School me on sway bars - Mustang Evolution
Old 11-23-2014, 08:55 AM   #1
I have a staggered set up, and I'm getting some weird steering problems on turns. It's like the car wants to turn by itself. I've heard that a stiffer rear sway can reduce this to a neutral feeling and improve steering. My question is, is there an added benefit to replacing the front sway bar as well while I'm at it? Im looking at the steeda rear sway that is 349. The package with both rear and front is 499. Thoughts?
Mikeyt03 is offline   Reply With Quote
Old 11-23-2014, 09:09 AM   #2
Actually I think I answered my own question. I'm going to get both. This way I can adjust them as needed. I think I actually need to increase the front sway to fix my problem right? I'm turning in fast because I'm losing traction in the rear, which a larger front sway would fix right?
Old 11-23-2014, 09:49 AM   #3
BigJay's Avatar
Have you tried tire pressure adjustments yet? When was last alignment? If so what settings?
BigJay is offline   Reply With Quote
Old 11-23-2014, 10:18 AM   #4
Grabber Blue5.0's Avatar
I don't even run a front sway bar....................
Old 11-23-2014, 11:20 AM   #5
Frozen Yettie's Avatar
I have the Steeda Front adjustable and rear adjustable and I can say they stiffen up the car a lot when you are turning or maneuvering through traffic or U turns. Its way beefier than the stock swaybars.
If it feels like its turning by itself then go get an alignment check and check if the tires are correctly balanced.
2014 Black Mustang 3.7L V6 Premium | 93Race MPT Tuned | Too many mods to list just check out my garage.
Frozen Yettie is offline   Reply With Quote
Old 11-23-2014, 02:27 PM   #6
Which package do you have? There are two different packages. One has a thicker rear sway. And is priced at 499.
Old 11-23-2014, 02:45 PM   #7
I got this one. Notice that the rear is adjustable as well. I got mine on the fall sale they were having a couple of months ago.
Steeda 2005-14 Mustang Ultimate Swaybar Kit - Made in USA 555-1080 - Free Shipping!
But this one. If you notice the rear swaybar is not adjustable. I don't know why they named it the adjustable kit but only the front is adjustable in this kit.
Steeda 2011-14 Mustang Adjustable Swaybar Kit - Made in the USA 555-1072 - Free Shipping!
Steeda lists them weird but you gotta read what you are getting.
Old 11-23-2014, 09:44 PM   #8
What do you have them set to?
Old 11-23-2014, 09:46 PM   #9
You also only drive in a straight line, so not exactly relevant here..........
Old 11-23-2014, 09:48 PM   #10
Stiffer rear sway bars generally induce oversteer and/or reduce understeer.
Stiffer front sway bars generally induce understeer and/or reduce oversteer.
Understeer is when the front end isn't quite able to turn and feels as if it washes out.
Oversteer is when the back end wants to come out wide in the turn.
Based off this, take into account what exactly is happening and make the adjustment accordingly.
You say " I'm turning in fast because I'm losing traction in the rear,". If you lose traction in the rear then you have oversteer, which is corrected by stiffer front sway bars.
Old 11-23-2014, 09:54 PM   #11
Yep that's why I said I needed a stiffer front. I'm going to get both and set them to what works well for me.
Old 11-23-2014, 09:55 PM   #12
Yea having both will help. Then you can do small adjustments to try and make it more balanced.
Roll bars or no roll bars stanzmustang08 2005-2010 Mustang GT 8 10-01-2014 04:14 PM
Last year for rear sway bars on V6 Mustangs? Brent Pre-2005 V6 Mustang 9 05-19-2004 11:30 AM
running skinnies and no sway bars tire The Bar 2 03-05-2004 11:39 AM
sway bars part2 JoeR. Pre-2005 V6 Mustang 10 01-05-2004 11:37 AM
Sway bars JoeR. Pre-2005 V6 Mustang 26 01-05-2004 10:49 AM
08:24 AM
