688RWHP!! E85 is the "magic gas!" - Mustang Evolution
Old 10-21-2014, 01:38 AM   #1
Camron502's Avatar
So I took my 2013 Roush Stage 3 to Shaun at AED for a final dyno tune and an E85 swap. All I can say is WOW!
First of all, Shaun provided great customer service and dialed the car in on 91 octane. The car put down 627rwhp but had to be dialed back to 604rwhp due to our terrible quality gasoline in the state of California. After the third pull safely put down 627rwhp, the car started having issues with the fuel and started pulling timing at around 6500 rpm. I purchased that 91 octane "v-power" from a local Shell Station which I thought would be the best fuel in my area but it turned out to be crap. Shaun pulled some timing out of the tune for safety and inconsistencies in fuel and that is why the car ended up at 604rwhp. To me that still exceeded my expectations and I was very happy with the result.
Now for the best part, E85!!!! As Shaun calls it "magic gas!" E85 is an incredible fuel for forced induction applications. On E85 Shaun was able to add 9.5 degrees of timing and put down 688rwhp and 605 lb/ft of torque. The car absolutely loves that stuff. It runs smoother and pulls like a freight train now, at the same time it's safer for the engine and runs cooler. The closest E85 is 22 miles from my house but the benefits are well worth it. The car is not a daily driver so it's no big deal. I will probably never switch back to gas.
http://youtu.be/nXpUrpRnBPw
2013 Roush Stage 3 M6 Roush CAI, 82mm pulley, ID1000's, KB BAP, Vossen CV3 20x9-20x10.5, Michelin Pilot SS, Lethal O/R X, GT500 axleback, Barton Shifter with 2-post bracket, Clutch Line Upgrade, Boss Trans Cooler, Dynotech Aluminum Driveshaft, BMR Driveshaft Loop, Whiteline Trans Bushing, BMR LCA's with Relo Brackets, Adjustable Panhard Bar, GT500 STB, Steeda X-Brace, Steeda rear sway, JLT Oil Separator, GT500 Diff Cover, Afco Heat Exchanger, 170* T-stat, Tint, RP Fluids, aeroforce interceptors///688rwhp 605lb/ft torque cornfed
Camron502 is offline   Reply With Quote
Old 10-21-2014, 04:20 AM   #2
Rapinator126's Avatar
What fuel system?
Rapinator126 is online now   Reply With Quote
Old 10-21-2014, 04:24 AM   #3
Camron502's Avatar
No fuel system... 2013's are E85 compatible so my mods are ID1000 injectors and a Kenne Bell 40amp 20 volt competition series boost-a-pump
Old 10-21-2014, 04:30 AM   #4
I know they are compatible.
Just interesting that you made 688 with the stock fuel system on e85.
You are one of a verry few
Old 10-21-2014, 04:34 AM   #5
What CF did Shaun use?
Old 10-21-2014, 04:34 AM   #6
Camron502's Avatar
I really don't think I am one of very few. Shaun said my car made pretty much exactly what he expected with his experience, and I had plenty of fuel at 7600 rpm on E85 with that setup.
I could be wrong as I am new to E85, but from my research there are plenty of others making the same.
Old 10-21-2014, 04:38 AM   #7
Well I know from personal experience, without a return style fuel sytem all the fuel gets sucked out of the rails on the hit, on e85 once you start getting mid 600's and up.
Thats why I'm curious on what CF his run was done it
Old 10-21-2014, 04:40 AM   #8
Camron502's Avatar
CF?
Old 10-21-2014, 04:40 AM   #9
Correction factor.
SAE or STD
Old 10-21-2014, 04:41 AM   #10
Camron502's Avatar
SAE Corrected
Old 10-21-2014, 04:41 AM   #11
Interesting
Old 10-21-2014, 04:43 AM   #12
Camron502's Avatar
Shaun told me 711RWHP STD
Old 10-21-2014, 04:46 AM   #13
Yes SAE #'s are about 4% lower than STD
Old 10-21-2014, 08:02 AM   #14
Renuco612's Avatar
Which shop is this guy located at? I'm also from California and looking for a mustang specialist to work on my car.
