Caster camber plates or alignment bolts??! - Mustang Evolution
Old 10-15-2014, 11:47 PM   #1
hdez41's Avatar
Im installing the eibach sportline lowering springs on my 2012 gt and i want to know if the alignment bolts will work..caster camber plates arent cheap and if the bolts will work id take those..my car will be a daily driver. Im also installing a panhard bar.
hdez41 is offline   Reply With Quote
Old 10-16-2014, 12:45 AM   #2
DallasStang77's Avatar
Name:	ImageUploadedByMustang Evolution1413441895.093820.jpg
Old 10-16-2014, 12:48 AM   #3
Name:	ImageUploadedByMustang Evolution1413442087.941763.jpg
Old 10-16-2014, 02:49 PM   #4
WhiteCali5oh's Avatar
Region: West Virgina
I got by with just the bolts. Mine is aligned perfectly.
WhiteCali5oh is offline   Reply With Quote
Old 10-16-2014, 04:44 PM   #5
hdez41's Avatar
How much did you drop yours?
Old 10-16-2014, 07:28 PM   #6
1.5 inch eibach prokit w bmr pan hard bar. Haven't installed my control arms and upper yet
Old 10-17-2014, 12:12 AM   #7
hdez41's Avatar
Sweet! Ride looks sweet. I went ahead and got the j&m caster camber plates and j&m panhard bar for the eibach sportlines. A 2" drop in the rear is what im most excited about. What exactly do the control arms do?
Old 10-17-2014, 04:22 AM   #8
Lowers help with wheel hop and stiffen the rear end up. The upper control arm is a must if you're lowering. Your pinion angle will be off on your driveshaft. So you'll need an adjustable
Upper control arm to fix that
Old 10-19-2014, 10:22 PM   #9
c_rizzle's Avatar
I would not trust the alignments bolts for high stress (track / road course) reliability. Or even long term reliability. Over time they will weaken, the threaded bolt moving around a little bit also wears the inside of where the bolt goes and the hole gets bigger. Its just not something I would trust, unless you have a "show" car, not a "go" car.
ie: by "showcar".... you daily drive it like a grandma, and never push it to the limits or track it.
c_rizzle is offline   Reply With Quote
Old 10-19-2014, 11:46 PM   #10
hdez41's Avatar
Looks like i made the right choice by getting the caster camber plates then haha
Alignment help with camber bolts The_Chech 1996-2004 Mustang GT 0 05-05-2014 08:58 PM
caster camber plates or bolts? formulaDstang 2011-2014 V6 Mustang 2 07-20-2013 06:31 AM
Caster Camber Plates or Camber Bolts OutlawGT 2005-2010 Mustang GT 18 04-05-2012 04:55 PM
Caster/Camber Plates...will they be a problem with this? Joel5.0 1979-1995 Mustang GT 4 10-22-2005 04:36 PM
Steeda Springs - Do I need caster camber plates? audioqueso Pre-2005 V6 Mustang 8 12-05-2003 05:34 PM
01:08 PM
