Slicks or Drag radials - Mustang Evolution
Old 10-10-2014, 09:07 AM   #1
REG
Anyone have experience with both.? I've seen a number of posts/articles which state drag radials really aren't that much better than street tires.
If I choose to go with a 15" 28 inch slick, what wheels would work with it?
Not in a hurry as tracks are starting to close here in western PA.
REG is offline   Reply With Quote
Old 10-10-2014, 10:20 AM   #2
1 Alibi 2's Avatar
Slicks will give you a better launch, drag radials will give you a higher mph top end.
There are plenty of MFG. offering 15" wheels with lots of widths available.
( Jegs, Summit, etc. ) costs nothing to look.
Be advised that if you go 15 x 10, you will probably have to relocate your rear sway bar.
( kits are available for this, BMR and other MFG. )
2014 - detuned to 780rwhp
2017 F150 Lariat Scab, 5.0
Old 10-10-2014, 10:34 AM   #3
Grabber Blue5.0's Avatar
Manual-Slick
Auto-Drag Radial
A 15" wheel requires sway bar relocation brackets. Not a big deal.
Old 10-10-2014, 09:42 PM   #4
Ntbruncie's Avatar
Grabber can you please explain why auto needs drag radials and not slicks. Thanks
Ntbruncie is offline   Reply With Quote
Old 10-11-2014, 05:45 AM   #5
A drag radial is faster than a slick. The auto can get away with using them since the rear won't be "shocked" like a manual will do. A manual needs a slick because when you dump the clutch on a slick the wrinkle affect will absorb a lot of the energy associated with the shock sent to the rear. A drag radial on a manual car can be detrimental to the rear. And it's not always about how much power a car makes. These cars are heavy and that does not help matters at all as well.
Old 10-11-2014, 05:46 AM   #6
Simple. Dumping the clutch shocks the drivetrain so hard that a DR or street tire wants to break lose. An automatic is a much smoother leave(doesn't shock the drivetrain so violently)and allows a DR to hook up. I have a 2014 GT and when I go to the track I run a 325/50/15 DR and have zero spin.
bodon is offline   Reply With Quote
Old 10-11-2014, 06:52 AM   #7
JimC's Avatar
Originally Posted by Grabber Blue5.0 View Post
Manual-Slick
Auto-Drag Radial
You only need a sway bar relocation for a 10" wide wheel. A 15 X 8 will fit. Can't go as wide on the tire though with the 8"
JimC is offline   Reply With Quote
Old 10-11-2014, 07:41 AM   #8
Wheel widths matter more if you choose the relatively stiff carcass drag radial. Slicks you can get by on a narrower rim, as long as you are prepared to pressure down to get them to sit flat. I have a true 10 inch wide tire on a 7.5 inch rim out back.
I have used both repeatedly. What has been said above is true. Dr auto, slick mt. Slicks need to be flown all the way down track, particularly with radials up front. Drs are better suited to rookies at this
For Sale: Hoosier Drag Slicks on Welds CodyNelson Mustang Parts for Sale and Wanted 2 04-30-2013 09:45 AM
Drag slicks? babyhuey 2005-2010 Mustang GT 17 03-18-2013 02:40 PM
street tires/drag radials/slicks Topless04GT At the Track 27 06-17-2012 02:46 PM
Slicks or drag radials on 10 holes Stockish302 1979-1995 Mustang GT 19 11-22-2011 08:13 PM
05:20 AM
