Borla Exhaust Issue - Mustang Evolution
Old 11-04-2014, 03:31 PM   #1
George T's Avatar
Borla Exhaust Issue
I just had Borla Cat-Back Exhaust S-Type (140515) installed on my 2013 Mustang GT. The sound is excellent. Anyway after the installation I had some squeaking and thumps when going over bumps. I decided to take the car to a local shop (not the one that installed the system) that specializes in hi-performance after market parts and has a mechanic that has installed many Borla exhausts. He showed me where the left pipe was actually touching the rear end pumpkin and the right pipe was pressed up against the floor above the axle. His comment was that he's been seeing quality issues with both Borla and Flowmaster since they started making them in Mexico. When the were US made he said he never ran into fit problems. Anyway, he cut 3/4" off the each pipe where they joined in the middle and was able to correct the issues. Just curious if anyone else has seen any issues.
2013 Mustang GT (Track Pack)
George T is offline   Reply With Quote
Old 11-06-2014, 01:10 AM   #2
grabber12's Avatar
I have the Borla atak. Sometimes when I get on it real hard and heat up the exhaust I also hear rattling as if it's touching my floor on the passenger side. I've taken it to exhaust shops had them weld in new hangers and it helped but I still hear it from time to time. I've got under the car at least 5 times to see where my clearance issues were and there's at least 1 to 2 inches of clearance at the tightest spots so I have no clue where it's touching if its even the exhaust making the noise.
But it's only when it gets driven hard. I even had Borla replace my exhaust under warranty because I thought the inside of the exhaust came loose and even with a new exhaust it makes the same sound.
2012 Grabber blue, Auto, Eibach pro street S coilovers, MM caster/camber plates, Borla ATAK cat back, off road X pipe, A.E.M CAI, SCT-x4 Mike Roush tune,SR LCA's, BMR Relocation brackets, J&M Pan hard bar, UPR Catch can, SVE 15x10's, Mickey T's 275-60-15.
grabber12 is offline   Reply With Quote
Old 11-06-2014, 08:00 AM   #3
GrabberMeBlue's Avatar
When you crawl under to look, is the weight of the car on the suspension and not jacked up off the ground?
2012 Grabber Blue V6 Convertible
1995 Red Trans Am Convertible
1979 Gold Trans Am
GrabberMeBlue is offline   Reply With Quote
exhaust
Borla stinger vS borla atak 2002VertGT 1996-2004 Mustang GT 49 03-28-2014 04:28 PM
Borla Exhaust Issue dinosoar 2005-2010 Mustang GT 2 04-27-2013 04:06 PM
Borla S-type Vs Borla Atak? Sppankyy 2005-2010 Mustang GT 10 11-27-2012 05:04 AM
got Borla exhaust jimmy_beaner The Bar 16 10-03-2006 11:41 AM
Borla GT Exhaust Black95GT Pre-2005 V6 Mustang 2 09-12-2003 09:33 AM
02:19 AM
