Eibach pro street coil overs and J&M camber plates noise - Mustang Evolution
Old 10-27-2014, 06:30 PM   #1
14greystang's Avatar
I have 14 gt with eibach pro street coil overs and J&M camber plates. I am getting a metal on metal noise when going slow through parking lots and streets. I have checked all suspension bolts and all tight. It seams that the noise is coming from the strut mount and shock tower. I have the springs in the front on lowest setting and tucking front tires. Has anyone else experienced this sound? Also wondering if I could buy a this rubber sheet and cut it out to match the camber plate and put it between shock mount and tower to dampen the noise, anyone done this?
14greystang is offline   Reply With Quote
Old 10-27-2014, 06:39 PM   #2
JoeM1494's Avatar
I had this problem on a previous car of mine that I installed camber plates on the Coilovers of after the fact. The company continuously told me it was because I didn't tighten the top nut holding everything together tight enough. I sent the Coilovers out to them to be checked out they said they were up to par and sent them back. I installed them again and the noise was still there. I never got around to trying anything else but that padding idea would be a good way of trying to narrow it down. If it still occurs then you know it isn't that. Try adjusting the dampening if it's too stiff or too soft it could have something to do with it as well.
Joe
'13 GT Track Pack
JoeM1494 is offline   Reply With Quote
Old 10-27-2014, 06:41 PM   #3
JoeM1494's Avatar
Could also be something to do with the preload. Could be all out of wack from taking the coilover apart to install the camber plates. I would say take them off the car and trial and error. Just make sure everything's all snugged up.
Joe
'13 GT Track Pack
Old 10-27-2014, 06:42 PM   #4
Thanks
Old 10-27-2014, 07:57 PM   #5
Deerslayer's Avatar
My bad.
They should not make any noise though. Something is not right if you are getting metallic noises especially.
2013 GT : 6sp MT, Track Pkg, 3.73 Rear End, Brembo Brakes, Vortech V3 SC, Boss IM, BBK 90mm TB, JLT CAI, ID1000 injectors, BAP, Brisk Plugs, Tial BOV, Lethal OR X Pipe, 3" over axle to GT500 Quad Exhaust, Dynotech Alum DS, MGW Shifter, Eibach R2 Coil Overs, Bob's Billet LCA's, UPR adj. UCA, Eibach Adj PH Bar, TruCarbon Carbon Fiber inside/out. Tuned by Jon Lund II Three salvaged Bosses worth of Parts live on in this car. 705.11rwhp 5.33pulley/Torque Booster Wastegate
Deerslayer is offline   Reply With Quote
Old 10-27-2014, 08:00 PM   #6
I have pro street coil overs
Eibach pro coil overs & Caster camber plates grabber12 2011-2014 Mustang GT 8 03-27-2015 05:40 PM
h&r club sport coil overs Marc3.71994 2011-2014 V6 Mustang 11 01-16-2013 01:27 PM
Eibach Pro-System-Plus vs. Eibach Sport-System-Plus MustangGT02 1996-2004 Mustang GT 15 01-12-2013 02:45 PM
Caster Camber Plates or Camber Bolts OutlawGT 2005-2010 Mustang GT 18 04-05-2012 04:55 PM
Changing plugs and coil overs 06' 3v GT buck199 2005-2010 Mustang GT 8 05-21-2011 09:38 PM
05:15 PM
