Sct return to stock error? - Mustang Evolution
Old 11-06-2014, 02:50 PM   #1
UrMaster's Avatar
So my 11 gt is at the body shop and it needs to go to Ford to have a new EPAS programed. I went down to the shop and returned the tune to stock with my x4 and did a kam reset. When done the car idled really rough and was missing. Threw engine light for some sort of block corrupt code or something. I called sct and they suggested unplug battery for 5 min so I did so. After about 10 min I plugged it back in and everything seemed good. Now after a few weeks of the car being at the shop and being moved in and put of the shop a few times the engine light back on for P0300. Would the car being fired up and moved around on a stock tune cause this with having a jlt cai, boss im headers etc? Personally I doubt it and wonder if the original issue returning to stock is still causing an issue. My question is should I attempt to put my tune back on or is there a way to get a copy of the factory calibration for my x4? Don't want to try and upload my tune see if it fixes it and brick the pcm.... Anyone else had a similar issue? And no I don't remember what the corrupt block code was. It was a few weeks ago.
Sent from my SM-N900V using Mustang Evolution mobile app
2011 GT Premium A6 glass roof.
Dynatech LT's, OR-X, Kooks Axle-back, Circle D 5c, Boss IM, BBK 85mm TB, JLT CAI, BMR LCA's, adj UCA & Panhard,Strange 10 way struts, 331 gears tuned by AED.
UrMaster is offline   Reply With Quote
Old 11-06-2014, 03:17 PM   #2
natestang07's Avatar
I would not even start that car on the stock tune with those mods.
05 Gt Premium Performance White, flowmaster outlaws, Jlt Series 3, Bama 91r tune
Old 11-06-2014, 03:49 PM   #3
UrMaster's Avatar
Doubt it's gonna hurt it if your not driving it for a distance or beating on it. I always had to remove the tune down the street from the dealer whenever I took it in for warranty work and never had an issue.
Old 11-06-2014, 03:54 PM   #4
Well I would put your tune back on. Did you save your stock tune to your computer?
Old 11-06-2014, 04:01 PM   #5
UrMaster's Avatar
That I am not sure. Basically got my tunes, loaded them to the x4 and installed them. Don't recall ever transferring the factory tune anywhere..
Old 11-06-2014, 04:03 PM   #6
I am pretty sure sct can get a stock tune if you give them a call. Try that
---------- Post added at 03:03 PM ---------- Previous post was at 03:03 PM ----------
Amd save it on your computer somewhere just in case
Old 11-06-2014, 08:18 PM   #7
UrMaster's Avatar
I'll give them a call. Thanks
SCT X4 Error Message 21301 memphisryder 2011-2014 Mustang GT 9 10-02-2014 10:39 PM
SCT SF3 Error #1018 ninerone 2011-2014 Mustang GT 7 09-25-2014 02:45 PM
P1639 code, then error 1027 on SCT SF3 Yellow Vert AmericanMuscle 1 04-16-2014 09:13 AM
Sct filesystem error? cory21 2005-2010 Mustang GT 2 06-27-2012 02:45 PM
SCT "return to stock" problem back n a stang 2011-2014 Mustang GT 7 04-08-2012 07:24 PM
10:41 PM
