HELP: Squeaking Wheel - Mustang Evolution
Old 11-18-2014, 12:58 PM   #1
I would appreciate any input on what is going on with my 2014 mustang gt / brembo package. My car currently has 7,500 miles on it.
At about 4,000 miles I lowered it on steeda springs, panhard bar, lower control arms, exhaust, etc. About a 1,000 miles later this squeaking started from my left front tire. Every time the tire rotated it squeaked.
I replaced all four rotors with cross-drilled rotors and new brakepads, the squeaking continued (metal on metal sound - high pitched). I brought my car to ford today and they replaced the front left control arm, the squeaking continues.
It goes away when I apply the brakes. I haven't read or heard about this issue before. Any idea what this can be? Thank you for any suggestions.
ajaffe90 is offline   Reply With Quote
Old 11-18-2014, 01:58 PM   #2
DallasStang77's Avatar
You probably didn't grease the bolts and/or the bushings in the control arms enough
Old 11-18-2014, 02:44 PM   #3
Thanks for responding, do you think it could still be the control arm when the noise stops when I apply the brakes?
Old 11-18-2014, 06:33 PM   #4
When you slow down, the front springs compress and the sound goes away. Did you put spring isolators on the springs? The jam nut on the panhard bar could be loose as well.
Sent from my SM-G900T using Mustang Evolution mobile app
Mikeyt03 is offline   Reply With Quote
Old 11-20-2014, 12:08 AM   #5
LuisBlackGT's Avatar
I think I have the same problem in the rear..
2014 Black Mustang GT. 20" Amr wheels, Sr Performance lowering springs 1.5", stillen front chin, mmd window louvers, roush AB exhaust. FOLLOW ME ON INSTAGRAM: @barrios_Luis
LuisBlackGT is offline   Reply With Quote
Old 11-20-2014, 12:56 PM   #6
This sounds mostly like bad wheel bearing. Just because the car is fairly new or low mileage, does not mean a bearing isn't bad.
kn7671 is offline   Reply With Quote
squeaking help! john.petr0 1996-2004 Mustang GT 4 05-30-2014 02:02 PM
HELP! Loud squeaking!!! Joe_Roma5 2005-2010 V6 Mustang 9 06-24-2013 04:27 PM
Squeaking come from steering wheel sLbxO143 General Mustang Discussion 11 11-07-2012 12:05 PM
brakes squeaking help!!!!!! really annoying austinknoll Pre-2005 V6 Mustang 11 02-16-2012 09:31 PM
Help! squeaking stang! betocruzazul Pre-2005 V6 Mustang 4 08-21-2011 12:10 AM
10:06 PM
