Question about removing rear differential - Mustang Evolution
Old 10-26-2014, 05:49 PM   #1
kingstrider's Avatar
I've been putting this off for a while but want to remove the rusty rear end and driveshaft to paint these parts. I'm going to use POR-15 and replace the stock cover with the FRPP girdle cover. I will probably upgrade the upper and lower control arms while I'm at it. My question is can this be done without disconnecting the brake lines? As in removing the calipers and suspending them then unbolting everything else?
2014 Grabber Blue Mustang GT Premium with nav, RR and comfy packages, 3.73 limited slip axle and optional 19" machined aluminum wheels. Come hang out in the garage and check out my build so far!
kingstrider is offline   Reply With Quote
Old 10-27-2014, 08:25 AM   #2
Yes you can. Just make sure you suspend the calipers as you stated, the flexible brake lines are very short.
Current Mustang: '14 GT/Track Pack/6spd-sold
Previous Mustangs: '68 Coupe, '73 Mach 1, '89 GT,
Hoss is offline   Reply With Quote
Old 10-27-2014, 08:45 AM   #3
bigmac3's Avatar
^ +1
Frank
1989 Blue LX Hatchback
2001 Red SVT Cobra Convertible (Phoenix)
2002 Black/Red GT (Ginger)
2011 Red Candy Metallic V6 (Manfred)
2016 Magnetic Metallic GT (Susie II)
bigmac3 is offline   Reply With Quote
Old 10-27-2014, 09:43 AM   #4
Cool that's what I was thinking after doing the rear shocks and springs but wanted to double check. Any idea of how much the assembly weighs? Just wondering how to best maneuver it around the garage for painting.
Old 10-27-2014, 09:51 AM   #5
bigmac3's Avatar
Probably around 150-200 lbs. Two floor jacks would work great.
What is your goal here as these are features that are rarely visible? The surface rust coat is an initial reaction to weather and actually will protect the base metal. If you are concerned that this is the same as sheet metal rust (car cancer) and your rear end will fall apart, you may rest safe. That will not happen.
Frank
Foxbody Rear Differential Question crroy71 1979-1995 Mustang GT 14 04-17-2014 06:04 AM
1998 'stang needs ALL o2 sensors and rear differential replaced xxmustang98xx Pre-2005 V6 Mustang 12 08-09-2009 10:22 PM
Rear Differential, 1998 Mustang Sam09 Pre-2005 V6 Mustang 3 04-06-2009 12:55 PM
3.27 Rear gears with open differential for 7.5 SpectorV Mustang Parts for Sale and Wanted 0 11-19-2004 08:51 AM
02:15 PM
