Click noise when breaking on 2014 - Mustang Evolution
Old 10-06-2014, 09:28 PM   #1
Has anyone had an issue with a clicking noise coming from front drivers side? Not sure if it's coming from breaks or motor, it only does it after the car has been driven for awhile. Then when you hit the breaks and start slowing down it starts clicking from the front drivers side. My car is at the dealership right now, wanted to see if anyone else had this problem.
aftermath81 is offline   Reply With Quote
Old 10-10-2014, 10:20 AM   #2
Itcouldbebobby's Avatar
Had to return mine to dealership the day after I bought it for similar reason. Sounded almost like a caliper was hitting something under load during braking. Turns out it was the driveshaft carrier bearing out of adjustment. A few minutes on the rack at the dealer and she was good as new. Hope you got yours sorted out and it was similarly minor.
2014 GT MT TrackPack w Brembos, 3.73 gears
Came home with me 4/23/14
Ingot Silver with matte black wheels and emblems, SR Performance lowering springs, J&M adj panhard bar, BMR LCA's
Dubbed "Lucinda" by my 5 year old daughter and co-pilot
Itcouldbebobby is offline   Reply With Quote
Old 10-11-2014, 09:16 AM   #3
I took it back to the dealer an they couldn't get it to click or anything. Only time it does it so far is when I have driven it for awhile an hit the breaks. So going to test it out again when the weather is better to see if it still does it. If it does I'll take it back to the dealer an have them check the carrier barring like you said.
Old 10-11-2014, 12:43 PM   #4
I know mine made the noise every time I was braking hard, so it was easy to replicate for service tech. If it's the carrier bearing it will most likely "sound off" when you're really hard on the brakes, causing the driveline to flex and misalign at the bearing. If this isn't the case I'm not sure what they'd be looking for. But I'd definitely have them start there as it sounds like the same issue. Good luck man, hope it gets solved.
Old 10-11-2014, 10:24 PM   #5
eliasj7's Avatar
Region: Oregon
Let us know the outcome. Good luck.
eliasj7 is offline   Reply With Quote
breaking in 2014 gt naquin14 gt 2011-2014 Mustang GT 46 05-19-2015 11:22 PM
2014 mustang GT breaking to a stop a loud clunk in the right rear johnfrogue 2011-2014 Mustang GT 14 05-05-2014 06:48 PM
Popping noise coming from the rear and when breaking Redonblackpony 2011-2014 Mustang GT 8 04-23-2014 08:47 AM
cows go mooo, ducks go quack...starter goes click click Bane- The Bar 13 05-02-2005 09:29 PM
06:57 PM
