avatar
Is there a certain place you have to keep to have it running if an aggressive can is placed? Rpm wise?
Old 01-07-2016, 09:35 AM   #28
Rickster_1823's Avatar
I have to do tons of reaserch on these cams and the VCT on my 2013 5.0.
i plan on putting Cams on mine for the HP gains and also get the original lobe sound from them. what keeps bugging me is the little knowledge i have about the VCT and deleting that feature along with the phasers and installing lockouts.
what will happen when you delete the VCT? doesn't that help tremendously in HP and tourque throughout the band? and 6-10 MPG? holy S***.
it may be best to just get cams and a good ghost cam tune.
2013 5.0 DIB; Airaid, JBA LT Headers / JBA Off Road X Pipe to Cutouts; 4.10s; BBK Lower Arms; Barton Short Shifter; E85 BAMA race.
Rickster_1823 is offline   Reply With Quote
Old 01-07-2016, 12:45 PM   #29
ArtU's Avatar
When you put in aggressive cams and delete the VCT; you get what you do with a push rod motor with aggressive cams. Now you have a race car you likely would trailer to any place or show not local.
Unless your making a pro street car to trailer or stay local only; save money and get a good ghost cam tune if you want the old school sound and don't forget the Borlas
Old 01-07-2016, 04:00 PM   #30
No no no. Wrong wrong. You can still daily a car with VCT and phasers deleted. Smh
LSX 408 FTW
Dragging your a$$
Old 01-07-2016, 04:26 PM   #31
2011 Kona Blue's Avatar
Just get the Ghost cam tune for $120 and call it a day. Big lope sound.
Non ๐Ÿผand non ๐ŸŒฝfed. I $uck!
Old 01-07-2016, 05:10 PM   #32
ArtU's Avatar
LSX 408 FTW
Dragging your a$$
Need to add "daily a car with VCT and phasers deleted, and aggressive pro comp cam...."?
Old 01-07-2016, 05:13 PM   #33
Until the day you have done this personally and have it tuned correctly do not assume stuff
LSX 408 FTW
Dragging your a$$
Old 01-07-2016, 05:14 PM   #34
Until the day you have done this personally and have it tuned correctly do not assume stuff.
It can be done. For a auto it's a little more complicated.
LSX 408 FTW
Dragging your a$$
LSX 408 FTW
Dragging your a$$
Old 01-07-2016, 05:20 PM   #35
ArtU's Avatar
I am asking here, hence the ??
Can you Daily Drive an aggressive Thumper cam with phasers deleted?
You are saying yes based on your response that doesn't exactly say yes; OK
If you don't need the Pro Comp power those cams give you when you add the head work and manifold work, is it worth the price if your not racing? and I mean real racing like you do..
And when I say Pro Comp, I am not talking brand of cam, but racing level; whats it called now? .. Pro Street for cars that needs trailered in and cant drive on the street?
I think what we used to call Pro Street 40 years ago is now Pro Touring?
Let me know, you do know your facts.
4.6l Cams Black00GT 1996-2004 Mustang GT 14 11-17-2008 08:19 AM
anyone have any cams out there? Zim Mustang Parts for Sale and Wanted 5 03-05-2005 05:59 AM
Cams and drag racing... Exit_In_Red Pre-2005 V6 Mustang 7 02-07-2005 03:51 PM
Mustang Cams ttpancakes Pre-2005 V6 Mustang 48 08-07-2004 12:38 PM
explanation of 1.73/1.8rr's with/without custom cams? tire Pre-2005 V6 Mustang 5 12-29-2003 10:18 AM
12:13 AM
