Going Away - Mustang Evolution
Old 11-26-2014, 07:46 PM   #1
Going Away
Team,
I will be going away on a business trip for 3 months and my question is about the battery, should I disconnect the battery, should I be concern about not using the car for 3 months.... Any subjection is more than appreciated.... btw I have a 2014gt, auto transmission
T.
"These cars are meant to be driven", so enjoy all of it - not just the look of it when it is all clean" - Carroll Shelby
blancoj17 is offline   Reply With Quote
Old 11-26-2014, 08:16 PM   #2
teabagsax's Avatar
Region: Nevada
You should have it immediately shipped to me for 'steadfast maintenance' while you are away.
teabagsax is offline   Reply With Quote
Old 11-26-2014, 08:30 PM   #3
BigJay's Avatar
Battery tender, stabil in your fuel and run it a bit to get it in the fuel system, ideally tires off the ground suspension weighted. Moisture control in cabin and trunk. In doors or out?
BigJay is offline   Reply With Quote
Old 11-26-2014, 08:40 PM   #4
Indoors (house's garage)....
Old 11-26-2014, 08:49 PM   #5
BigJay's Avatar
In the garage you can leave a window cracked helps keep inside from developing moisture mildew etc. They make tire cradles that keep tires from flat spotting and you won't have to block it up.
Old 11-27-2014, 05:24 AM   #6
I like the idea of the tire cradles any one in specific you recommend, I just did a search and there are so many to choose from and the cost is around $250...btw thanks every one for your responses and recomendations...and Happy Holidays....
Old 11-27-2014, 06:53 AM   #7
kingstrider's Avatar
Battery tender, full tank and fuel stabilizer and you should be good. I wouldn't worry too much about the tires, they are made much better than the old bias tires that used to develop flat spots. If worried you can over-inflate the tires a little and/or park on carpet squares or foam insulation. Most people think the tire cradles are a waste of money.
2014 Grabber Blue Mustang GT Premium with nav, RR and comfy packages, 3.73 limited slip axle and optional 19" machined aluminum wheels. Come hang out in the garage and check out my build so far!
kingstrider is offline   Reply With Quote
Old 11-27-2014, 08:16 AM   #8
BigJay's Avatar
They are a bit spendy but it does help. My classics sit quite a bit and even though the have stellar rubber they still flatspot. I think tufframp makes the least expensive solution. Personally, jacking up each corner and putting a cut piece of 8x8 under the front control arms and rear axle housing is much cheaper and makes it a deterrent for someone to joyride while your away.
Old 11-27-2014, 08:56 AM   #9
Laquisha's Avatar
Lol sucks to do all that work! Never knew it was all that much
Old 11-27-2014, 09:03 AM   #10
UrMaster's Avatar
Stabil for a 3 month storage? Really? I've always heard ya only need that stuff if it's gonna be in storage for a year or more.
Sent from my SM-N900V using Mustang Evolution mobile app
2011 GT Premium A6 glass roof.
Dynatech LT's, OR-X, Kooks Axle-back, Circle D 5c, Boss IM, BBK 85mm TB, JLT CAI, BMR LCA's, adj UCA & Panhard,Strange 10 way struts, 331 gears tuned by AED.
UrMaster is offline   Reply With Quote
Old 11-27-2014, 03:34 PM   #11
BigJay's Avatar
At 8 bucks you bet. Stabil only protects up to a year. Helps with ethanol and moisture etc. Cheap insurance especially during winter storage. All it takes is getting buggered up once and you wont go without.
Old 11-28-2014, 01:10 AM   #12
UrMaster's Avatar
Good point
Old 11-28-2014, 10:56 AM   #13
hctr154's Avatar
Stabil in the tank and run it for a few minutes afterwards is the most important. Maybe a smart charger for the battery as well.
hctr154 is offline   Reply With Quote
Old 12-02-2014, 04:48 PM   #14
Thank You to all....as always wise recommendation....
Old 12-02-2014, 09:22 PM   #15
ddtmoto's Avatar
Region: Utah
Corn liquor only has a shelf life of like thirty days. Use an additive made to address food storage in your gas tank.....better safe than sorry
ddtmoto is offline   Reply With Quote
Rearend going finally going in tomorrow! 86gt 1979-1995 Mustang GT 5 08-31-2011 05:25 PM
the 88 is going away for awhile... Bane- The Bar 8 07-25-2005 09:31 AM
I got rims ! Giving away some nice stock V6 rims and tires ASSEMbler Mustang Audio & Video 5 11-30-2003 03:13 PM
Been away for ages! Morpheus The Bar 8 10-31-2003 11:53 AM
another video... rx7 getting blown away by gattling gun Zim The Bar 5 07-23-2003 10:47 AM
11:11 AM
