Need opinion if you have own these. - Mustang Evolution
Old 10-18-2014, 09:44 PM   #1
Ford Racing Rear Lower Control Arms
Ford Racing Mustang Rear Lower Control Arms M-5538-A (05-14 All) - Free Shipping
Ford Racing Boss 302R Lower Control Arms
Ford Racing Boss 302R Mustang Lower Control Arms M-5649-R1 (05-14 All) - Free Shipping
Contemplating which one i should get for street/daily driver. It would be great if i can get your feed back on nvh if you have own these.
13' Mustang GT, A6, Whiteline adj. phb & support brace, Roush a/b, Boss 302 brace, Pioneer door speakers, Alpine 10" 500 Watt RMS Amp and Sub, Michelin Pilot Super Sport
winkawak is offline   Reply With Quote
Old 10-19-2014, 07:20 AM   #2
The first one is garbage and is not an upgrade really. The second looks good as they have poly bushings. I'm not a fan of tubular control arms though. In my experience they transmit more noise then soild billet aluminum pieces like steeda.
Sent from my SM-G900T using Mustang Evolution mobile app
Mikeyt03 is offline   Reply With Quote
Old 10-19-2014, 07:22 AM   #3
And the second pair doesn't have grease fittings, which means they'll be a ***** to grease.
Old 10-19-2014, 07:28 AM   #4
AJcruz1's Avatar
Why not just a a set of BMR LCAs? They cost less and will work better than the ones your looking at. They will also be easier to grease.
http://www.americanmuscle.com/bmr-lca-poly-0512.html
AJcruz1 is offline   Reply With Quote
Old 10-19-2014, 09:41 AM   #5
Are you speaking about these?
Steeda Billet Mustang Rear Lower Control Arms - Polyurethane Bushings 555-4405 (05-14 All) - Free Shipping
Description says no nvh, really? abit expensive but if its true its well worth it. Also hows traction improvement compared to other lca's like the whiteline adj. lca with elastomer bushings?
BMR Mustang Rear Lower Control Arms with Poly Bushings - Hammertone Finish TCA019H (05-14 All) - Free Shipping
I heard they cause alot of noises and needed to be grease frequently. Are thereothere alternatives to increase traction with no nvh?
Old 10-19-2014, 10:01 AM   #6
I have zero nvh with the steeda piece. I couldn't believe it.
Old 10-19-2014, 10:10 AM   #7
Grabber Blue5.0's Avatar
BMR here. No NVH and my best 60' times are 1.5x. Yep, they work.
Old 10-19-2014, 10:34 AM   #8
How many miles have you had them on so far? how often do you need to regrease?
Old 10-19-2014, 10:43 AM   #9
25k on them. I've regreased them once. Going to regrease them wi the my next oil change
Old 10-19-2014, 10:49 AM   #10
Im really leaning towards these, its the only lca i have seen so far that saids no nvh in the description and has great traction performance gain.
You only regreased them once and they never squeaked? do they even require regreasing? whats the difference between aluminum vs steel lower control arms?
Old 10-19-2014, 11:26 AM   #11
AJcruz1's Avatar
I've had BMR LCAs on my six for 10K miles. I don't drive mines that much but I haven't greased them since I installed them. Just make sure you use the right grease. ( nothing with petroleum in it) Steeda is very good and you should go with them but if you want to save some coin then go with BMR over the others in your original post.
Old 10-19-2014, 11:45 AM   #12
WhiteCali5oh's Avatar
Region: West Virgina
May sound dumb but what is nvh
WhiteCali5oh is offline   Reply With Quote
Old 10-19-2014, 11:46 AM   #13
noise,vibration and harshness.
Old 10-19-2014, 12:20 PM   #14
Okay thanks
Old 10-25-2014, 12:23 PM   #15
14mustang's Avatar
If you have a performance package it has gt500 lower control arms already
14mustang is offline   Reply With Quote
Old 10-25-2014, 03:54 PM   #16
Tangster's Avatar
This is the cheapest billet LCA's for mustang. Last year's thanksgiving sale, this was around $150. I used this for almost a year with BMR reloc bracket with no issues.
http://www.latemodelrestoration.com/...r-Control-Arms
Tangster is offline   Reply With Quote
Old 10-25-2014, 03:55 PM   #17
14mustang's Avatar
those are nice. I got the performance package so I wouldn't need to do the suspension mods since they were already done
Old 10-25-2014, 04:04 PM   #18
Tangster's Avatar
I got 2013 pp as well. Can't compare it with this. However, I changed UCA and bracket with metco from ebay (lightly used) altogether. It feels very tight and planted with no noticeable increase in nvh. I just can't tell which one provides more impact, UCA or LCA as I changed it at the same time.
Old 10-25-2014, 04:11 PM   #19
14mustang's Avatar
You didn't like the gt500 lower Control arms? Alot of people upgrade to those and they are stock on pp. At least on the 14 ' s they were
Old 10-25-2014, 05:23 PM   #20
Tangster's Avatar
I guess I was hit by a mod bug. However, I only buy if I find bargain price of the parts I wanted. As far as the performance difference of a PP rear suspension and the mod I made, it's something that you can feel and tell that you made an upgrade. Ditching out those soft bushings from PP oem parts. I also choose the metco UCA as the arm can twist and looks very sturdy, relieving strain to the bushings when in corners or uneven pavements.
Old 10-26-2014, 07:50 PM   #21
20bmr14's Avatar
I went with Bob's lca. They look great. Greasable and zero nvh.
Roush Supercharger,Custom axleback,x-pipe,Barton short shifter with Blowfish trans bracket,Whiteline trans bushing,McCleod RXT twin disc clutch w/billet steel flywheel,Steeda braided clutch line,Steeda g-force brace,BMR cradle lockout braces and bushings,Whiteline front sway bar,SR rear sway bar,SR rear vertical links,MM camber plates,Mich Pilot SS 255/305,Roush rear spoiler and hood heat extractors,and Ford Performance hood shocks,JLT oil separator,Flossy heavy weight shift knob
20bmr14 is offline   Reply With Quote
Old 10-28-2014, 11:50 AM   #22
14mustang's Avatar
I haven't had any vibrations from.mine. I use white lithium grease on all my rubber bushings.
Old 10-28-2014, 08:54 PM   #23
c_rizzle's Avatar
I have the top ones. When I took off my stock ones, the new ones looked very similar, but I think the difference mostly is in the durometer level / hardness of the rubber bushings.
It felt a little stiffer, but wasn't world changing. It felt like the tires just spun instead of spin, then hop, then spin, etc..
c_rizzle is offline   Reply With Quote
Finally own my own mustang clx182 New Member Introductions & Greetings 5 05-06-2014 09:12 PM
Anybody use these or have used these 04__gt 1996-2004 Mustang GT 19 08-25-2013 02:04 PM
Do you have to be certified to open your own auto shop? shawn General Mustang Discussion 1 03-08-2010 02:47 AM
Have you ever been guilty of judging others you own age? roselyn The Bar 5 03-02-2010 09:03 AM
What Fox-bodies have you, or do you, own? 427windsorman Mustang Audio & Video 8 02-11-2004 02:05 PM
05:02 AM