Sent from my SAMSUNG-SM-G900A using Mustang Evolution mobile app
Renuco612 is offline   Reply With Quote
Old 10-21-2014, 08:23 AM   #15
Brockman66's Avatar
Does E85 only give gains to forced induction cars or would my N/A car benefit from it as well. I live in Pennsylvania and every Sheetz gas station around me has E85. I know you get worse gas mileage on E85 but it's also cheaper than premium gas so I'm sure it'd offset the bad gas mileage.
____________________________________________________________
EDIT:
Actually, edmunds.com did a test and concluded that even though E85 is less to fill up, due to the 20-25% decrease in mileage, you're still going to spend ~22% more on E85 than you would regular if you use it constantly. (I'm sure the savings would be a little less since we use premium)
Brockman66 is offline   Reply With Quote
Old 10-21-2014, 08:30 AM   #16
Joaquin_ii's Avatar
how bad does it affect the gas milage?
Joaquin_ii is offline   Reply With Quote
Old 10-21-2014, 09:03 AM   #17
Brockman66's Avatar
Supposedly its supposed to be ~20-25% less than the CITY/HIWY MPG on your widow sticker. That's for flexfuel vehicles though so I'm not sure about non-flexfuel vehicles. Maybe the OP can weigh in on this...
Old 10-21-2014, 10:26 AM   #18
steven7010's Avatar
Do u know if the 2012s equip for e85?
steven7010 is offline   Reply With Quote
Old 10-21-2014, 10:32 AM   #19
Yes it's the exact same thing as a 14.
And NA gains all depends on how much timing you add.
I gained 26 hp and 21tq on motor alone.
And over 700 on nitrous
---------- Post added at 11:32 AM ---------- Previous post was at 11:31 AM ----------
* And made over 700 with nitrous and e85.
Old 10-21-2014, 11:36 AM   #20
steven7010's Avatar
Nice the only problem is I travel for work and I end up in them small towns errrrrrrrrr
Old 10-21-2014, 11:59 AM   #21
Shingle Springs, just on the northern skirt of Sacramento.
Old 10-21-2014, 12:06 PM   #22
bigmac3's Avatar
Originally Posted by Camron502 View Post
No fuel system... 2013's are E85 compatible...
Both of mine have a sticker on the fuel door that says absolutely no E85, is that a Ford CYA or are they not all compatible.
Frank
1989 Blue LX Hatchback
2001 Red SVT Cobra Convertible (Phoenix)
2002 Black/Red GT (Ginger)
2011 Red Candy Metallic V6 (Manfred)
2016 Magnetic Metallic GT (Susie II)
bigmac3 is offline   Reply With Quote
Old 10-21-2014, 12:27 PM   #23
It's pretty much that E85 is a different type of fuel, since it runs about 30% more than regular fuel, the fuel system needs to be upgraded a little bit..... That sticker is more for the average joe filling his tank thinking he can save money.
Old 10-21-2014, 02:28 PM   #24
bigmac3's Avatar
I thought E85 is about 30% cheaper than regular. It just gets less mileage. I know it's corrosive to non-stainless and certain rubber components.
Frank
Old 10-21-2014, 02:36 PM   #25
It's cheaper but honestly ends up costing more in the long run, you have to change your oil alot more often also.
Race gas over E85? 2003mustangGT General Mustang Discussion 5 12-20-2013 01:11 PM
Has anyone filled up with E85 105 Octane gas? Vash Pre-2005 V6 Mustang 5 01-05-2006 08:08 AM
"Magic Nickel" Seph The Bar 3 06-02-2005 05:45 PM
Mr. Clean Magic eraser??? Hoover The Bar 3 03-04-2005 06:23 AM
03:41 PM
