Rear swaying at high speeds... - Mustang Evolution
Old 11-22-2014, 05:33 AM   #1
Mustang32Bill's Avatar
So I just installed upr adjustable upper control arm and lower control arms with bmr relocation brackets. Yesterday I realized the rear will sway pretty bad at high speeds. Anyone know what this issue could be?
Mustang32Bill is offline   Reply With Quote
Old 11-22-2014, 06:32 AM   #2
zinc03svt's Avatar
Define high speeds? Going straight or turning?
2014 "Cobra Jet" GT/CS
Automatic, Comfort pkg, Oxford White
zinc03svt is offline   Reply With Quote
Old 11-22-2014, 06:33 AM   #3
Straight around 100mph
Old 11-22-2014, 06:42 AM   #4
zinc03svt's Avatar
Do you still have front sway bar?
Old 11-22-2014, 06:45 AM   #5
Yeah still have front and rear sway bars. Thinking maybe something todo with the uca maybe my shop that installed it didn't adjust it right? Or I do I have coilovers on the car so maybe they are to stiff in the rear?
Old 11-22-2014, 07:12 AM   #6
Check the gaps between the rear tires and the front edge of the wheel-wells on both sides with a ruler. If they are not within 1/8" of each other, it will cause the rear end to wander as you described. Some with the BMR brackets have noticed a difference in this measurement after their install as well. If this is your case, contact Kelly at BMR and he will help you fix it. Don't worry about your UCA, it only controls the pinion angle.
Current Mustang: '14 GT/Track Pack/6spd-sold
Previous Mustangs: '68 Coupe, '73 Mach 1, '89 GT,
Hoss is offline   Reply With Quote
Old 11-22-2014, 07:13 AM   #7
zinc03svt's Avatar
Yep. Too stiff of rears with your rear sway would cause induced oversteer. Soften them up. Besides, for drag you want them soft for weight transfer. Make sense?
Old 11-22-2014, 08:27 AM   #8
Ok I'll try to soften them up and see if that helps
Old 11-22-2014, 09:08 AM   #9
Grabber Blue5.0's Avatar
Bill,
I run my strange struts 2 clicks from full soft in the front and my shocks 7 clicks from full soft in the rear. This is for the strip. You want it firm in the rear not soft. On the street I run full soft in the front and half way (5 clicks from full soft) in the rear.
Old 11-22-2014, 09:15 AM   #10
Originally Posted by Grabber Blue5.0 View Post
Bill,
I have them stiff all 4 corners right not I'll make some adjustments and see if it helps
Old 11-22-2014, 09:20 PM   #11
BigJay's Avatar
are your lower arms adjustable? With relocation brackets you should be using adjustable imo. Relocation brackets can be off and the adjustable LCA can make up the difference. Since this became an issue with the install check axle alignment. Good luck!
BigJay is offline   Reply With Quote
Rattling at High Speeds VTHokiez 2011-2014 V6 Mustang 10 10-28-2014 04:54 PM
Right rear rattles at slow speeds after lowering 20bmr14 2011-2014 Mustang GT 3 02-11-2014 06:59 PM
Knocking sound coming from rear end at slow speeds? roch 1996-2004 Mustang GT 2 12-11-2011 07:22 AM
91 GT shifting into 3rd at parking lot speeds (~15-20 MPH) 91StangGT5.0 1979-1995 Mustang GT 31 06-01-2011 04:01 PM
Freakin Awesome. Comcast Ups Their Upload Speeds Brent The Bar 5 07-05-2008 03:47 PM
02:17 PM
