Had my 2013 gt on the dyno this weekend - Mustang Evolution
Old 10-14-2014, 05:59 AM   #1
Mustang32Bill's Avatar
So over the weekend I went to a car show and they had I dyno there so I said what the hell and put it on there. The first run was 398hp 390tq, second run was 402hp 394tq. My car is auto with steeda intake, catless hpipe, slp loudmouth axleback, and vmp tune. I'm happy with the numbers. Is that about where I should be hp and tq wise? And can anyone input why there is a hiccup right before 3k on the graph? Thanks Click image for larger version
Name:	ImageUploadedByMustang Evolution1413287977.978735.jpg
Mustang32Bill is offline   Reply With Quote
Old 10-14-2014, 06:27 AM   #2
Rapinator126's Avatar
Your actual #'s are going to be lower, they gave you the make me feel good #'s
And the dip is in both pulls so it's something to do with the tune more than likely
Old 10-14-2014, 06:28 AM   #3
You need to do some dataloging badly.
Old 10-14-2014, 06:31 AM   #4
But now you are going to hear from people saying I got this# with same mods. Don't listen to it bc it does not matter.
You can't compare 2 different cars on 2 different dynos on 2 different days. Just does not work.
You just need to get that tune in order and you will be good.
Old 10-14-2014, 06:37 AM   #5
I've datalogged multiple times for Justin, for some reason it still won't do a burnout and if I power brake it at the track it bogs down when I let off the brake. What should my numbers be around?
Old 10-14-2014, 06:45 AM   #6
DallasStang77's Avatar
Originally Posted by Mustang32Bill View Post
So over the weekend I went to a car show and they had I dyno there so I said what the hell and put it on there. The first run was 398hp 390tq, second run was 402hp 394tq. My car is auto with steeda intake, catless hpipe, slp loudmouth axleback, and vmp tune. I'm happy with the numbers. Is that about where I should be hp and tq wise? And can anyone input why there is a hiccup right before 3k on the graph? Thanks Attachment 167810
Yeah that dip is consistent on both pulls so a datalog will smooth it out. Also your hp and torque are very close in number to each other. Shouldn't be that close with the mods you have.
Old 10-14-2014, 06:46 AM   #7
Are you taking traction control off b4 your burnouts?
It's hard to say on your actuall #'s but the ones they gave you were uncorrected. So using a correction factor they will be slightly lower. Don't get caught up in the # game.
Old 10-14-2014, 06:51 AM   #8
Yeah I shut off trac and still will bog the power down at 2k and won't go past and keep bogging to stay under 2k. How do you feel about Lund? He lives about 15 mins away from me and my buddy knows him really well.
Old 10-14-2014, 06:53 AM   #9
Dam your local to him, use him then bud.
Old 10-14-2014, 06:59 AM   #10
What should my 1/4 times be around because the best I've got is 12.5 and that's with no spinning on the vmp tune. Shouldn't it be lower?
Old 10-14-2014, 07:02 AM   #11
Is this time on street tires? And stock converter if so that's actually pretty good given your mods and the way the graph is looking.
Old 10-14-2014, 07:07 AM   #12
285 drag radial with stock converter and hotchkis lcas. The 60' is 2.041
Old 10-14-2014, 07:09 AM   #13
REG
Best I've ever run was a 12.9 on street tires, no tune, only BBK short tube headers.
With regards to burnouts, I've seen posts where 2013 auto's can't do burnouts, I have a 2013 auto and I could smoke the tires forever with traction control off. That is just pushing the button once.
I just do a little spin to clean the tires as it really doesn't do anything to burnout on street tires, it really doesn't heat them up enough and they don't get any "stickier.
I've gone to drag times.com and seen an awful lot of stock/slightly modified GT's running low 13's high 12's.
Track can make a difference as well. I'm in western pa and the tracks I've run are at 1200 - 1300 ft above sea level.
12.5's with street tires is fantastic, even with a tune.
REG is offline   Reply With Quote
Old 10-14-2014, 07:16 AM   #14
I'm in pa also but run in Cecil county or atco.
---------- Post added at 09:16 AM ---------- Previous post was at 09:15 AM ----------
I had a bama tune and it would roast the tires but the vmp tune won't.
Old 10-14-2014, 07:17 AM   #15
REG
60'
Street tires, no converter, BBK short tube, best 60' 1.976, 13.02 et
2.07 60' 13.07 et, best et 12.905 with a 2.007 60'.
Do the Hotchkis lcas eliminate wheel hop?
I had one run I thought I tore the tire off the rim when I launched, guy behind me said i was bouncing like mad. That run was a 13.8 with a 2.37 60'
Need to fix that for next year.
Old 10-14-2014, 07:18 AM   #16
REG
I'm in beaver county (western PA, outside PGH)
Have run at Quakercity in OH and Pittsburgh Raceway Park.
Old 10-14-2014, 07:24 AM   #17
I love the hotchkis lcas they are stiff when daily driving so they do feel bumpy but man at the the track they plant the power down. Never had an issue even on the street with launching with them. With the stocks I used to blow the wheels out when the car would shift into second now no problem.
Old 10-14-2014, 07:26 AM   #18
And look good lol Click image for larger version
Name:	ImageUploadedByMustang Evolution1413293157.872733.jpg
Old 10-14-2014, 07:32 AM   #19
Abominable Mustang
WhoDat's Avatar
Region: Alaska
Hmm the VMP tune may not deactivate the "anti-power braking" that the 2013-14 autos have. You could always ask your current tuner about it.
