2014 Mustang Gt Rear End - Mustang Evolution
Old 11-24-2014, 02:40 PM   #1
mustang145.0's Avatar
hey hows it going guys i have a question i have a 14 gt base and was wondering what the difference between the base and track pack rear end is it only the gear ratio? or is the track pack better for handling cuz ima need a new rear end for my car and if track pack gives better handling rather go with that but ya i would like to know the differences thanks
mustang145.0 is offline   Reply With Quote
Old 11-24-2014, 02:48 PM   #2
DallasStang77's Avatar
It's got a 3.73 axle gear and a Torsen differential as well as different shocks.
Old 11-24-2014, 03:01 PM   #3
Region: Oregon
Also has the GT500 LCAs and stiffer springs.
So very different from the standard GT.
skramblr is offline   Reply With Quote
Old 11-24-2014, 03:06 PM   #4
The GT500 LCAs are almost the same with slightly stiffer rubber bushings. Both LCAs are stamped metal.
Didn't realize about the stiffer springs.
Still apparently floats like a boat tho so OP do try to look into aftermarket parts to remedy the boat like ride and the wheel hop.
Old 11-24-2014, 03:11 PM   #5
pss3286's Avatar
And the finned differential cover
pss3286 is offline   Reply With Quote
Old 11-24-2014, 03:39 PM   #6
would u guys say the torsen diff gives better handling? ima put aftermarket springs, shocks, lcas so no need for me to worry about those
Old 11-24-2014, 03:48 PM   #7
Great for turning as it puts power down to the wheel with the most traction.
Without it the rear wheel will spin and kick out more slide.
Old 11-24-2014, 06:03 PM   #8
Region: Oregon
I've heard the standard gears are better (stronger?) for drag racing and the Torsen is better for power thru turns. I've had both and could tell the difference in cornering. Most of my driving is on twisty roads, so I opted for the Torsen on the 2014.
Old 11-24-2014, 07:20 PM   #9
hctr154's Avatar
Maybe some one can chime in and answer a question about Track Pack springs for me. Would installing them in place of standard GT springs lower the car? I have a local guy literally giving some away on Craigslist, that's why I'm asking.
hctr154 is offline   Reply With Quote
Old 11-24-2014, 07:30 PM   #10
Redonblackpony's Avatar
No. Only slightly stiffer.
Redonblackpony is offline   Reply With Quote
Old 11-24-2014, 11:20 PM   #11
i rather have handling over drag stripe so im most likely gna go with the torsen
2014 mustang
86 front end into an 89 front end Beatjunkiexorge 2.3 Mustang 1 05-18-2013 07:07 PM
How long is a mustang rear end compared to a ranger rear end. lenth meaning from tire to tire? macray33 General Mustang Discussion 1 03-14-2010 03:43 AM
Is a 1995 Mustang V6 rear end different from a 1995 Mustang V8 rear end? celyddon Pre-2005 V6 Mustang 2 08-25-2009 06:56 PM
Can i swap my 1997 mustang gt rear end for a 1995 mustang cobra one? mathieu 1996-2004 Mustang GT 1 08-21-2009 01:40 PM
Can a 2003 ford mustang gt rear end fit in a 1997 mustang gt? evian 1996-2004 Mustang GT 1 08-19-2009 02:24 AM
04:54 AM
