To those with 3.73 gears... - Mustang Evolution
Old 10-25-2014, 11:27 AM   #1
Mustang Coyote's Avatar
What kinds of sounds so you hear with these in the very low (500-1500) and higher up (3500+) RPMs. I hear an almost rattle like noise that is coming from the rear when I go to take off in 1st sometimes(differential?). Perhaps when my RPMs are low. And higher up I hear a grinding noise around 3600 that is around the transmission area (clutch?) also, when I go to accelerate fairly hard, the car feels as it is almost bouncing back and fourth during acceleration sometimes (clutch slipping with 50K on stock one?). Please give me your input on my symptoms and any you might have as well. I want to know if it's normal or needs to be taken in. Thanks!
Mustang Coyote is offline   Reply With Quote
Old 10-25-2014, 11:32 AM   #2
kingstrider's Avatar
My car barely has 1300 miles. No noises outside of the ordinary though I probably wouldn't hear it over the exhaust anyway.
2014 Grabber Blue Mustang GT Premium with nav, RR and comfy packages, 3.73 limited slip axle and optional 19" machined aluminum wheels. Come hang out in the garage and check out my build so far!
kingstrider is offline   Reply With Quote
Old 10-25-2014, 12:07 PM   #3
TommyV's Avatar
That's not normal, get it checked.
'13 5.0 PW Premium / E-Force Supercharger w/ Brenspeed tune / FRPP Recaro's / GT500 quad exhaust / DSS Aluminum / Stop Tech 6P 15" / 13" rears / LP over axels / MGW / Moroso separator / 3:73's / Forgestar F14's 20x9/20x11 w/ Nitto Invo's 275/35's & 315/35's / Steeda Sport springs / Koni STR.T's / Steeda PHB / GT500 Spoiler / Roush upper and lower grills / Stillen front splitter / Boss steering wheel
TommyV is offline   Reply With Quote
Old 10-25-2014, 01:20 PM   #4
hobo1's Avatar
3 types after moving to frpp handling kit and getting noise 1., took it into stealership and they rebuilt rear, and now 2, and 3. Whine, howl and a light metal scraping sound. They assure me all is okay. 4 trips in. Not happy, but I play tunes and usually have windows down
hobo1 is offline   Reply With Quote
Old 10-26-2014, 05:29 PM   #5
JoeM1494's Avatar
No weird noises or anything at all coming from mine. 13k miles in.
Joe
'13 GT Track Pack
JoeM1494 is offline   Reply With Quote
Old 10-26-2014, 05:38 PM   #6
Travis238's Avatar
My stock clutch on my 03 v6 went out at 65000. Could be a clutch. Sounds like a clutch to me.
2005 Roush GT, Roush cai, BAMA 93r tune
Travis238 is offline   Reply With Quote
Old 10-26-2014, 05:46 PM   #7
Laquisha's Avatar
No noises. 3.73s
Old 10-27-2014, 06:31 AM   #8
2011 Kona Blue's Avatar
No noise here. All nice and quiet.
Sent from my SCH-I535 using Mustang Evolution mobile app
Old 10-27-2014, 08:00 AM   #9
c_rizzle's Avatar
If you put them in aftermarket you have to be sure everything is shimmed properly. Also, you should add the friction modifer stuff it will help reduced that "gear chatter".
c_rizzle is offline   Reply With Quote
Old 10-27-2014, 08:04 AM   #10
I haven't heard anything out of the ordinary. It sounds like it may be a clutch issue?
SpeedAKL is offline   Reply With Quote
Old 10-27-2014, 11:33 AM   #11
Double that. Even though the Royal Purple gear oil comes with friction modifier in it , my installer still used the Ford racing friction motifier as well.
Old 10-27-2014, 11:41 AM   #12
Rapinator126's Avatar
A little gear whine never hurt anyone. Your not driving a high end car, it will be ok.
Old 10-27-2014, 11:48 AM   #13
Lmao. JK bro. I found the pic funny.
Old 10-27-2014, 12:49 PM   #14
Lol
Old 10-28-2014, 04:58 PM   #15
get a bottle of positive traction gear grease additive !! NOW it will definitely help if not solve the issue. im a 20 plus yr mechanic, i speak fr experience. its at advance auto parts,$8.89 , if it doesnt quit, get it to ur tech asap or itll cost you big!
waynepeyton11 is offline   Reply With Quote
Old 10-28-2014, 05:27 PM   #16
JoeyM91's Avatar
Yep, about 3-4k miles since my swap. No noises. I replaced everything but the differential itself though. I went with the friction modifier as well. Cheap insurance.
Old 10-28-2014, 06:42 PM   #17
DallasStang77's Avatar
I just swapped out from 3.31 to 3.73 gears. There's whining on deceleration only from 35mph but no whining on acceleration.
I got a reputable shop called True Street Motorsports in McKinney, TX to work on it.
