Problem with Supercharger!! - Mustang Evolution
Old 10-25-2014, 10:33 PM   #1
BoostedStang's Avatar
I was am driving around and hit the gas and felt no power vs before. You can hear the supercharged but no power at all, feels like a Stock 5.0 any help on what it could be?
2014 5.0 Auto - Vortech V3 Supercharger, UPR X-Pipe, Lund 93oct Tune, & Bassani Axle backs
BoostedStang is offline   Reply With Quote
Old 10-25-2014, 10:41 PM   #2
Perhaps it's your adaptive shifting. Try pulling fuse #47 and plug it back in after 10 minutes. I doubt that's your issue but its worth a shot.
Sent from my iPhone using M
KushBandit is offline   Reply With Quote
Old 10-26-2014, 04:44 AM   #3
Grabber Blue5.0's Avatar
LOL at pulling a fuse. Yea that will work.
Did you check the belt? Any of the connections come loose?
Old 10-26-2014, 05:45 AM   #4
kingstrider's Avatar
Surely you have a boost gauge, is it making boost? If not then you may want to start with blow off valve. How long have you ran the SC before having problems?
2014 Grabber Blue Mustang GT Premium with nav, RR and comfy packages, 3.73 limited slip axle and optional 19" machined aluminum wheels. Come hang out in the garage and check out my build so far!
kingstrider is offline   Reply With Quote
Old 10-26-2014, 08:02 AM   #5
Deerslayer's Avatar
You blew a hose off. Did you get the T-Bolt clamps? If not, they are a wise investment. You can not tighten the worm drive clamps near tight enough IMHO. If it was a belt, you would be dead in the water. I am sure it is your charge piping between your intake and intercooler.
All the more reason a boost gauge is vital.
2013 GT : 6sp MT, Track Pkg, 3.73 Rear End, Brembo Brakes, Vortech V3 SC, Boss IM, BBK 90mm TB, JLT CAI, ID1000 injectors, BAP, Brisk Plugs, Tial BOV, Lethal OR X Pipe, 3" over axle to GT500 Quad Exhaust, Dynotech Alum DS, MGW Shifter, Eibach R2 Coil Overs, Bob's Billet LCA's, UPR adj. UCA, Eibach Adj PH Bar, TruCarbon Carbon Fiber inside/out. Tuned by Jon Lund II Three salvaged Bosses worth of Parts live on in this car. 705.11rwhp 5.33pulley/Torque Booster Wastegate
Deerslayer is offline   Reply With Quote
Old 10-26-2014, 09:06 AM   #6
I got t-bolts
Old 10-26-2014, 04:41 PM   #7
Deerslayer's Avatar
Did you figure out what was up?
Old 10-26-2014, 04:45 PM   #8
Yeah I remove my front bumper and one of the pipe slide off 😑
---------- Post added at 10:45 PM ---------- Previous post was at 10:44 PM ----------
Now it's back on doing 60mph burnout 😬
Old 10-26-2014, 05:46 PM   #9
Deerslayer's Avatar
lol......I figured it was a charge pipe. If one of ours blows, there is some serious pressure because I was anal about making sure there was plenty of coverage and those T-Bolts were tightened with an air ratchet, so...........Install you a boost gauge. This will inform you of a problem and help you to diagnose it pretty easily.
Old 10-27-2014, 08:05 PM   #10
Thanks
Old 10-28-2014, 12:33 PM   #11
Voltwings's Avatar
Blow though MAF saves the day haha. Nothing worse than blowing a charge pipe when draw though and having a car that doesnt run.
Big problem-easy find, small problem-hard to find Dnraiders General Mustang Discussion 0 08-30-2011 11:10 AM
supercharger el cheapo Pre-2005 V6 Mustang 0 08-20-2003 10:34 PM
$200+ complete supercharger, help Stang01 Pre-2005 V6 Mustang 3 07-20-2003 04:07 PM
Supercharger or Nitrous? ERICK Pre-2005 V6 Mustang 8 05-12-2003 02:41 PM
12:17 AM
