Smell oil burning thru interior air vents after oil change - Mustang Evolution
Old 10-25-2014, 06:31 PM   #1
Has anyone had this problem after a oil change from the dealer I put almost 50 miles on & I keep getting a faint oil smell coming thru my air vents
dentman43 is offline   Reply With Quote
Old 10-26-2014, 01:21 AM   #2
Abominable Mustang
WhoDat's Avatar
Region: Alaska
They may have spilled a bit of oil somewhere in the engine bay when doing the oil change, and that may be what you're smelling.
2012 Kona Blue 3.7L V6:
Old 10-26-2014, 05:52 AM   #3
Oil, when pulling the filter gets all over.
bodon is offline   Reply With Quote
Old 10-26-2014, 03:25 PM   #4
MP187's Avatar
Shouldn't be anything to worry about unless they didn't tighten the filter all the way.. look under your car after a drive and see if anything looks like it's leaking ......
But most likely I bet they spilled it when they filled it up or changing the oil filter... another reason I do my own services.. nobody will cherish your vehicle as well as you will... I just did my oil change Saturday and went out driving.. no odor at all..
Sent from my SM-N900A using Mustang Evolution mobile app
MP187 is offline   Reply With Quote
Old 10-26-2014, 09:36 PM   #5
ddtmoto's Avatar
Region: Utah
Yup, no one cares more for my car than me. Ford tech spilled oil around the filler when he was dumping in the new oil. He left out a cover screw for the filter access panel too. Took me an hour to clean up his mess around and down the passenger valve cover/head. They only charged me 11 for labor and 5 for the filter since I brought in my own oil, I only needed a state emissions and yearly state inspection but I thought while I was there... Didn't turn out so good for my OCD. I won't be back. I will continue to do my own oil changes.
ddtmoto is offline   Reply With Quote
Old 10-26-2014, 10:37 PM   #6
Ya I will be doing my own oil changes for now on
Old 10-27-2014, 08:04 AM   #7
MP187's Avatar
---------- Post added at 02:04 PM ---------- Previous post was at 02:04 PM ----------
So much better that way...
Old 10-27-2014, 08:36 AM   #8
hctr154's Avatar
Just a couple of drops of oil on the header pipes can smell for a while...
hctr154 is offline   Reply With Quote
Burning Smell? TheBlackStang 2011-2014 V6 Mustang 23 10-10-2013 12:13 PM
Oil burning/lots of air coming from oil cap tage 1996-2004 Mustang GT 5 12-18-2012 06:55 PM
Burning smell Dogbitdude Pre-2005 V6 Mustang 5 10-03-2012 09:17 PM
burning smell GTKidd53 General Car Discussion 9 01-01-2012 09:45 AM
Burning smell? 98projectpony Pre-2005 V6 Mustang 4 12-09-2011 06:59 PM
09:52 AM