They're saying that possibly the LCAs that I have with the spherical bushings are transferring more NVH than a stock LCA.
Other than the noise the differential is smooth as butter. No thrashing or grinding. Nothing metallic clunking. Just finished putting 120 miles of tender driving on them.
The tech explained also that the ring gear is bigger (or has more surface area) so something about the pinion and the ring gear has inherently more NVH and depending on your set up it can have more NVH than others.
They advised that it's fine and give it a few more miles to properly let the gears break in and it may get better once the teeth are polished out when broken in.
Old 10-28-2014, 06:44 PM   #18
yes do some more driving but the gears break in adequate and down don't worry about it sounds normal
Old 10-28-2014, 06:44 PM   #19
JoeyM91's Avatar
Check your rear axle bearings as well. I had whining on deceleration prior to the swap and had them replace those while they were at it.
(Had a visible leak from the seal as well). The noise completely stopped after the swap.
Old 10-28-2014, 06:50 PM   #20
They replaced the pinion bearing and used royal purple. I'll let the gears break in and see if anything changes. I'm not too picky on the NVH just so long as it doesn't explode on me when I finally get to romp on the gas again. Lol
Old 10-28-2014, 06:52 PM   #21
JoeyM91's Avatar
Yeah I had them replace all of the bearings, seals and clutch packs, but since my car was 60k miles and had a visible leak I threw in the axle bearings since they had to pull those axles to remove the c clip anyway. Glad I did lol
Old 10-28-2014, 06:56 PM   #22
Oh snaps. Well I guess I'll get that replaced when I put in my one piece DS lol.
Well I guess whining doesn't really hurt or anything. None of the dozens of threads I've read came out and said "my Stang's *** end blew up and sent shrapnels everywhere."
Old 10-29-2014, 06:39 AM   #23
Sounds like explosive diarrhea, or the aftermath of anal.
Old 10-29-2014, 08:38 AM   #24
You sir have a very very VERY sick taste in porn. You should watch Two Girls and One Cup
Old 10-29-2014, 09:03 AM   #25
No thanks. I don't need to see that crap.
Old 10-29-2014, 09:14 AM   #26
Pun intended?
Old 10-29-2014, 09:18 AM   #27
Pun intended?
Actually no. Now that's disturbing
Old 10-31-2014, 11:42 AM   #28
absherk's Avatar
Noise free other than normal driveline gear stacking.
absherk is offline   Reply With Quote
Old 11-07-2014, 09:34 PM   #29
tazor's Avatar
no noise's just rumbling from my flowmasters
tazor is offline   Reply With Quote
Old 11-11-2014, 09:29 PM   #30
Konawin's Avatar
My 2c - I had a metal on metal rattle at times after some mods so I got underneath it with a mechanics stethoscope and a buddy revving the engine up and found my exhaust hanger rubbing on part of the nearby body. I zip-tied a rubber hose around the hanger and it's never made another rattle.
Konawin is offline   Reply With Quote
Old 11-12-2014, 01:49 PM   #31
c_rizzle's Avatar
Handling kit has a few stiffer suspension parts it might be those parts making the noise. You pay a little price for the higher performance.
Also, it lowers everything 1" so you might want to verify the pinion angle is correct. That might cause some additional noise from the driveshaft/pinion.
Old 11-12-2014, 05:55 PM   #32
hobo1's Avatar
I agree. That's why I'm looking into new LCAs an adjustable UCA and new bracket (sound like BMR ?). Should help with new LCA busing squeak, which might have been caused as by product of lowering with some hard starts. And will help get the pinion angle back to spec.
Before taking the dive, want to contact dealer to see if, 1) they'll install, 2) impact to drivetrain warranty, 3) if they don't install and I do, will that affect dt warranty. This car has a history of being in their shop for track pack 3.73 noises, following the Ford install of the FR3A handling kit.
Old 11-12-2014, 06:48 PM   #33
Noise is not normal, FRPP gears do not need to break in, they should be dead silent from the get go. Whoever you had do the install ****ed up. Take it back to the shop and get them re-done or have a mechanic that does not have his head all the way up his *** re-do them.
Difference between 2.3 rear axle gears and 5.0 rear axle gears 93mstnglx 2.3 Mustang 9 07-07-2013 05:12 PM
4:10 gears vs 4:30 gears SwatKatz901 1996-2004 Mustang GT 5 03-24-2012 03:17 PM
3:55 Gears vs 3:73 gears 06Blue 2005-2010 Mustang GT 19 01-04-2012 06:57 PM
NEED HELP WITH GEARS!! Motive 4.10 gears? Cant find ford racing? Camaro Eater Pre-2005 V6 Mustang 4 06-23-2010 10:57 AM
Factory Gears Vs. Racing Gears tire Pre-2005 V6 Mustang 0 07-21-2003 04:02 AM
08:12 PM
