New Guy, 2014 Gt pics - Mustang Evolution
Old 10-10-2014, 08:38 PM   #1
Glad to join up, owned alot of mustangs but this one is my favorite. I have about 1200 miles on it now, 2014 GT track package, cloth recaros, M6. Heading to track soon. I tried to be a little different both under the hood and on the wheel and tire set up, constructive criticism allowed
Mods Include the following:
Boss Intake
JLT CAI
Accufab TB
Lund Race Tune
Steeda Catted Xpipe
Corsa Axle back , resonator delete
Barton Shifter
Upper and Lower Control arms
Boss Strut Brace
Black GT500 19X8.5 and 18X10
Mickey Thomson ET streets 305/45/18, MT street comps 255/40/19
Name:	mustang carbon.jpg
ID:	167708   Click image for larger version
ID:	167710   Click image for larger version
Name:	mustang outside.jpg
Jason14Gt is offline   Reply With Quote
Old 10-10-2014, 09:05 PM   #2
SixBanger's Avatar
Jumping Jehoshaphat. That's a lot of mods for 1K on the odo. Looks great!
2014 V6 Base Coupe, Sterling Gray Metallic///3.31 Gears///FP6 Appearance Package///Tech. Package///Reverse Sensing and Security Package///Mods: Boss 302 grille, MMD Ducktail Spoiler, Weathertech Floor Mats, Bassani Axle-Back Exhaust
SixBanger is offline   Reply With Quote
Old 10-10-2014, 09:19 PM   #3
he musta called AM and been like
OP: i'll take one
AM: one what sir
OP: everything
AM: CHA-CHING!
great looking car man.
deadpandan is offline   Reply With Quote
Old 10-11-2014, 01:22 AM   #4
welcome, beautiful engine bay!
BlkBettyCS is offline   Reply With Quote
Old 10-11-2014, 06:58 AM   #5
Very nice
dentman43 is offline   Reply With Quote
Old 10-11-2014, 11:44 AM   #6
Grabber Blue5.0's Avatar
Be careful with that Torsen rear at the track. It's not meant for drag racing.
Old 10-11-2014, 12:05 PM   #7
TommyV's Avatar
Nice set up, you need to lower it though.
'13 5.0 PW Premium / E-Force Supercharger w/ Brenspeed tune / FRPP Recaro's / GT500 quad exhaust / DSS Aluminum / Stop Tech 6P 15" / 13" rears / LP over axels / MGW / Moroso separator / 3:73's / Forgestar F14's 20x9/20x11 w/ Nitto Invo's 275/35's & 315/35's / Steeda Sport springs / Koni STR.T's / Steeda PHB / GT500 Spoiler / Roush upper and lower grills / Stillen front splitter / Boss steering wheel
TommyV is offline   Reply With Quote
Old 10-11-2014, 12:21 PM   #8
insidious_ruin's Avatar
man that's wicked..looks bad@$$ Def lower it!
13 GT Prem.
War-King Edition.
Modded.
insidious_ruin is offline   Reply With Quote
Old 10-11-2014, 01:44 PM   #9
Thanks! yea im not sure if im gonna lower it, i lowered my 97 cobra and had hella problems. Ive also heard that the torsen isnt a good rear end for drag racing. I wanna make the car a street car meant for 30-120mph races. Kinda wish i would bought a stock auto and just added procharger. But its all good!
Old 10-11-2014, 06:21 PM   #10
Red Stallion 11's Avatar
Torsen is not good for drag racing? Why? Why is it on my car then?
What's better?
I really have to make more time to spend on this forum.
Red Stallion 11 is offline   Reply With Quote
Old 10-11-2014, 06:46 PM   #11
Right from Maximum Motorsports website.
Torsen Limited-Slip Differential
The Torsen is the ultimate performance differential. Combine a well balanced suspension package on your Mustang with a Torsen for incredible traction! The Torsen's unique torque-sensing ability keeps engine power going to the ground during changing traction conditions. The Torsen functions as an open differential as long as the amount of torque transmitted to each rear wheel remains equal. When one tire begins to lose traction, the Torsen instantly senses the change in torque being applied to the ground. The excess torque that cannot be delivered to the ground by the tire that is beginning to lose traction is delivered to the opposite tire, which has better traction and can take more torque.
