Installing suspension questions - Mustang Evolution
Old 10-31-2014, 08:03 PM   #1
I'm trying to assemble my front suspension for installation. The parts I got are 05-10 Koni Yellows, 11-14 Eibach Pro springs, GT500 strut mounts, and Monroe dust covers and bump stops, plus Eibach camber bolts for the front.
I want to try to assemble the whole front suspension so I can just replace it without having to disassemble the stock suspension. This is my first time doing this, so I want to try to make sure I'm doing it right. I have just hand tools, torque wrench, and spring compressor.
How much do I have to compress the springs, do I have to compress it enough so that the strut mount sits all the way down like in the first pic I posted below? I plan to use the top strut nut that came with the Konis.
I wish bump stops and cover were included. The jounce/bumpers I got don't fit the struts perfectly, it looks like I would have to trim it, should I just get the FRPP jounce stops?
Which way should I install the strut mounts? It says to install the GT500 mounts with the arrows pointing out, but I read some people say to install it reverse, with the arrows pointing toward the engine to keep the wheels closer to alignment.
ID:	168906   Click image for larger version
2014 Mustang GT, DIB, MT82, Tech and Track Package
mods are coming, slowly
kanine is offline   Reply With Quote
Old 11-01-2014, 05:26 AM   #2
Grabber Blue5.0's Avatar
Install the GT500 mounts with the arrows pointing in towards the engine compartment.
How much of a drop are those springs? Do not use the camber bolts until you see where you're camber is set at. The method I use should gain back most if not all of your camber depending on the drop amount.
Old 11-01-2014, 06:42 AM   #3
kingstrider's Avatar
Check out some of the youtube videos if you haven't done this before, or read a shop manual.
2014 Grabber Blue Mustang GT Premium with nav, RR and comfy packages, 3.73 limited slip axle and optional 19" machined aluminum wheels. Come hang out in the garage and check out my build so far!
kingstrider is offline   Reply With Quote
Old 11-01-2014, 02:10 PM   #4
They are Eibach Pro Springs, drops 1" in front and 1.5" in back.
I watched videos of it, just want to know how much the spring need to be compressed, I assume it has to be compressed enough that the strut mount can be screwed on to the lowest part of the threads on the shaft.
Old 11-29-2014, 08:03 AM   #5
20bmr14's Avatar
When you compress the spring you will know when its enough, the spring and the compressor will be loose and the bottom of the spring will seperate from the strut/perch.
Roush Supercharger,Custom axleback,x-pipe,Barton short shifter with Blowfish trans bracket,Whiteline trans bushing,McCleod RXT twin disc clutch w/billet steel flywheel,Steeda braided clutch line,Steeda g-force brace,BMR cradle lockout braces and bushings,Whiteline front sway bar,SR rear sway bar,SR rear vertical links,MM camber plates,Mich Pilot SS 255/305,Roush rear spoiler and hood heat extractors,and Ford Performance hood shocks,JLT oil separator,Flossy heavy weight shift knob
20bmr14 is offline   Reply With Quote
Old 11-29-2014, 06:43 PM   #6
Getn off's Avatar
Very easy install. Follow this vid if u get stumped. Used a jack under the lower A arm to compress spring. Good luck,
Troy
S197 Mustang Lowering Spring Installation
Getn off is offline   Reply With Quote
Old 11-29-2014, 09:39 PM   #7
Thank you, but I have them installed already, was not hard, just getting the two bottom strut bolts loose was the hardest part.
Just FYI, I installed them with Steeda Sport Springs, the 11-14 Eibach Pro kit does not fit with 05-10 struts, while the other springs listed as 05-14 do.
Old 12-15-2014, 09:31 AM   #8
Sean313's Avatar
Hi I have a 2013 mustang gt with eibach prokit springs on about 6 months ago just notice the inner of my two front tires are wearing out uneven especially the insides just purchase eibach camber bolts do you know where I should align the tabs so my tires can wear evenly?
Sean313 is offline   Reply With Quote
Old 12-15-2014, 06:36 PM   #9
20bmr14's Avatar
I would have an alignment done and have that person dial it in with adjusting the camber bolts, then you know its right.
Old 12-15-2014, 06:40 PM   #10
Sean313's Avatar
Should I install it first or have the shop install itand adjust it
Old 12-15-2014, 07:00 PM   #11
20bmr14's Avatar
I have always installed them and just let the tech do the alignment. Just make sure you tell the tech you have camber bolts.
Old 12-15-2014, 07:22 PM   #12
Sean313's Avatar
Ok thanks a lot for your help
Installing LCA's Have Some Questions Big Q 2011-2014 Mustang GT 4 06-02-2014 10:30 PM
installing 4.6 sohc questions qtuic 1996-2004 Mustang GT 5 04-20-2014 05:46 PM
will trade fairings and lowered suspension for stock suspension vincent1 1996-2004 Mustang GT 2 06-22-2009 07:34 AM
Questions on Installing Longtubes petrey10 Pre-2005 V6 Mustang 11 12-21-2005 12:43 PM
Installing Suspension bluemustang 1979-1995 Mustang GT 16 04-13-2005 06:56 PM
08:24 AM
