Longer crank than normal - Mustang Evolution
Old 11-29-2014, 07:53 AM   #1
Hey guys I have been away from the forum for a while but I am searching for help. This has happened sporadically but now it has begun to get me nervous and annoyed.
I have a 2011 GT with CAI, tune, boss intake manifold.
I go to start my car and it cranks longer than normal before start up. Sometimes it just cranks and keeps cranking. When it does this i usually turn the key to the off position and try to start the car again. It usually does it about 2/3 times before a normal start up when it occurs. It has happened while the car is warm and it has happened while the car is cold. I thought misfire but I don't know if I am right. If you know what my issue is please let me know and how to fix it if you know that. My warranty is up so I would rather not go back to Ford.
phantomx2 is offline   Reply With Quote
Old 11-29-2014, 08:58 AM   #2
BLKBETTY13's Avatar
Possibly fuel related. Try changing your fuel filter.
BLKBETTY13 is offline   Reply With Quote
Old 11-29-2014, 09:04 AM   #3
BLKBETTY13's Avatar
Filter can be had for under $20 and only takes about 5 mins. to replace. It's located under a shield on the driver side under car and that cover removes with a few 10mm bolts. No special tool required as the new quick disconnectors are a push button. Be sure to disconnect the battery 1st and remove fuel pressure or at least have the car sit over night so you don't get a face full of gas. Enjoy...
Old 11-29-2014, 09:07 AM   #4
BigJay's Avatar
can you check for trouble codes with your handheld tuner?
BigJay is offline   Reply With Quote
Old 11-29-2014, 09:09 AM   #5
Sounds like your fuel pressure is bleeding off. If you have a gauge, you can test it at the fuel rail. Just attach it to the schrader-valve at night, then check it in the morning. It should hold for that long. There is a check valve to stop the pressure from dropping, but I don't know where in the fuel system it would be. Hopefully someone will help you out with that.
Current Mustang: '14 GT/Track Pack/6spd-sold
Previous Mustangs: '68 Coupe, '73 Mach 1, '89 GT,
Hoss is offline   Reply With Quote
Old 11-29-2014, 01:48 PM   #6
ddtmoto's Avatar
Region: Utah
Ford has a TSB on the '11 built before 8/16/2010 for the long crank to start issue. The dealer updates the software in the ecu...
ddtmoto is offline   Reply With Quote
Old 10-08-2017, 10:00 PM   #7
ridinrightauto's Avatar
Region: Arkansas
did u get it figured out???? Having same issues......
ridinrightauto is offline   Reply With Quote
Old 10-09-2017, 09:44 AM   #8
crjackson2134's Avatar
This thread died years ago. I would suggest you start a new thread.
2014 Black GT Premium - Track Pack - (Apocalypse)
2018 Black Nissan 370Z Nismo - (Lucille-2)
crjackson2134 is offline   Reply With Quote
Old 10-09-2017, 10:03 AM   #9
Strange Mud's Avatar
and a different answer...props on using search.
Old 10-10-2017, 09:42 AM   #10
Voltwings's Avatar
This.
Old 10-10-2017, 04:42 PM   #11
noldevin's Avatar
I just want to know how that guy thought the fuel filter was in the front, when it's actually on the pump
noldevin is offline   Reply With Quote
5.0 Runs hotter than normal mike_jay5.0 1979-1995 Mustang GT 5 09-02-2013 09:39 AM
Smokes on the drivers side alot more than than the passenger side Drgula5 1979-1995 Mustang GT 4 09-15-2012 12:08 PM
A different gear thread than the normal "what one to get" questions! (PLUS NEW #s!) CodyNelson 1996-2004 Mustang GT 62 07-18-2012 12:02 PM
I have a v8 1977 mach 1 mustang whats the reason for it sucking up so much gas than a normal v8? iddig17 Classic Mustangs 2 12-18-2011 04:50 AM
bigger crank pulley for SOHC? bigger than 6.5 inch? anything? blownranger Pre-2005 V6 Mustang 4 07-11-2010 08:03 PM
10:15 AM