The Torque Bias Ratio (TBR) is the ratio indicating how much more torque the Torsen can send to the tire with more available traction, than is used by the tire with less traction. This ratio represents the "locking effect" of the differential.
The 4:1 TBR of the Torsen T-2R means that this differential is capable of delivering up to four times as much torque to the tire with better traction than is delivered to the tire with the least available traction. By comparison, the Torsen T-2R can deliver about 2.5 times as much torque to both rear tires, collectively, as an open differential can, given the same conditions.
During braking there is little or no torque being conveyed to the differential, and so there is little or no torque difference between the two rear tires. Therefore, the Torsen differential will not support any appreciable torque "wind-up" between the two rear tires during braking. Because of this, the Torsen differential does not interfere with the functioning of anti-lock brake systems.
The clutch plates of the Mustang's stock Traction-Lock differential wear out, requiring periodic replacement to maintain its functionality. This wear causes axle endplay on a solid axle car, which in turn increases brake pad kickback. Axle endplay does not increase over time with a Torsen differential because it does not have clutch plates to wear out. This makes the Torsen differential ideal for use with fixed-mount brake calipers.
While it is ideal for street use, autocrossing, and road racing, the Torsen differential is not recommended for drag strip use. The Torsen differentials fit Mustang 8.8" rear-ends, both solid axle and IRS, and are available in 28 spline and 31 spline versions.
Old 10-11-2014, 09:17 PM   #12
Torsen is best used for Road Races and Autocross
Old 10-11-2014, 10:22 PM   #13
2014oxstang's Avatar
That's all good information. I'm sure my torsen loved all 9 passes down the strip this summer lol.
2014oxstang is offline   Reply With Quote
Old 10-11-2014, 10:26 PM   #14
eliasj7's Avatar
Region: Oregon
Boss Intake
JLT CAI
Accufab TB
Lund Race Tune
Steeda Catted Xpipe
Barton Shifter
Boss Strut Brace
Looks great.
eliasj7 is offline   Reply With Quote
Old 10-12-2014, 06:18 AM   #15
Boss Intake
JLT CAI
Accufab TB
Lund Race Tune
Steeda Catted Xpipe
Barton Shifter
Boss Strut Brace
Gee why did you wait so long to do the mods?? Great car!!!!!!
bodon is offline   Reply With Quote
Old 10-12-2014, 10:46 AM   #16
3.7Muscle's Avatar
Man, thats alot of mods for only 1k miles! You are a hard working individual! I salute to you sir!
I love that it is black on black on black!
Welcome to ME!
Sent from my GT-N7105 using Tapatalk
See my Baby Here
2012 101a Mustang V6 M/T 6-Speed
3.7Muscle is offline   Reply With Quote
Old 10-12-2014, 01:12 PM   #17
Thanks guys! I try to work real hard to keep the mods going. Just wanted to do it all at once instead of piece by piece. I hate the torsen isnt recommended for drag strip. I purchased this car just for that! i guess il drive it till it breaks and put something else in there. The car isnt my daily driver, just weekends. Gonna get big clutch and alumn driveshaft next!!
Old 10-12-2014, 03:12 PM   #18
kingstrider's Avatar
Looks good, nice list of mods. I was the same way, mods started before the plates ever showed up. Have you taken it to the track yet?
2014 Grabber Blue Mustang GT Premium with nav, RR and comfy packages, 3.73 limited slip axle and optional 19" machined aluminum wheels. Come hang out in the garage and check out my build so far!
kingstrider is offline   Reply With Quote
Old 10-12-2014, 03:23 PM   #19
DAJOKER07's Avatar
I bought a Black 14 GT about a month ago. It came with Sportline springs. Congrats on your purchase. I have searched forums and read for two days now trying to decide on shifter. I watched a vid on the barton and love the notchy short shift. reminds me of my tri-ax from my 99. Everybody swears by the MGW though.
My question is do you have any complaints about the Barton. I simply want very short shifts. I love the sound of the shifter going in gear. I just dont want to have to turn the radio up to drown out noise of the transmission going down the road.
