MGW STS, Whiteline Mount, Spring Delete - Mustang Evolution
Old 10-22-2014, 04:13 PM   #1
Laquisha's Avatar
Okay so a few days ago I purchased a Whiteline Mount, and a MGW Short Throw Shifter.
The Whiteline Mount just arrived
Name:	ImageUploadedByMustang Evolution1414015887.615937.jpg
Still waiting on the MGW Short Throw Shifter which should be here around noon tomorrow.
I'm installing them tomorrow along with the "Clutch Spring Assist delete" Aka removing the spring in the clutch so I don't get locked out of 7.4K shifts.
I'll keep you guys updated on how this stuff works out and to see if the Whiteline mount was really worth the $30.04. 😄
Stay tuned,
- Trevor
Old 10-22-2014, 04:18 PM   #2
Laquisha's Avatar
Name:	ImageUploadedByMustang Evolution1414016281.318946.jpg
Old 10-24-2014, 11:27 PM   #3
Rufeo's Avatar
Where did you buy the mgw shifter btw? Looking forward to seeing your mustang after all the mods.
Sent from my SM-N900V using Mustang Evolution mobile app
Rufeo is offline   Reply With Quote
Old 10-24-2014, 11:28 PM   #4
Laquisha's Avatar
Everythings on. and their site lol...🙊Shifts perfect! Power up the whole band.
Old 10-24-2014, 11:31 PM   #5
Rufeo's Avatar
Oh sick! I saw a couple of threads on your mods and was thinking how badass the cars going to be. Get some vids up!
Old 10-24-2014, 11:44 PM   #6
Fastlane13's Avatar
Any specifics on the improvement in the shifting? Did you install it or a shop? Details please...
'13 Fastlane Stage 3 Whipple-JLT 127-FRPP Springs-GT Quad-20"True Forge Chicanes-Custom Katskin Interior-Etc...
2013 Mustang GT Fastlane Stage 3 Race Red-Matte Black GT 500 Stripes-2.3 Whipple-20" TF Chicanes-R888's-Brembos-Slotted/Drilled-Custom Katskin interior-Suspension and other goodies...603/498 http://youtu.be/wa73L4lF3Ws
Fastlane13 is offline   Reply With Quote
Old 10-25-2014, 05:58 PM   #7
hobo1's Avatar
Smile
I installed the MGW about 2 months ago. Reviewed their video for the 2014 redesign about 5 times. When it came in, I hardly needed the instructions. Take your time. I jacked at the factory body jack points then put stands under and raised them another inch or two by putting a block under the jack I was using. I may have backed up onto ramps first (?). I was done in a half day, but didn't work the whole time. I found you could use 1/4 or 3/8 drives and switch up extensions and use the new ratcheting "box end" wrenches for some of it. I use the Street durometer bushing. Adjusting for reverse and 1st was easy - just barely moved the set bolt and tested the feel before I closed it all up. Heat shield was a snap. Hardest part might have been putting on the sound deadening on the shift shaft far end (optional).
For your test drive, you won't want to get out of the car. Warning-- It'll make you want to ask your buddy to drive it!
hobo1 is offline   Reply With Quote
Old 10-25-2014, 06:02 PM   #8
Laquisha's Avatar
Shop installed (1-2 Hr install time) $ The whiteline mount helps ALOT. The gears are always where you need them to be and easy to get in the gear with the short sturdy shifts. + The clutch spring delete is letting me easily shift high RPMs with my CJ Setup.
just installed Whiteline transmission mount insert on my 2014 GT/CS (pics inside) Devil 2011-2014 Mustang GT 7 10-12-2014 03:05 PM
Whiteline Transmission Mount Bushing insert???? 2014GT 2011-2014 Mustang GT 16 05-30-2014 04:37 AM
Whiteline trans mount gtstyles2 2011-2014 Mustang GT 16 03-27-2014 12:18 PM
whiteline trans mount GypsyChris 2011-2014 Mustang GT 12 12-15-2013 09:06 AM
Sts System Or Supercharger?? mustangmaniac Pre-2005 V6 Mustang 7 10-27-2006 09:29 PM
10:40 AM
