Uca lca installation - Mustang Evolution
Old 11-03-2014, 08:36 PM   #1
WhiteCali5oh's Avatar
Region: West Virgina
Hey guys I need to get my upper control arm and bracket(hotchkis) (bmr bracket) and bmr lcas w bmr relocation bracket installed. I'm lowered on the eibach pro kit. Should I get the dealership to install that stuff or could I do it? My dad has any tool I would need. But idk how to do the pinion angle. I need y'all's opinions or recommendations.
WhiteCali5oh is offline   Reply With Quote
Old 11-03-2014, 08:37 PM   #2
Also need to know which holes they need to be put into on the brackets and the recommended
Pinion angle after lowering with the new uca
Old 11-03-2014, 09:10 PM   #3
The Blue Dragon
GrabberBlue5.0's Avatar
First off I'm not completely sure why your UCA and bracket are different brands, they are made to work together and some are not compatible with a different brand.
Aside from that it is not difficult work to do from an intelligence standpoint but it can be physically demanding and exhausting. My main concern would be getting the new Uca and mount in and properly tightened. That actually holds the axle to the body.
If you decide to do it yourself, plan for a minimum of 6 hours of work time. With the proper tools, knowledge, and strength it's a moderately easy task.
I don't remember which hole the uca should be mounted in on the bracket but I think it's the lower hole and for a street car I would mount the lcas into the middle hole on the relocation brackets.
Most shops that can do alignments should be able to adjust pinion angle so long as the have an angle finder. That cannot be done on jack stands very easily
New quick exhaust video
AUGUST 2012 MOTM!!!!
Old 11-03-2014, 09:11 PM   #4
Well I didn't know they had to match.
Old 11-03-2014, 09:20 PM   #5
JoeyM91's Avatar
They may not "have" to match. However, it's just a good rule of thumb to match brackets with parts of the same brand to ensure the best fit and compatibility.
There's several videos you can watch, like the CJ pony parts one that shows how to install them.
The LCAS aren't bad, but the UCA takes some convincing.
Old 11-03-2014, 09:22 PM   #6
I can do the lcas I'm sure but not the uppers. I guess I should let the shop do it. Will ford know what the pinion angle should be now?
Old 11-03-2014, 09:23 PM   #7
JoeyM91's Avatar
Uppers? Plural? Just making sure you only bought 1....
Ford would, but the dealership is generally the most expensive and worst option. They normally don't stand behind their work with aftermarket parts and are 2-3 times more expensive.
Old 11-03-2014, 09:25 PM   #8
I meant upper. My b
---------- Post added at 09:25 PM ---------- Previous post was at 09:24 PM ----------
I have a gmc Chevy Buick dealer I take my vehicles to for alignments and they're supposedly the best in the area with about anything and maybe I'll let them do it
Old 11-03-2014, 09:25 PM   #9
JoeyM91's Avatar
I meant upper. My b
All good. Forgot to mention, a shop that does suspension can look up the pinion angle. They almost all use Alldata which has factory specs for most cars on there.
Old 11-03-2014, 09:26 PM   #10
What should the pinion angle be now that I'm lowered do u guys know.
Old 11-03-2014, 09:30 PM   #11
The Blue Dragon
On a street car you will want it somewhere between 1.5-2*
Old 11-03-2014, 09:31 PM   #12
1.5 - 2 degree correct
Old 11-04-2014, 05:10 AM   #13
Riko's Avatar
Per BMR instructions
ADJUSTING PINION ANGLE WITH AN ADJUSTABLE UPPER CONTROL ARM
Make sure the rear end is loaded by either setting the car on the ground or letting the car rest on jack stands positioned under the rear axle. In both cases, the car needs to be as level as possible and the suspension loaded.
• Place an angle finder on the rear portion of the two piece driveshaft and record the angle. Now place the angle finder on the pinion yoke and record the angle.
• Subtracting one angle from the other results in your pinion angle (Example: -2 rear end angle subtracted from 0 driveshaft angle = -2 degrees)
• Adjust the control arm to achieve the desired angle.
• As a starting point, most cars respond well to the following initial settings: Automatics: 1-2 degrees negative, Manuals: 2-3 degrees negative
• Once pinion angle has been set, apply Loctite to jam nuts and tighten.
Riko is offline   Reply With Quote
Old 11-04-2014, 08:14 AM   #14
LuisBlackGT's Avatar
If your doing it on the ground make sure you can torque a bolt to 130-ft lbs while on your back
2014 Black Mustang GT. 20" Amr wheels, Sr Performance lowering springs 1.5", stillen front chin, mmd window louvers, roush AB exhaust. FOLLOW ME ON INSTAGRAM: @barrios_Luis
LuisBlackGT is offline   Reply With Quote
Old 11-04-2014, 09:10 AM   #15
Voltwings's Avatar
Have a good 1/2" torque wrench and get the car in the air as high as you can. Certain parts of the LCA / brackets need to be tightened to like 130 ft/lbs and that is a ***** if you're cramped under the car. All in all i agree with others, its not a "difficult" install, its just physically demanding since all that **** is so tight.
Lca Uca questions 11stangGT 2011-2014 Mustang GT 12 01-14-2014 10:02 AM
lca's and uca jaymoe5555 2011-2014 Mustang GT 9 08-29-2013 05:52 PM
UCA/LCA Install WCatoe 2011-2014 Mustang GT 11 03-21-2013 04:07 PM
Wanted: Rear LCA and UCA for 2012 Srohda Mustang Parts for Sale and Wanted 1 02-27-2013 08:53 AM
LCA UCA sLbxO143 General Mustang Discussion 0 12-07-2012 05:42 PM
04:15 PM