Very Nice Ride. The engine bay is a work of art. Keep up the great modding
DAJOKER07 is offline   Reply With Quote
Old 10-12-2014, 03:57 PM   #20
Thanks! havent taken it to track, plan on going to the one in Gilliam Lousiana at the end of the month, hopefully weather be in the 55-60 degree. Shifter is awesome, as for the sound, i like a little notchy noise from it, i dont play the radio at all, i just consider it part of the race theme.
Old 10-15-2014, 12:58 PM   #21
Nice setup, Jason. Let us know how you do on the track.
Current Mustang: '14 GT/Track Pack/6spd-sold
Previous Mustangs: '68 Coupe, '73 Mach 1, '89 GT,
Hoss is offline   Reply With Quote
Old 10-15-2014, 03:35 PM   #22
Nvrfastenough87's Avatar
Beauty. I need to get that coyote strut brace.. thats really nice. diggin the wheels too. You just showed me 2 things I must have...
.... I didn't know I couldn't do that officer...
Nvrfastenough87 is offline   Reply With Quote
Old 10-15-2014, 05:09 PM   #23
Thanks! yes strut tower brace is just a standard BOSS brace, had my buddy wrap it in 3m carbon fiber and add the decal! one of a kind touch.
Old 10-15-2014, 06:32 PM   #24
Aaaaah I knew there was something special about it.
Old 10-16-2014, 07:09 AM   #25
Jason14gt , I love what u did with the boss strut tower brace great job
Old 10-16-2014, 08:31 AM   #26
Deerslayer's Avatar
Looks great Jason! Close to our old bay. Next.........get the battery & brake booster Covers ---- then when you are really ready....... the Vortech
old bay
new bay: I am in the process of replacing this Vortech Plastic Intake tube with a polished Carbon Fiber intake tube
2013 GT : 6sp MT, Track Pkg, 3.73 Rear End, Brembo Brakes, Vortech V3 SC, Boss IM, BBK 90mm TB, JLT CAI, ID1000 injectors, BAP, Brisk Plugs, Tial BOV, Lethal OR X Pipe, 3" over axle to GT500 Quad Exhaust, Dynotech Alum DS, MGW Shifter, Eibach R2 Coil Overs, Bob's Billet LCA's, UPR adj. UCA, Eibach Adj PH Bar, TruCarbon Carbon Fiber inside/out. Tuned by Jon Lund II Three salvaged Bosses worth of Parts live on in this car. 705.11rwhp 5.33pulley/Torque Booster Wastegate
Deerslayer is offline   Reply With Quote
Old 10-16-2014, 08:52 AM   #27
Sterlingbeast5.0's Avatar
Boss Intake
JLT CAI
Accufab TB
Lund Race Tune
Steeda Catted Xpipe
Barton Shifter
Boss Strut Brace
Constructive criticism allowed but not warrented! LOL. Love the ride man. Really put it together well both in performance and in looks. Great build going on
Old 10-16-2014, 06:05 PM   #28
old bay
WOW! awesome job man, cleanest setup ive seen. I think your budget is bigger than mine LOL. I hope to achieve that same look soon. Hows the vortech? worth the $$???
Old 10-16-2014, 06:48 PM   #29
Deerslayer's Avatar
Freak'n awesome. Worth every penny. Great to daily drive, yet and animal WOT
Old 10-20-2014, 07:47 AM   #30
joefez55's Avatar
Very nice mustang OP !!
joefez55 is offline   Reply With Quote
Traded a 2014 base for a 2014 premium nd4spd24 2011-2014 V6 Mustang 31 07-11-2014 08:18 AM
MARCH 2014: 709HP GT500 PLUS Blown 2014 GT Near Crash! - AmericanMuscle.com AMDanBailer AmericanMuscle 5 03-17-2014 08:19 AM
Mustang GT 5.0 2014 :: 2014 Ford Mustang jeanmorissette Member Garages 0 09-20-2013 07:08 PM
New guy with a 2014 Competition New Member Introductions & Greetings 12 05-28-2013 03:47 PM
New Shelby...HI RES Pics...Updated With Pics PureVenom The Bar 15 03-25-2005 09:53 AM
10:00 AM
