2014 Mustang GT Ticking noise under hood - Mustang Evolution
Old 11-06-2014, 04:55 PM   #1
So today I went outside to show my friend my exhaust and get his opinion on it and when we turn the car on and let it warm up we notice that there is a ticking noise coming from under the hood. We pop the hood to check under there, everything LOOKS normal but the ticking noise is there and its not the sound of the engine idling its a separate sound. So I come back in and do some research and long behold I'm not the only one who has encountered this. I saw posts about a lifter and some about having Ford replace their motor. I have an appointment with Ford on Monday to get it checked out but just wanted to see if anyone on here has had first hand experience with this and if I could get their insight. The mods that are currently on the car are just pype bombs and an after cat X pipe. I did run catless for like 5 days going about 150 miles without a tune but that's it, I put the cats back on after that. Just mentioning the mods to see if they make any difference.
kaveh14GT is offline   Reply With Quote
Old 11-06-2014, 06:25 PM   #2
blackie's Avatar
go to search and enter ticking sound, a long thread on the issue.
you will be educated.
blackie is offline   Reply With Quote
Old 11-06-2014, 09:33 PM   #3
Just run it in 1st gear at 6 rpms for a couple miles. Clear that carbon out. J/k...sawgrass ford did that to guys car though...lol they ended up buying it back from the guy because it went viral.
Sent from my SM-G900T using Mustang Evolution mobile app
Mikeyt03 is offline   Reply With Quote
Old 11-07-2014, 09:02 AM   #4
I'm confused about your tick. Is it the engine ticking? You said it isn't the engine. If not the engine, you should be able to find which thing it's coming from - AC, alternator, etc. Does the tick coincide with rpm's? Only hot engine?
jd864 is offline   Reply With Quote
Old 11-07-2014, 09:07 AM   #5
Search is your friend.
Old 11-07-2014, 09:08 AM   #6
What I meant by it's not the engine is that it isn't the idling noise. It may come from the engine but it isn't the engine idling. I worded it poorly I know, my bad. And it only ticks when its warmed up and idling, but I might not be able to hear it other than idle because my exhaust drowns out the noise.
Old 11-07-2014, 09:15 AM   #7
Most people find the valve train to have slight ticks and chatter at idle. Not real loud, hard to pinpoint. And it's pretty normal. If you stand at the engine and go from idle to 2k rpm, and the tick goes with the engine, get Ford help. Just my opinion.
2014 mustang
Ticking under the hood Jay180 1996-2004 Mustang GT 5 10-23-2014 04:30 PM
Ticking under the hood 5.0car 1996-2004 Mustang GT 24 10-17-2014 11:34 PM
ticking sound under my car? Vile87 Pre-2005 V6 Mustang 29 03-04-2012 08:42 PM
Ticking under load MustangGT02 1996-2004 Mustang GT 13 01-18-2012 03:40 PM
Nasty noise under the hood please help! S197STANG 2005-2010 Mustang GT 18 11-05-2011 11:14 PM
01:54 PM
