Putting Cats back on 2014 GT - Mustang Evolution
Old 10-25-2014, 08:52 PM   #1
I deleted my cats on Thursday and have driven the car about 100 miles (no tune) and I don't like the way car sounds/smells... if I put back on my cats on Monday (probably another 40 miles driven) will I have damaged anything? And will my car continue to dump gas or will the sensors and everything work properly once more? Also will the CEL turn back off?
kaveh14GT is offline   Reply With Quote
Old 10-25-2014, 10:26 PM   #2
zinc03svt's Avatar
Oh boy...
Permanent engine damage. Lol.
You will need scan tool or device to clear code. Why would you delete your cats without tune? And then decide it smells bad? Did you do a search on this before removing your cats? Your car will be fine. Wow...
2014 "Cobra Jet" GT/CS
Automatic, Comfort pkg, Oxford White
zinc03svt is offline   Reply With Quote
Old 10-25-2014, 10:40 PM   #3
I knew it would smell bad but the sound isn't quite what I was expecting.... so the code won't go away by putting back in the stock Cats? If not where can can get a scan tool or device to clear it
Old 10-25-2014, 11:21 PM   #4
If you put the cats back on and drive the car for a while the CEL will turn off once the sensors go through a cycle and realize that the cats are back on and it is in fact reading within the range.
You can also try disconnecting the battery to reset the computer. Or any auto parts store can read the code but some of them can be weird about clearing codes. Although you can tell them you had replaced the cats and they will probable clear it for you
StarzTA17 is offline   Reply With Quote
Old 10-26-2014, 05:48 PM   #5
Laquisha's Avatar
Guessing Google doesn't work in Africa.
Old 10-27-2014, 03:05 AM   #6
kingstrider's Avatar
Auto parts stores can be iffy when clearing the codes, some will and some won't. Another option is to buy your own OBD II/CAN tool and clear the code yourself. I bought one for around $100 and have found it useful in both of my cars.
2014 Grabber Blue Mustang GT Premium with nav, RR and comfy packages, 3.73 limited slip axle and optional 19" machined aluminum wheels. Come hang out in the garage and check out my build so far!
kingstrider is offline   Reply With Quote
Old 10-27-2014, 02:20 PM   #7
Laquisha's Avatar
To be honest I enjoy the smell of no cats.
Old 10-27-2014, 03:27 PM   #8
Rapinator126's Avatar
Try it with e85 hahah
Old 10-28-2014, 04:56 PM   #9
Took into the shop today, cats back on... The shop reset the ECU for me so the lights off too... Lesson learned
Old 10-29-2014, 06:05 AM   #10
REG
CEL/MIL Light
If you replaced the cats and everything is still right they should clear them selves very quickly. Most sensors (MAP, MAF, EGR) will clear themselves once the computers sees the correct values.
It s only the evap system codes that take a long time to clear, as it doesn't check every key cycle, usually every 5 - 6 but can take a month to clear itself.
REG is offline   Reply With Quote
xpipe... cats, no cats, *scratches head* A5295 1979-1995 Mustang GT 33 03-07-2017 01:41 AM
Putting cats back on. CEL? black9D5 2005-2010 Mustang GT 2 01-09-2013 12:58 PM
NEED HELP PUTTING DRIVE SHAFT BACK IN TRANSMISSION!!!!? sidney16 1979-1995 Mustang GT 2 12-16-2011 09:48 PM
Putting my x pipe back on 04machazblue 1996-2004 Mustang GT 15 03-10-2011 09:30 AM
Cats or no cats that is the question StreetRacer4371 1979-1995 Mustang GT 34 01-14-2011 09:07 AM
04:49 AM
