Can someone describe the difference in the feel and performance of the two? I have a steeda tri ax and I want to try another shifter. The steeda is good, but I wanted a shifter takes a little less effort to get into gear. 1st to second is pretty rough with the steeda.
People say the barton is notchy...what exactly does that mean? Is the MGW a similar feel?
Sent from my SM-G900T using Mustang Evolution mobile app
MGW comes as a complete package I love the way it's shifts a lot smother and very precise. No experience with Barton but I have heard good things about them.
No that would be notchy imo. It's real precise you know exactly what gear your going into there is no fight going into gear that's what makes it smooth for me
I have a Ford Racing (Barton) and my buddy has the MGW, the both feel the same shift wise, the only difference is the MGW is in reverse and you are taking it out of reverse, it springs back, the Ford Racing doesn't.
The MGW is a great shifter. The MT-82 itself is the culprit in what you are describing. Search the forum for a better fluid in the transmission. Several members claim improvement in shift quality after such a swap.
No its not what I'm describing. It's the shifter for sure. There's nothing wrong with the shifter, I would just prefer a shifter with less of a notchy feel. If the mgw is less notchy, I'm going to go that route. 2nd gear is harder to get into in higher rpms, but that's a clutch and trans twist issue I believe.
Mgw hands down read reviews on it. The only shifter company that swaps out the whole shifter no other one does. They will install it for free if u make a appointment
There is also the Whiteline bushing insert. Basically it fills up the voids in the horrifically designed OEM rubber trans mount and keeps the tailshaft from jumping all the hell over the place and binding up the shift linkage at higher RPMs.
you would see a diff. The Steeda is a step above the stock shifter which is sloppy and notchy. The barton is a firm but positive shift into any gear. I did the shifter & bracket and was happy then did the whiteline bushing a week or so later and all my shifts are solid and sure.....and quick.
Whiteline bushing seems to make a huge difference. Just watching the install videos of it you can see that it would have to. Not sure wth Ford was thinking with that bushing...
What's really sad is that it costs the enthusiast $1000 in parts to fix this shifting issue for a transmission that Ford designed to keep the cost and NVH down.
The GT500 MGW... that might as well be a required modification literally as soon as you pull your car into the driveway from driving it home before you ever fire it up and drive it again.[/QUOTE]
Yea, pretty much what I did. Installed my MGW AT 2500 miles. It has solved most of my shifting issues.
Related Threads
Mustang Evolution Forum
2.1M posts
50.8K members
Since 2003