2012 Kona Blue 3.7L V6:
Old 10-14-2014, 07:46 AM   #20
zinc03svt's Avatar
Great numbers Man! Awesome torque numbers much higher than most with your mods. Opinions are like a$sholes, everyone has one. I noticed a huge increase in overall torque with my VMP tune. On the street in everyday driving its great. 12.50's are very respectable times BTW. I have no problems completely obliterating my tires (stock oem) in first, shift into second and sometimes third. FYI
Dude you have a drag radial on and your complaining about hooking up...LOL.
Question, what did Justin set your shift points at? Mine where around 7100 and I lowered them down to 6800 range (on device) and it runs a lot better. On stock intake and exhaust it would fall flat at top of second and third. JMO
2014 "Cobra Jet" GT/CS
Automatic, Comfort pkg, Oxford White
zinc03svt is offline   Reply With Quote
Old 10-14-2014, 07:51 AM   #21
I hope Justin can figure out. If not Im gonna give Lund a call I guess.
Old 10-14-2014, 07:57 AM   #22
zinc03svt's Avatar
Sent you PM.
Old 10-14-2014, 08:31 AM   #23
Deerslayer's Avatar
LUND! ftw
Lund will give you a tune that will definately show a better graph than that.
2013 GT : 6sp MT, Track Pkg, 3.73 Rear End, Brembo Brakes, Vortech V3 SC, Boss IM, BBK 90mm TB, JLT CAI, ID1000 injectors, BAP, Brisk Plugs, Tial BOV, Lethal OR X Pipe, 3" over axle to GT500 Quad Exhaust, Dynotech Alum DS, MGW Shifter, Eibach R2 Coil Overs, Bob's Billet LCA's, UPR adj. UCA, Eibach Adj PH Bar, TruCarbon Carbon Fiber inside/out. Tuned by Jon Lund II Three salvaged Bosses worth of Parts live on in this car. 705.11rwhp 5.33pulley/Torque Booster Wastegate
Deerslayer is offline   Reply With Quote
Old 10-14-2014, 09:03 AM   #24
c_rizzle's Avatar
Smoking your tires = loss of traction.
I'm confused as to why you'd WANT to spin your tires, except to "look cool" or to clean tires/warm them up.
Have you ever seen a GT-R, Lambo, 911 Turbo, etc... take off... no tire screeching.
Granted those examples are all 4WD, but the whole point of traction control is to maximize your acceleration, while minimizing tire slip (loss of grip/acceleration).
A small chirp at gear change is all you really want.
Your 1/4 miles are showing you are tuned well.
Your dyno numbers assuming a 16% correction = 464hp, so you've increased hp about 10% above stock (420hp x 1.1=462hp) with your mods (CAI & catless), which is what a lot of people get in general with a few bolt ons.
I don't see a problem. Your numbers look fine... and the proof is in the pudding... I mean the 1/4 mile.
Also, some dyno operators use a higher smoothing #, to make the graph look a little smoother, and it won't show the smaller dips/peaks as much as your "smoothing = 1" graph.
c_rizzle is offline   Reply With Quote
Old 10-14-2014, 09:16 AM   #25
REG
burnouts
I'm confused as to why you'd WANT to spin your tires, except to look cool or to clean tires/warm them up.
That's all I do, just spin them real quick to make sure they're clean before making a pass. Doing big burnouts with street tires does nothing really.
Old 10-14-2014, 11:57 AM   #26
He said that hiccup is where the converter locked up
Old 10-14-2014, 12:14 PM   #27
scott_0's Avatar
youre really close to Revolution Automotive, the drive down to Baltimore would be well worth it man, give them a call 443-231-5072 and let Adam work some magic for you man
Old 10-15-2014, 02:47 PM   #28
joefez55's Avatar
Nice numbers !!
joefez55 is offline   Reply With Quote
Old 11-02-2014, 06:38 AM   #29
zinc03svt's Avatar
Did you ever get your tune/burnout issue sorted out? I just ran back to back 12.4's with VMP canned tune. Fyi
Old 11-02-2014, 10:43 AM   #30
No still no burnout... I've talked to lund think I'm switching over to him. I think Justin is a great tuner just tired of the waiting games with him.
Old 11-02-2014, 11:11 AM   #31
zinc03svt's Avatar
My first time up I did a great burn out. But, I will tell you on my third run I think my tires were warm and had a lot of track glue on them because they would barely spin. That's called stick. LOL
Good luck, Man. Justin has always been very responsive to me.
Old 11-02-2014, 12:36 PM   #32
Lund throws a cam tune in for free so I kinda wanna hear a cam tune on my straight pipped 5.0 lol
Old 11-06-2014, 08:54 AM   #33
BlackBetty2012's Avatar
Region: Rhode Island
2011 GT Dyno
Mods are JLT intake/tune
pretty happy with that, next looking for a Boss302 intake/tune to push me past the 400 mark.
BlackBetty2012 is offline   Reply With Quote
Old 11-06-2014, 10:16 AM   #34
scott_0's Avatar
you shouldn't need a boss intake to go over 400, my only mods are a tune and Pypes long tubes and catted x pipe and I made 412/395
sent from my HTC M8 using tapatalk
Old 11-06-2014, 10:20 AM   #35
Different dynos read different #'s. Wtf does everyone compare I made blah blah blah and I made blah blah.
Fun Ford Weekend at Maple Grove Raceway near Reading PA this Weekend Aug 16-17-18 Spiney General Mustang Discussion 0 08-13-2013 01:06 AM
Fun Ford Weekend this weekend (June 14-15) 9tee7pony General Mustang Discussion 0 06-13-2013 06:36 AM
I had a good dyno day Always broke 2005-2010 Mustang GT 5 05-21-2012 10:49 AM
Baton Rouge area: Who's going to fun ford weekend this weekend? PureVenom Regional Mustang Discussion 9 05-22-2008 06:55 PM
Getting Dyno Tuned this weekend. Number predictions? Monkey The Bar 2 10-10-2005 09:39 PM
07:23 PM
